> John’s ‘73 Restoration, Light at the end of the tunnel
Morph914
post Mar 12 2020, 07:07 PM
Post #21
I am more than a couple of years into my restoration of my ‘73 1.7 (now 2.0) but did not want to bore everyone with the same old stuff you have seen before. However, I am very thankful that many members here, take the time to post there work in detail. I have followed Brent’s (bbrock) post and have used many of his examples. In fact, I have adopted his idea of painting the trunks, cabin, underside first and now am doing the exterior panels. However, I do not have the cojones to paint mine myself.
I am getting close to having the car ready for paint. Once I finish this I will get the car back to a roller so I can flatbed to the paint shop. I want to use my old 4 lug Fuchs to sent to the paint shop and not my nice 5 lug Fuchs.
This is where I need advice, I sent my 4 lug hubs to PMB to be converted to 5 lug and also purchased the kit. Since I no longer have the 4 lug hubs, what would be the easiest way to accomplish this. I know Ivan purchase a pair of 4 lug hubs, just wanted to make sure I am not missing something easier.
Also, I want to know if I can install the stub axles without the axles just to get it to the paint shop. There will be no engine in the car.Attached Image
I want to use these wheels to take to the paint shopAttached Image
And not these
Cheers,
John
Morph914   John’s ‘73 Restoration   Mar 12 2020, 07:07 PM
mepstein   If you haven't installed your five lug setup y...   Mar 12 2020, 10:22 PM
billh1963   I agree....don't use those 4 lug Fuchs for pai...   Mar 13 2020, 04:17 AM
Morph914   Thank you, maybe some out there has some 4 lug hub...   Mar 13 2020, 04:45 AM
Morph914   I guess I will continue the build postings here in...   Sep 29 2020, 07:13 AM
porsche914rick   :driving:   Sep 29 2020, 07:32 AM
JOEPROPER   Very nice progress. Inspiration for the reset of ...   Sep 29 2020, 07:33 AM
mepstein   Looks amazing. :beer2:   Sep 29 2020, 07:37 AM
76-914   To locate your thread or comments you've made ...   Sep 29 2020, 08:17 AM
Cairo94507   Very nice to see it all coming together. You are ...   Sep 29 2020, 08:22 AM
PanelBilly   Everything looks so nice at this stage. Assembly i...   Sep 29 2020, 10:18 AM
Morph914   Thank you all for your comments. I just received t...   Sep 29 2020, 02:48 PM
mepstein   Keep the yoke all the way in. I would drill holes ...   Sep 29 2020, 02:54 PM
Morph914   Keep the yoke all the way in. I would drill holes...   Sep 29 2020, 04:24 PM
nditiz1   I have the same yoke and that's what I did. A...   Sep 29 2020, 05:40 PM
Morph914   Anyone know what the zip tied sleeve/ bushing is? ...   Sep 30 2020, 05:29 AM
VaccaRabite   Anyone know what the zip tied sleeve/ bushing is?...   Sep 30 2020, 06:05 AM
Morph914   Anyone know what the zip tied sleeve/ bushing is...   Sep 30 2020, 09:07 AM
Morph914   Since the weather is fantastic here today, I am wo...   Sep 30 2020, 09:18 AM
Morph914   I decided not to use this piece of vinyl due to th...   Sep 30 2020, 08:40 PM
Tdskip   Keep the updates coming please.   Sep 30 2020, 09:50 PM
Morph914   Continuing to work on the dash, I received the 2 w...   Oct 4 2020, 03:11 PM
Morph914   These are the rear license plate lights. As you ca...   Oct 5 2020, 08:28 PM
Gint   Nice work!   Oct 6 2020, 06:23 PM
Morph914   She is in! After shedding a few tears due to t...   Oct 8 2020, 08:23 AM
iankarr   nice to see the rubber bands ;)   Oct 8 2020, 08:51 AM
Morph914   nice to see the rubber bands ;) Thanks to you a...   Oct 8 2020, 06:02 PM
Morph914   I was able to finish with all the ducting today.   Oct 8 2020, 06:06 PM
Morph914   I was able to get the dash top installed today. Iâ...   Oct 16 2020, 01:54 PM
turk22   Progress is great, the workmanship looks top notch...   Oct 17 2020, 07:55 PM
Mitox   Great work; love the attention to detail   Oct 17 2020, 08:03 PM
Cairo94507   If you have it apart, I would do the bearing. Mig...   Oct 18 2020, 06:10 AM
Jett   If you have it apart, I would do the bearing. Mi...   Oct 18 2020, 08:35 AM
Morph914   Thank you all for the kind words of encouragement....   Oct 18 2020, 09:23 AM
Morph914   Today I took apart the steering column I have o...   Oct 20 2020, 06:09 PM
tygaboy   John - You're doing a GREAT job on your car...   Oct 20 2020, 06:34 PM
Morph914   John - You're doing a GREAT job on your car...   Oct 20 2020, 07:37 PM
DRPHIL914   John - You're doing a GREAT job on your car...   Oct 21 2020, 06:11 AM
Morph914   [quote name='Morph914' post='2860499' date='Oct 2...   Oct 23 2020, 07:31 PM
Morph914   I received my carmagic switch for the windshield w...   Oct 23 2020, 08:14 PM
DRPHIL914   :popcorn: i will be doing this soon as well and j...   Oct 24 2020, 11:57 AM
Morph914   :popcorn: i will be doing this soon as well and ...   Oct 25 2020, 05:25 PM
