GB engine tin delete plugs Closes 12/31/19, PN 914.559.243.10 $6 a pair Confirmed These fit perfectly LIke OEM |
Mikey914 |
Dec 9 2019, 02:37 AM
The rubber man Group: Members Posts: 12,660 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
These are the delete plugs used on the 914/6 to eliminate the rain tubes as there is no rain tray on it.
They are also used on the early cars including 73 from what I can see on PET Stopper -73 1 914-4/1,7 for 914-2,0 Oil hose And Water drain sleeve 13 Stopper -73 2 914-6 for Oil hose And Water drain sleeve These are located in the Hell hole area and under the relay board. I'll post pictures up Monday afternoon, but if you have holes there these are what should be plugging them They are not on the low point, but on the part sloping down. Made from Nylon to the correct dimension like factory not a cheap plug that kind of fits At $6 a pair who's in? |
IronHillRestorations |
Feb 7 2020, 08:00 AM
I. I. R. C. Group: Members Posts: 6,717 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I dropped the ball on ordering mine and tried to order this morning, is the code no longer valid?
Mikey914 |
Feb 7 2020, 11:38 AM
I dropped the ball on ordering mine and tried to order this morning, is the code no longer valid? Sorry the GB is closed they are available, just a little more. https://900designs-container.zoeysite.com/s...and-body-panels We will be running a sale on them in the next news letter. won't be as good as the GB but still will save a bit. Will be out about the 20th. |
Lo-Fi Version | Time is now: 12th May 2024 - 07:23 PM |
