John’s ‘73 Restoration, Light at the end of the tunnel |
Morph914 |
Mar 12 2020, 07:07 PM
Member Group: Members Posts: 435 Joined: 22-August 16 From: St Augustine, FL Member No.: 20,326 Region Association: South East States |
I am more than a couple of years into my restoration of my ‘73 1.7 (now 2.0) but did not want to bore everyone with the same old stuff you have seen before. However, I am very thankful that many members here, take the time to post there work in detail. I have followed Brent’s (bbrock) post and have used many of his examples. In fact, I have adopted his idea of painting the trunks, cabin, underside first and now am doing the exterior panels. However, I do not have the cojones to paint mine myself.
I am getting close to having the car ready for paint. Once I finish this I will get the car back to a roller so I can flatbed to the paint shop. I want to use my old 4 lug Fuchs to sent to the paint shop and not my nice 5 lug Fuchs. This is where I need advice, I sent my 4 lug hubs to PMB to be converted to 5 lug and also purchased the kit. Since I no longer have the 4 lug hubs, what would be the easiest way to accomplish this. I know Ivan purchase a pair of 4 lug hubs, just wanted to make sure I am not missing something easier. Also, I want to know if I can install the stub axles without the axles just to get it to the paint shop. There will be no engine in the car. I want to use these wheels to take to the paint shop And not these Cheers, John |
Morph914 |
Dec 17 2020, 08:31 PM
So I already have the intermittent relay on my car. I have installed the car magic switch in the column. The new washer pump has been installed under the reservoir, I have grounded the pump and run a wire to from the positive terminal of the pump up to the column, this wire will connect to one of the car magic wires, but I am not sure if the other wire goes to the switched side of the fuse panel or the intermittent relay.
Any help with this would be appreciated. You can see the two blue carmagic wires, one of those will connect to the red wire from the washer pump. Ian am looking for direction on where the other should go. I am trying to get all these little loose ends tied up before dropping the fuel tank in, as it is much harder to work in there with it installed. I am using the braided fuel line under the tank as it is much more flexible. I will probably add enough extra to lift the tank out without having to remove the lines. Also wondering what this hole next to the brake fluid lines is for. I don’t want to install the tank more than once if possible. |
Lo-Fi Version | Time is now: 6th May 2024 - 04:08 PM |
