John’s ‘73 Restoration, Light at the end of the tunnel |
Morph914 |
Mar 12 2020, 07:07 PM
Member Group: Members Posts: 435 Joined: 22-August 16 From: St Augustine, FL Member No.: 20,326 Region Association: South East States |
I am more than a couple of years into my restoration of my ‘73 1.7 (now 2.0) but did not want to bore everyone with the same old stuff you have seen before. However, I am very thankful that many members here, take the time to post there work in detail. I have followed Brent’s (bbrock) post and have used many of his examples. In fact, I have adopted his idea of painting the trunks, cabin, underside first and now am doing the exterior panels. However, I do not have the cojones to paint mine myself.
I am getting close to having the car ready for paint. Once I finish this I will get the car back to a roller so I can flatbed to the paint shop. I want to use my old 4 lug Fuchs to sent to the paint shop and not my nice 5 lug Fuchs. This is where I need advice, I sent my 4 lug hubs to PMB to be converted to 5 lug and also purchased the kit. Since I no longer have the 4 lug hubs, what would be the easiest way to accomplish this. I know Ivan purchase a pair of 4 lug hubs, just wanted to make sure I am not missing something easier. Also, I want to know if I can install the stub axles without the axles just to get it to the paint shop. There will be no engine in the car. I want to use these wheels to take to the paint shop And not these Cheers, John |
Morph914 |
Oct 23 2020, 08:14 PM
I received my carmagic switch for the windshield washer pump today. Let’s see how this baby fits.
First order of business is to remove the old valve, enlarge the center hole with a 4 mm drill bit and install the new switch. Like an idiot I forgot to take a picture of the drilled out hole, but you get the idea. Even though I was very careful when drilling, the hole ended up a bit off center so the switch would not fit until I wallowed out the holes a bit. Here is where I could use some help, I have looked at the electrical schematic and not sure how to wire this. I really don’t want to add a relay if possible. Maybe someone who has done this conversion could chime in. Thanks in advance, John Attached image(s) |
Lo-Fi Version | Time is now: 6th May 2024 - 08:33 PM |
