New here and need some help 914/8 Chevy 350 refurbish, Cleaning up and refurbishing 1973 914 - 350 converted car |
Daryl32 |
Jan 14 2020, 02:36 PM
Member Group: Members Posts: 133 Joined: 14-January 20 From: Southern California Member No.: 23,827 Region Association: Southern California |
So just a hello and introduction.
I am Daryl - sorta old and have been working on cars since 1969. Mostly Chevy's and Dodge's - then a 30 years or so I got my first taste of German engineering with a BMW E21 320i we were given as our Dd died on us. So I am here because a friend of a friend needed help with a project. We thought it just needed some carb work and a couple of leaks sorted out. The project have taken on the project of working out some issues with a chevy 350 converted 1973 914, the conversion is most likely 10 plus years old. I believe the kit is a Renegade kit. Some of the issues were it bleeds fluid very where the tranny and engine can. Most of the leaks have been addressed and stopped "I hope". Heads were replaced because both were cracked. New Holley carb will go on with new intake with square bore pattern for more choices in carbs. New electric water pump Lots of bent and rusty parts blasted and powder coated or replaced. Now that all this is done I need to fix the wiring and try to put it all back together. I can find lots of pictures of Chevy v8's from the top seating in the cars, But I could use some good pictures of the bottom of the car. Shiftier issues I need to address. Fuel line placement to carb Thorttel cable placements with carb facing forward. Where did you run your wiring harness to the engine bay? I am sure I will have more questions by the day. May work bench - sorta. |
Daryl32 |
Mar 20 2020, 04:28 PM
The car came with some interior parts that needed install so I have been working on these.
#1 an aftermarket center console. NOTE: it does not fit well at all with the short shift lever and spacer in the car. Made it work as well as possible. #2 an older used under dash pad, it is incorrect one for the dash outer speakers. It comes into the face of dash too much. Again made it / installed anyway. #3 A Cloth glue on dash cover. Personally thinking paint the dash would have looked better in the long run. #4 A set of four older VDO gauges, they needed cleaning and a home. The center console supplied piece for gauges had three large holes 25/8" or so. VDO gauges more like 2". So I made a new piece out of some 3/16" white birch plywood I had. #5 Installed the pedal cover board. I also took apart, cleaned and regressed the shift leveler. Seeing the engine is water cooled and the stock heater-blower is no long working. I made a circuit breaker/switch panel out of 1/6" aluminum to go the heater control position. The circuit breakers are for the fuel pump, electric water pump, Davis Craig controller hot lead and the fan hot to the relay. Easier to see and push then finding the fuse and replacing. |
Lo-Fi Version | Time is now: 26th May 2024 - 11:48 AM |
