Help - 914-6 2.7 External Oil Cooler Options?, What is best option for adding a non-front oil cooler? |
jwinner |
Feb 20 2020, 06:29 PM
Newbie Group: Members Posts: 23 Joined: 5-August 14 From: Milwaukee, WI Member No.: 17,736 Region Association: Upper MidWest |
My 914-6 2.7 runs a little hot (230-240 degrees) so I am looking for advice on adding an external oil cooler. Thinking of adding a Mocal/Setrab external cooler to the underside of the rear trunk, has anybody used this option and if so did it help? Please let me know if you have any other ideas. I am not plumbed for a GT style front cooler which is why I am not pursuing that $$$ option. Thank you, James.
Steve |
Feb 20 2020, 07:08 PM
914 Guru Group: Members Posts: 5,585 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
My 914-6 2.7 runs a little hot (230-240 degrees) so I am looking for advice on adding an external oil cooler. Thinking of adding a Mocal/Setrab external cooler to the underside of the rear trunk, has anybody used this option and if so did it help? Please let me know if you have any other ideas. I am not plumbed for a GT style front cooler which is why I am not pursuing that $$$ option. Thank you, James. From my experience, my 2.7 ran much hotter than my current 3.2. I am a big fan on copying what the factory does so I went down the GT route. Otto's in Venice installed a cooler on a racing trans they built for the previous owner. I have since removed it when I installed my 915 gear box. Here is a picture of how Otto's installed it. Might give you an idea on what is possible. Since you live in a cooler climate it might work for you. I would add a -12 inline temp switch for a fan and mount a SPAL fan on it. |
thelogo |
Feb 20 2020, 08:04 PM
Senior Member Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
Under the truck cooler works well on
My big \4 Big Setrab w fan w\ switch But thats street application One guy here had a rocker panel naca ducked to oil coolers. If your driving your 2.7 more like a track car or cafe racer. Front cooler $$$ will really solve your ... I hope i dont overheat my really ! Expensive engine issue . For good . |
Mark Henry |
Feb 21 2020, 08:30 AM
barefoot |
Feb 21 2020, 11:24 AM
Senior Member Group: Members Posts: 1,273 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
mb911 |
Feb 21 2020, 11:27 AM
914 Guru Group: Members Posts: 6,850 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
James you got this wrong.. GT style will cost you about 3k..
You can do cheap if you stay in the back of the car.. Once you move past the firewall then start adding dollars for hose, fittings, ducting, drilling, cutting, and possibly welding.. If you stay in back you are looking likely at less then 800 in materials.. |
jwinner |
Feb 21 2020, 05:56 PM
James you got this wrong.. GT style will cost you about 3k.. You can do cheap if you stay in the back of the car.. Once you move past the firewall then start adding dollars for hose, fittings, ducting, drilling, cutting, and possibly welding.. If you stay in back you are looking likely at less then 800 in materials.. Not sure how I got it wrong, I said I do not want to do the expensive GT front cooler option. |
mb911 |
Feb 21 2020, 08:40 PM
James you got this wrong.. GT style will cost you about 3k.. You can do cheap if you stay in the back of the car.. Once you move past the firewall then start adding dollars for hose, fittings, ducting, drilling, cutting, and possibly welding.. If you stay in back you are looking likely at less then 800 in materials.. Not sure how I got it wrong, I said I do not want to do the expensive GT front cooler option. Lol I am referring to $$$ signs it should be you don't want to do $$$$ signs . that's what a GT setup costs.. |
jwinner |
Feb 22 2020, 09:48 PM
James you got this wrong.. GT style will cost you about 3k.. You can do cheap if you stay in the back of the car.. Once you move past the firewall then start adding dollars for hose, fittings, ducting, drilling, cutting, and possibly welding.. If you stay in back you are looking likely at less then 800 in materials.. Not sure how I got it wrong, I said I do not want to do the expensive GT front cooler option. Lol I am referring to $$$ signs it should be you don't want to do $$$$ signs . that's what a GT setup costs.. Ah gotcha, my dollar-sign scale must be different than yours lol. Either way it looks like we are heading towards a secondary oil cooler and a fan under the rear trunk. |
barefoot |
Feb 23 2020, 08:34 AM
Here's the best place for low cost cooler.
Lo-Fi Version | Time is now: 14th May 2024 - 10:50 AM |
