John’s ‘73 Restoration, Light at the end of the tunnel |
Morph914 |
Mar 12 2020, 07:07 PM
Member Group: Members Posts: 435 Joined: 22-August 16 From: St Augustine, FL Member No.: 20,326 Region Association: South East States |
I am more than a couple of years into my restoration of my ‘73 1.7 (now 2.0) but did not want to bore everyone with the same old stuff you have seen before. However, I am very thankful that many members here, take the time to post there work in detail. I have followed Brent’s (bbrock) post and have used many of his examples. In fact, I have adopted his idea of painting the trunks, cabin, underside first and now am doing the exterior panels. However, I do not have the cojones to paint mine myself.
I am getting close to having the car ready for paint. Once I finish this I will get the car back to a roller so I can flatbed to the paint shop. I want to use my old 4 lug Fuchs to sent to the paint shop and not my nice 5 lug Fuchs. This is where I need advice, I sent my 4 lug hubs to PMB to be converted to 5 lug and also purchased the kit. Since I no longer have the 4 lug hubs, what would be the easiest way to accomplish this. I know Ivan purchase a pair of 4 lug hubs, just wanted to make sure I am not missing something easier. Also, I want to know if I can install the stub axles without the axles just to get it to the paint shop. There will be no engine in the car. I want to use these wheels to take to the paint shop And not these Cheers, John |
Morph914 |
Jan 6 2021, 08:35 PM
After replacing some of the seals on my side shift trans yesterday, I decided today to tackle the small shift rod seal. This little bugger gave me about a 2 hour plus fight. First I tried a seal puller with no luck, too big for this small seal. I tried a small screw driver, a pick, I drilled a small hole in the top of the seal (very carefully) inserted a screw and tried to pull it out, no go. I used my Dremel tool to carefully cut two notches 180 degrees apart, and then inserted a washer into the notches and slid a long punch through the washer and tried to twist it out, no go. Next, I got the torch out and put some heat to it, tried prying again with several different tools, no go. Finally, I put it in the vise with thin wood strips to protect the part, more heat more prying and it finally gave up.
I started by pressing the roll pin out with a small bolt on one side and a socket on the other. This worked perfectly. I was careful not to press the pin all the way out, as these can be a bugger to get back in. After removing the shift rod, the process of removing the old seal began. This is what was left after getting the seal out. Notice that the old one was not rubber coated on the side like the new one. Perhaps this is why it was so difficult to get out. I will install the new seal tomorrow |
Lo-Fi Version | Time is now: 6th May 2024 - 11:31 AM |
