| Morph914 |
Mar 12 2020, 07:07 PM
Member ![]() ![]() Group: Members Posts: 435 Joined: 22-August 16 From: St Augustine, FL Member No.: 20,326 Region Association: South East States
I am more than a couple of years into my restoration of my ‘73 1.7 (now 2.0) but did not want to bore everyone with the same old stuff you have seen before. However, I am very thankful that many members here, take the time to post there work in detail. I have followed Brent’s (bbrock) post and have used many of his examples. In fact, I have adopted his idea of painting the trunks, cabin, underside first and now am doing the exterior panels. However, I do not have the cojones to paint mine myself.
I am getting close to having the car ready for paint. Once I finish this I will get the car back to a roller so I can flatbed to the paint shop. I want to use my old 4 lug Fuchs to sent to the paint shop and not my nice 5 lug Fuchs. This is where I need advice, I sent my 4 lug hubs to PMB to be converted to 5 lug and also purchased the kit. Since I no longer have the 4 lug hubs, what would be the easiest way to accomplish this. I know Ivan purchase a pair of 4 lug hubs, just wanted to make sure I am not missing something easier. Also, I want to know if I can install the stub axles without the axles just to get it to the paint shop. There will be no engine in the car. I want to use these wheels to take to the paint shop ![]() And not these Cheers, John |
Morph914 John’s ‘73 Restoration Mar 12 2020, 07:07 PM
mepstein If you haven't installed your five lug setup y... Mar 12 2020, 10:22 PM
billh1963 I agree....don't use those 4 lug Fuchs for pai... Mar 13 2020, 04:17 AM
Morph914 Thank you, maybe some out there has some 4 lug hub... Mar 13 2020, 04:45 AM
Morph914 I guess I will continue the build postings here in... Sep 29 2020, 07:13 AM
porsche914rick :driving: Sep 29 2020, 07:32 AM
JOEPROPER Very nice progress. Inspiration for the reset of ... Sep 29 2020, 07:33 AM
mepstein Looks amazing. :beer2: Sep 29 2020, 07:37 AM
76-914 To locate your thread or comments you've made ... Sep 29 2020, 08:17 AM
Cairo94507 Very nice to see it all coming together. You are ... Sep 29 2020, 08:22 AM
PanelBilly Everything looks so nice at this stage. Assembly i... Sep 29 2020, 10:18 AM
Morph914 Thank you all for your comments.
I just received t... Sep 29 2020, 02:48 PM
mepstein Keep the yoke all the way in. I would drill holes ... Sep 29 2020, 02:54 PM
Morph914
Keep the yoke all the way in. I would drill holes... Sep 29 2020, 04:24 PM
nditiz1 I have the same yoke and that's what I did. A... Sep 29 2020, 05:40 PM
Morph914 Anyone know what the zip tied sleeve/ bushing is?
... Sep 30 2020, 05:29 AM
VaccaRabite
Anyone know what the zip tied sleeve/ bushing is?... Sep 30 2020, 06:05 AM
Morph914
Anyone know what the zip tied sleeve/ bushing is... Sep 30 2020, 09:07 AM
Morph914 Since the weather is fantastic here today, I am wo... Sep 30 2020, 09:18 AM
Morph914 I decided not to use this piece of vinyl due to th... Sep 30 2020, 08:40 PM
Tdskip Keep the updates coming please. Sep 30 2020, 09:50 PM
Morph914 Continuing to work on the dash, I received the 2 w... Oct 4 2020, 03:11 PM
Morph914 These are the rear license plate lights. As you ca... Oct 5 2020, 08:28 PM
Gint Nice work! Oct 6 2020, 06:23 PM
Morph914 She is in! After shedding a few tears due to t... Oct 8 2020, 08:23 AM
iankarr nice to see the rubber bands ;) Oct 8 2020, 08:51 AM
Morph914
Thanks to you a... Oct 8 2020, 06:02 PM
Morph914 I was able to finish with all the ducting today.
