John’s ‘73 Restoration, Light at the end of the tunnel |
Morph914 |
Mar 12 2020, 07:07 PM
Member Group: Members Posts: 435 Joined: 22-August 16 From: St Augustine, FL Member No.: 20,326 Region Association: South East States |
I am more than a couple of years into my restoration of my ‘73 1.7 (now 2.0) but did not want to bore everyone with the same old stuff you have seen before. However, I am very thankful that many members here, take the time to post there work in detail. I have followed Brent’s (bbrock) post and have used many of his examples. In fact, I have adopted his idea of painting the trunks, cabin, underside first and now am doing the exterior panels. However, I do not have the cojones to paint mine myself.
I am getting close to having the car ready for paint. Once I finish this I will get the car back to a roller so I can flatbed to the paint shop. I want to use my old 4 lug Fuchs to sent to the paint shop and not my nice 5 lug Fuchs. This is where I need advice, I sent my 4 lug hubs to PMB to be converted to 5 lug and also purchased the kit. Since I no longer have the 4 lug hubs, what would be the easiest way to accomplish this. I know Ivan purchase a pair of 4 lug hubs, just wanted to make sure I am not missing something easier. Also, I want to know if I can install the stub axles without the axles just to get it to the paint shop. There will be no engine in the car. I want to use these wheels to take to the paint shop And not these Cheers, John |
Morph914 |
Feb 25 2021, 08:05 PM
Time to clean and inspect the seat belt bits and pieces.
Off with the old PRESS sticker And on with the new sticker And now for the retractors The belts seemed pretty dirty, so I decided to give them an overnight bath After soaking and manually agitating the water was black, so I dumped it out and soaked again in water only. The water was only slightly dirty, so I called it good. After this, I hung them up over night to dry. They seem to be working much better now. (IMG:style_emoticons/default/aktion035.gif) |
DC_neun_vierzehn |
Mar 13 2021, 09:44 PM
Member Group: Members Posts: 377 Joined: 16-November 20 From: Delaware Shore Member No.: 24,893 Region Association: MidAtlantic Region |
Time to clean and inspect the seat belt bits and pieces. Off with the old PRESS sticker And on with the new sticker And now for the retractors The belts seemed pretty dirty, so I decided to give them an overnight bath After soaking and manually agitating the water was black, so I dumped it out and soaked again in water only. The water was only slightly dirty, so I called it good. After this, I hung them up over night to dry. They seem to be working much better now. (IMG:style_emoticons/default/aktion035.gif) Nice touch with the new stickers. Where did you get them? And I assume you have to take them apart to remove/replace them? |
Morph914 |
Mar 14 2021, 08:16 AM
Time to clean and inspect the seat belt bits and pieces. Off with the old PRESS sticker And on with the new sticker And now for the retractors The belts seemed pretty dirty, so I decided to give them an overnight bath After soaking and manually agitating the water was black, so I dumped it out and soaked again in water only. The water was only slightly dirty, so I called it good. After this, I hung them up over night to dry. They seem to be working much better now. (IMG:style_emoticons/default/aktion035.gif) Nice touch with the new stickers. Where did you get them? And I assume you have to take them apart to remove/replace them? Yes, you will have to take it apart to get the old sticker off, but this is very easy to do. As far as where I purchased, I don’t remember, they were sitting in a box for a couple of years. Either 914 Rubber, AA or Pelican I would guess has these. |
Lo-Fi Version | Time is now: 6th May 2024 - 09:32 AM |
