John’s ‘73 Restoration, Light at the end of the tunnel |
Morph914 |
Mar 12 2020, 07:07 PM
Member Group: Members Posts: 435 Joined: 22-August 16 From: St Augustine, FL Member No.: 20,326 Region Association: South East States |
I am more than a couple of years into my restoration of my ‘73 1.7 (now 2.0) but did not want to bore everyone with the same old stuff you have seen before. However, I am very thankful that many members here, take the time to post there work in detail. I have followed Brent’s (bbrock) post and have used many of his examples. In fact, I have adopted his idea of painting the trunks, cabin, underside first and now am doing the exterior panels. However, I do not have the cojones to paint mine myself.
I am getting close to having the car ready for paint. Once I finish this I will get the car back to a roller so I can flatbed to the paint shop. I want to use my old 4 lug Fuchs to sent to the paint shop and not my nice 5 lug Fuchs. This is where I need advice, I sent my 4 lug hubs to PMB to be converted to 5 lug and also purchased the kit. Since I no longer have the 4 lug hubs, what would be the easiest way to accomplish this. I know Ivan purchase a pair of 4 lug hubs, just wanted to make sure I am not missing something easier. Also, I want to know if I can install the stub axles without the axles just to get it to the paint shop. There will be no engine in the car. I want to use these wheels to take to the paint shop And not these Cheers, John |
Morph914 |
Nov 5 2020, 01:26 PM
I discovered this today, after installing the dash and now connecting everything. (IMG:style_emoticons/default/headbang.gif) I will now have to undo much of what I have been working on to fix this problem.
I am not sure which orientation is correct, I think the drivers side is the correct. Notice the side of the metal dash, the drivers side is on the outside and the passenger side is on the inside. (IMG:style_emoticons/default/mad.gif) I guess it could have been worse, I could have been completely done with the dash, steering wheel, etc. |
Gint |
Nov 7 2020, 03:15 PM
Mike Ginter Group: Admin Posts: 16,066 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
I discovered this today, after installing the dash and now connecting everything. (IMG:style_emoticons/default/headbang.gif) I will now have to undo much of what I have been working on to fix this problem. I am not sure which orientation is correct, I think the drivers side is the correct. Notice the side of the metal dash, the drivers side is on the outside and the passenger side is on the inside. (IMG:style_emoticons/default/mad.gif) I guess it could have been worse, I could have been completely done with the dash, steering wheel, etc. That is a very good question. And one I'll need an answer to at some point in the future. I'll give you a (IMG:style_emoticons/default/icon_bump.gif) |
Lo-Fi Version | Time is now: 6th May 2024 - 12:10 PM |
