Body dolly, Anyone made one |
ThePaintedMan |
Feb 26 2020, 12:41 PM
Anyone made a body dolly for their car? I'm looking to start my drivetrain swap this summer and want to retain the ability to move the shell around in the driveway. Only really worried about dimensions and keeping it balanced, but open to your suggestions, particularly in the area of safety. Here's a pic of something sort of what I was thinking.
Feb 26 2020, 12:47 PM
914-6 GT in waiting Group: Members Posts: 19,258 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Rory made this one.
I'm "storing" it under one of my chassis. Attached image(s) |
ndfrigi |
Feb 26 2020, 12:50 PM
how about just use wheel dolly? I can easily move this project and I was able to pushed it all the way to the corner and fit 3 small cars in a 2 car garage.
ThePaintedMan |
Feb 26 2020, 12:53 PM
Well my thinking was that this would make it easier to test fit and adjust the drivetrain, rather than jacking it up each time until it's complete.
ValcoOscar |
Feb 26 2020, 12:58 PM
Garage Life Group: Members Posts: 2,383 Joined: 19-November 13 From: SoCal Member No.: 16,669 Region Association: Southern California |
injunmort |
Feb 26 2020, 12:59 PM
Senior Member Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States |
summit has a generic dolly about $400.00.
mlindner |
Feb 26 2020, 01:18 PM
Senior Member Group: Members Posts: 1,518 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
mlindner |
Feb 26 2020, 01:33 PM
PaintedMan, regarding safety. The wood really works nice, if your removing front suspension before engine the front will become very light (like a 911). Adding a few hundred pounds of bagged water softener salt or sand to the front trunk will help. Best, Mark
roblav1 |
Feb 26 2020, 02:56 PM
Senior Member Group: Members Posts: 528 Joined: 18-September 12 From: KY Member No.: 14,943 Region Association: MidAtlantic Region |
Here's mine. 3.0 engine is installed.
Oops, wrong pic! Engine not in! Attached thumbnail(s) |
roblav1 |
Feb 26 2020, 03:01 PM
With engine in now.
Olympic 914 |
Feb 26 2020, 06:56 PM
Group: Members Posts: 1,662 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Did this one. Cut groves in the top piece to receive the seam.
Put some eye bolts in to strap it down and was able to winch it in and out of the garage on the cart. |
914forme |
Feb 26 2020, 07:25 PM
I just cut one up made of wooden 4x4s 1x4 as an X brace to keep it square, and some Casters I got off a plywood car Dad had. Don't need it anymore I just use my EZ-Car lift, with the wheel kit.
Do not have a picture of my car on it handy, but here you will get the idea. Some of the best money I ever spent on tools for my shop. I will get a picture once I get it un buried next week. |
mbseto |
Feb 27 2020, 03:44 PM
Senior Member Group: Members Posts: 1,253 Joined: 6-August 14 From: Cincy Member No.: 17,743 Region Association: North East States |
1st post in my build thread has a couple decent dolly pics. Corners are individually detachable because I needed to replace metal in each corner and wanted to have the other three still held stable.
http://www.914world.com/bbs2/index.php?showtopic=262220 |
mlindner |
Feb 28 2020, 06:47 AM
mbseto, best dolly yet. Very nice. Thanks for sharing. mark
mgarrison |
Mar 2 2020, 01:43 PM
Member Group: Members Posts: 351 Joined: 14-February 20 From: Chandler, AZ Member No.: 23,922 Region Association: Southwest Region |
So, silly question but how do you put the body/chassis minus all suspension parts, etc. onto the body dolly?
Are you just using multiple jacks front and rear, or...? Mine is currently sitting on four tall jack stands which I would like to use for rotating truck tires in the near future, so I was gong to build a body dolly so it was a bit more mobile, and a better height for my back! Got sidetracked by the idea of how do I get it onto and then back off the body dolly! Thanks! Mike |
ValcoOscar |
Mar 2 2020, 01:53 PM
So, silly question but how do you put the body/chassis minus all suspension parts, etc. onto the body dolly? Are you just using multiple jacks front and rear, or...? Mine is currently sitting on four tall jack stands which I would like to use for rotating truck tires in the near future, so I was gong to build a body dolly so it was a bit more mobile, and a better height for my back! Got sidetracked by the idea of how do I get it onto and then back off the body dolly! Thanks! Mike In MY case I used my BendPak 2 Post Lift. I helped a member with a forklift once also. Oscar |
Jonathan Livesay |
Mar 2 2020, 01:59 PM
Senior Member Group: Members Posts: 741 Joined: 13-March 10 From: La Canada CA Member No.: 11,461 Region Association: None |
PaintedMan, regarding safety. The wood really works nice, if your removing front suspension before engine the front will become very light (like a 911). Adding a few hundred pounds of bagged water softener salt or sand to the front trunk will help. Best, Mark The old Corvair handling package trick! |
Nacho |
Mar 2 2020, 02:24 PM
Member Group: Members Posts: 219 Joined: 31-December 16 From: So. California Member No.: 20,716 Region Association: None |
mgarrison |
Mar 2 2020, 03:07 PM
Lo-Fi Version | Time is now: 9th May 2024 - 10:47 AM |
