John’s ‘73 Restoration, Light at the end of the tunnel |
Morph914 |
Mar 12 2020, 07:07 PM
Member Group: Members Posts: 435 Joined: 22-August 16 From: St Augustine, FL Member No.: 20,326 Region Association: South East States |
I am more than a couple of years into my restoration of my ‘73 1.7 (now 2.0) but did not want to bore everyone with the same old stuff you have seen before. However, I am very thankful that many members here, take the time to post there work in detail. I have followed Brent’s (bbrock) post and have used many of his examples. In fact, I have adopted his idea of painting the trunks, cabin, underside first and now am doing the exterior panels. However, I do not have the cojones to paint mine myself.
I am getting close to having the car ready for paint. Once I finish this I will get the car back to a roller so I can flatbed to the paint shop. I want to use my old 4 lug Fuchs to sent to the paint shop and not my nice 5 lug Fuchs. This is where I need advice, I sent my 4 lug hubs to PMB to be converted to 5 lug and also purchased the kit. Since I no longer have the 4 lug hubs, what would be the easiest way to accomplish this. I know Ivan purchase a pair of 4 lug hubs, just wanted to make sure I am not missing something easier. Also, I want to know if I can install the stub axles without the axles just to get it to the paint shop. There will be no engine in the car. I want to use these wheels to take to the paint shop And not these Cheers, John |
krazykonrad |
Jan 25 2021, 11:31 AM
Senior Member Group: Members Posts: 1,124 Joined: 21-February 06 From: Canton, GA Member No.: 5,610 |
It looks like you're just a couple of steps ahead of me in the putting it back together process, so your thread is a huge help.
How did you put the new FI injector boots on without ripping or cutting them? Will the small end stretch enough to go over the connector? |
Morph914 |
Jan 25 2021, 01:41 PM
It looks like you're just a couple of steps ahead of me in the putting it back together process, so your thread is a huge help. How did you put the new FI injector boots on without ripping or cutting them? Will the small end stretch enough to go over the connector? You have to remove the wires from the plug, use a paper clip with a flattened end to remove the wires. Slide the new boot on then reconnect the wires. Cheers, John |
Lo-Fi Version | Time is now: 6th May 2024 - 02:49 PM |
