| jack20 |
Dec 14 2019, 08:10 PM
Member ![]() ![]() Group: Members Posts: 422 Joined: 7-November 14 From: Granite Bay, CA Member No.: 18,099 Region Association: Northern California
Hello, my side mirrors are in need of new glass and liners, what holds the glass in place. I know 914 Rubber sells the glass but is there a source for the liners? Is there a technique for removing and reusing the original liners without damage?
Thanks in advance. Jack |
| 914Sixer |
Dec 14 2019, 09:03 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,508 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
Check with AA, I think they made the black plastic outer trim rings. No one makes the clear inner liner.
| mepstein |
Dec 14 2019, 09:38 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,792 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Mark said he is making them this spring.
I feel your pain, I need 26 of them. Most of mine have disintegrated. @Mikey914 |
| Jett |
Dec 14 2019, 11:45 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,699 Joined: 27-July 14 From: Seattle Member No.: 17,686 Region Association: Pacific Northwest
Mark said he is making them this spring. I feel your pain, I need 26 of them. Most of mine have disintegrated. @Mikey914 +1! Mark, can you make them now? I will take four pre-72 and six newer. Can you also make the passenger mirror... I know you can have them made with the right optics but it’s a pain. |
| 914Sixer |
Dec 15 2019, 06:22 AM
I had new glass cut for my mirrors using glare resistant glass. Glass shop used inserts from factory mirrors of some vehicle and was able to make the passenger side is convex.
| 914forme |
Dec 15 2019, 07:35 AM
Times a wastin', get wrenchin'! ![]() ![]() ![]() ![]() Group: Members Posts: 3,899 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None
(IMG:style_emoticons/default/agree.gif) Convex pass side is a dream of mine.
But then you have to drive it to really need it. |
| Mikey914 |
Dec 15 2019, 12:13 PM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,782 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
We are actually making the early and late with retaining rings
| Jett |
Dec 15 2019, 12:25 PM
| mepstein |
Dec 15 2019, 01:23 PM
Hello, my side mirrors are in need of new glass and liners, what holds the glass in place. I know 914 Rubber sells the glass but is there a source for the liners? Is there a technique for removing and reusing the original liners without damage? Thanks in advance. Jack As to technique, I use my fingernail to pull off the black plastic gasket. It's very strong and rarely breaks. don't use a screwdriver, it cracks the edge of the stainless back. Lube all the hardware inside the arm and mirror back. It dries out, corrodes and you bend up the mirror back trying to twist the pivots. A little mothers polish makes them look like new. |
| FlacaProductions |
Dec 15 2019, 01:28 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,245 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California
I just did the same refurb on my mirrors. fingernail to pull the black border off. Luckily, both of my liners were in tact but it was dirty in there. Dismantled all of it, cleaned and re-greased and then put it back together.
I kept my current glass as it's got just a little patina around the edges and it's original, i'm sure. Just waiting for the spring so I can go for a ride and make sure everything is tight enough to prevent vibration/shaking. The movement on the is really nice now, tho. |
| mepstein |
Dec 15 2019, 02:11 PM
Yea, don’t try to turn them if they are stuck. You just damage the stainless housing .
| Mikey914 |
Dec 17 2019, 06:04 PM
Mark said he is making them this spring. I feel your pain, I need 26 of them. Most of mine have disintegrated. @Mikey914 +1! Mark, can you make them now? I will take four pre-72 and six newer. Can you also make the passenger mirror... I know you can have them made with the right optics but it’s a pain. We are actually in the process of doing these. They have been drawn up, and we are starting tooling. It will require some machine time, we have a few other projects scheduled in. We are actively working on over 25 projects as I write this. We do some contract manufacturing as well as what we do here. Unfortunately, it's not as simple as just bumping it up. I can tell you we are 6 months in on these and the tooling will be started in the next 30 days. We typically don't announce projects until they are eminent so you don't have the "wait" time. |
| mepstein |
Dec 17 2019, 06:48 PM
Mark said he is making them this spring. I feel your pain, I need 26 of them. Most of mine have disintegrated. @Mikey914 +1! Mark, can you make them now? I will take four pre-72 and six newer. Can you also make the passenger mirror... I know you can have them made with the right optics but it’s a pain. We are actually in the process of doing these. They have been drawn up, and we are starting tooling. It will require some machine time, we have a few other projects scheduled in. We are actively working on over 25 projects as I write this. We do some contract manufacturing as well as what we do here. Unfortunately, it's not as simple as just bumping it up. I can tell you we are 6 months in on these and the tooling will be started in the next 30 days. We typically don't announce projects until they are eminent so you don't have the "wait" time. (IMG:style_emoticons/default/beerchug.gif) |
| Jett |
Dec 17 2019, 08:15 PM
Thanks Mark, makes sense.
| jack20 |
Dec 18 2019, 12:08 AM
Thanks for all the info and tips. Very much appreciated. I’ll probably wait for Mark to finish but I do want a convex mirror on the passengers side when I do this project.
| euro911 |
Dec 18 2019, 01:36 AM
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,937 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California
Lo-Fi Version | Time is now: 4th July 2026 - 05:55 AM |