Oct 8 2020, 06:06 PM
Morph914 I was able to get the dash top installed today. Iâ... Oct 16 2020, 01:54 PM
turk22 Progress is great, the workmanship looks top notch... Oct 17 2020, 07:55 PM
Mitox Great work; love the attention to detail Oct 17 2020, 08:03 PM
Cairo94507 If you have it apart, I would do the bearing. Mig... Oct 18 2020, 06:10 AM
Jett
If you have it apart, I would do the bearing. Mi... Oct 18 2020, 08:35 AM
Morph914 Thank you all for the kind words of encouragement.... Oct 18 2020, 09:23 AM
Morph914 Today I took apart the steering column
I have o... Oct 20 2020, 06:09 PM
tygaboy John - You're doing a GREAT job on your car... Oct 20 2020, 06:34 PM
Morph914
John - You're doing a GREAT job on your car... Oct 20 2020, 07:37 PM
DRPHIL914
John - You're doing a GREAT job on your car... Oct 21 2020, 06:11 AM
Morph914
[quote name='Morph914' post='2860499' date='Oct 2... Oct 23 2020, 07:31 PM
Morph914 I received my carmagic switch for the windshield w... Oct 23 2020, 08:14 PM
DRPHIL914 :popcorn:
i will be doing this soon as well and j... Oct 24 2020, 11:57 AM
Morph914
:popcorn:
i will be doing this soon as well and ... Oct 25 2020, 05:25 PM
FlacaProductions @Morph914 - are you running that switch straight ... Oct 25 2020, 08:53 AM
Morph914
[b]@[url=http://www.914world.com/bbs2/index.php?s... Oct 25 2020, 05:32 PM
zfisher6164
[quote name='FlacaProductions' post='2861651' dat... Oct 28 2020, 08:42 AM
DRPHIL914
[quote name='FlacaProductions' post='2861651' dat... Dec 2 2020, 10:34 PM
Morph914
[quote name='FlacaProductions' post='2861651' da... Dec 3 2020, 08:33 AM
bbrock
[quote name='DRPHIL914' post='2871534' date='Dec ... Dec 3 2020, 08:43 AM
Morph914 Finally received the upper bearing for the steerin... Nov 1 2020, 08:42 PM
Morph914 I purchased this kit to clean and seal my gas tank... Nov 4 2020, 06:43 PM
djway I don't think that is the proper routing for t... Nov 5 2020, 01:27 AM
Morph914
I don't think that is the proper routing for ... Nov 5 2020, 12:16 PM
Morph914 I discovered this today, after installing the dash... Nov 5 2020, 01:26 PM
Gint I discovered this today, after installing the dash... Nov 7 2020, 03:15 PM
Morph914 Figured it out, it has to go on the outside to tig... Nov 11 2020, 03:58 PM
Morph914 Has anyone had any issues with the 914 Rubber dash... Nov 11 2020, 04:26 PM
bbrock
Has anyone had any issues with the 914 Rubber das... Dec 2 2020, 09:10 PM
Morph914
Has anyone had any issues with the 914 Rubber da... Dec 3 2020, 08:26 AM
Morph914 I am getting ready to install the fuel pump on the... Dec 2 2020, 08:09 PM
Morph914 So I already have the intermittent relay on my car... Dec 17 2020, 08:31 PM
raynekat It's great that we have 914 Rubber.
Unfortunat... Dec 17 2020, 09:39 PM
Morph914
Unfortuna... Dec 18 2020, 11:24 AM
Morph914 Starting to get some tidbits ready for the engine.... Dec 23 2020, 07:22 PM
Morph914 After replacing some of the seals on my side shift... Jan 6 2021, 08:35 PM
Morph914 Time to get the fan shroud cleaned up
Decid... Jan 24 2021, 05:16 PM
Morph914 The pulley after fresh paint
I can’t remem... Jan 24 2021, 05:33 PM
krazykonrad It looks like you're just a couple of steps ah... Jan 25 2021, 11:31 AM
Morph914
It looks like you're just a couple of steps a... Jan 25 2021, 01:41 PM
krazykonrad Your photos make sense now. Thanks for the info. t... Jan 25 2021, 03:23 PM
Morph914 Trying to figure out if I have all my heater parts... Feb 14 2021, 02:13 PM
Morph914 Time to clean and inspect the seat belt bits and p... Feb 25 2021, 08:05 PM
DC_neun_vierzehn
Time to clean and inspect the seat belt bits and ... Mar 13 2021, 09:44 PM
Morph914
Time to clean and inspect the seat belt bits and... Mar 14 2021, 08:16 AM
Morph914 I was making fairly good progress today until my f... Mar 2 2021, 08:36 PM
barefoot Is there any benefit to mounting the coil here ver... Mar 3 2021, 07:11 AM
anderssj
Is there any benefit to mounting the coil here v... Mar 3 2021, 09:50 AM
Morph914
Is there any benefit to mounting the coil here ... Mar 3 2021, 07:45 PM
Morph914 Started on the vinyl last week, the weather has be... Mar 13 2021, 08:02 PM
Morph914 Also worked on installing the vinyl on the floor
... Mar 13 2021, 08:21 PM
bkrantz Looks great! We were in sync on targa vinyl, ... Mar 13 2021, 08:32 PM
930cabman This is great, thanks for posting and sharing all ... Mar 14 2021, 09:12 AM
Morph914
This is great, thanks for posting and sharing all... Mar 15 2021, 11:58 AM
Morph914 I pulled the targa top out to check the condition.... Mar 18 2021, 07:04 PM
Morph914 Time for some window seal replacements. The new se... Mar 22 2021, 10:28 AM
Morph914 Today I’m continuing with the refresh on my targ... Apr 6 2021, 12:32 PM
930cabman +1, looks great, check another item from the list Apr 6 2021, 12:51 PM
Morph914 Time to get the engine off the stand so I can marr... Apr 17 2021, 08:34 PM
bbrock Looking good! You made the right call install... Apr 17 2021, 08:48 PM
Morph914
Looking good! You made the right call instal... Apr 18 2021, 01:39 PM
bbrock
Looking good! You made the right call insta... Apr 18 2021, 02:17 PM
930cabman Looking good, keep the progress reports coming, in... Apr 18 2021, 01:50 PM
930cabman If it was easy, our kids would do it.
Lucky is t... Apr 18 2021, 02:30 PM
Morph914 I’ve been working on the engine last couple of d... Apr 28 2021, 07:18 PM
bbrock Looks like you have the green hose plugged into th... Apr 28 2021, 09:25 PM
Dion Car is looking fantastic! Great work. I apprec... Apr 29 2021, 04:46 AM
Morph914
Car is looking fantastic! Great work. I appre... Apr 29 2021, 10:28 AM
bbrock BTW, where did you get the green vacuum hose? Apr 29 2021, 07:31 AM
Morph914
... Apr 29 2021, 10:21 AM
Root_Werks Looks clean and detailed, nice! Apr 29 2021, 10:43 AM
930cabman Lookin good and thanks for posting your progress. ... Apr 29 2021, 12:05 PM![]() ![]() |
Lo-Fi Version | Time is now: 4th November 2026 - 03:13 PM |