FlacaProductions   @Morph914 - are you running that switch straight ...   Oct 25 2020, 08:53 AM
Morph914   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Oct 25 2020, 05:32 PM
zfisher6164   [quote name='FlacaProductions' post='2861651' dat...   Oct 28 2020, 08:42 AM
DRPHIL914   [quote name='FlacaProductions' post='2861651' dat...   Dec 2 2020, 10:34 PM
Morph914   [quote name='FlacaProductions' post='2861651' da...   Dec 3 2020, 08:33 AM
bbrock   [quote name='DRPHIL914' post='2871534' date='Dec ...   Dec 3 2020, 08:43 AM
Morph914   Finally received the upper bearing for the steerin...   Nov 1 2020, 08:42 PM
Morph914   I purchased this kit to clean and seal my gas tank...   Nov 4 2020, 06:43 PM
djway   I don't think that is the proper routing for t...   Nov 5 2020, 01:27 AM
Morph914   I don't think that is the proper routing for ...   Nov 5 2020, 12:16 PM
Morph914   I discovered this today, after installing the dash...   Nov 5 2020, 01:26 PM
Gint   I discovered this today, after installing the dash...   Nov 7 2020, 03:15 PM
Morph914   Figured it out, it has to go on the outside to tig...   Nov 11 2020, 03:58 PM
Morph914   Has anyone had any issues with the 914 Rubber dash...   Nov 11 2020, 04:26 PM
bbrock   Has anyone had any issues with the 914 Rubber das...   Dec 2 2020, 09:10 PM
Morph914   Has anyone had any issues with the 914 Rubber da...   Dec 3 2020, 08:26 AM
Morph914   I am getting ready to install the fuel pump on the...   Dec 2 2020, 08:09 PM
Morph914   So I already have the intermittent relay on my car...   Dec 17 2020, 08:31 PM
raynekat   It's great that we have 914 Rubber. Unfortunat...   Dec 17 2020, 09:39 PM
Morph914   It's great that we have 914 Rubber. Unfortuna...   Dec 18 2020, 11:24 AM
Morph914   Starting to get some tidbits ready for the engine....   Dec 23 2020, 07:22 PM
Morph914   After replacing some of the seals on my side shift...   Jan 6 2021, 08:35 PM
Morph914   Time to get the fan shroud cleaned up Decid...   Jan 24 2021, 05:16 PM
Morph914   The pulley after fresh paint I can’t remem...   Jan 24 2021, 05:33 PM
krazykonrad   It looks like you're just a couple of steps ah...   Jan 25 2021, 11:31 AM
Morph914   It looks like you're just a couple of steps a...   Jan 25 2021, 01:41 PM
krazykonrad   Your photos make sense now. Thanks for the info. t...   Jan 25 2021, 03:23 PM
Morph914   Trying to figure out if I have all my heater parts...   Feb 14 2021, 02:13 PM
Morph914   Time to clean and inspect the seat belt bits and p...   Feb 25 2021, 08:05 PM
DC_neun_vierzehn   Time to clean and inspect the seat belt bits and ...   Mar 13 2021, 09:44 PM
Morph914   Time to clean and inspect the seat belt bits and...   Mar 14 2021, 08:16 AM
Morph914   I was making fairly good progress today until my f...   Mar 2 2021, 08:36 PM
barefoot   Is there any benefit to mounting the coil here ver...   Mar 3 2021, 07:11 AM
anderssj   Is there any benefit to mounting the coil here v...   Mar 3 2021, 09:50 AM
Morph914   Is there any benefit to mounting the coil here ...   Mar 3 2021, 07:45 PM
Morph914   Started on the vinyl last week, the weather has be...   Mar 13 2021, 08:02 PM
Morph914   Also worked on installing the vinyl on the floor ...   Mar 13 2021, 08:21 PM
bkrantz   Looks great! We were in sync on targa vinyl, ...   Mar 13 2021, 08:32 PM
930cabman   This is great, thanks for posting and sharing all ...   Mar 14 2021, 09:12 AM
Morph914   This is great, thanks for posting and sharing all...   Mar 15 2021, 11:58 AM
Morph914   I pulled the targa top out to check the condition....   Mar 18 2021, 07:04 PM
Morph914   Time for some window seal replacements. The new se...   Mar 22 2021, 10:28 AM
Morph914   Today I’m continuing with the refresh on my targ...   Apr 6 2021, 12:32 PM
930cabman   +1, looks great, check another item from the list   Apr 6 2021, 12:51 PM
Morph914   Time to get the engine off the stand so I can marr...   Apr 17 2021, 08:34 PM
bbrock   Looking good! You made the right call install...   Apr 17 2021, 08:48 PM
Morph914   Looking good! You made the right call instal...   Apr 18 2021, 01:39 PM
bbrock   Looking good! You made the right call insta...   Apr 18 2021, 02:17 PM
930cabman   Looking good, keep the progress reports coming, in...   Apr 18 2021, 01:50 PM
930cabman   If it was easy, our kids would do it. Lucky is t...   Apr 18 2021, 02:30 PM
Morph914   I’ve been working on the engine last couple of d...   Apr 28 2021, 07:18 PM
bbrock   Looks like you have the green hose plugged into th...   Apr 28 2021, 09:25 PM
Dion   Car is looking fantastic! Great work. I apprec...   Apr 29 2021, 04:46 AM
Morph914   Car is looking fantastic! Great work. I appre...   Apr 29 2021, 10:28 AM
bbrock   BTW, where did you get the green vacuum hose?   Apr 29 2021, 07:31 AM
Morph914   BTW, where did you get the green vacuum hose? ...   Apr 29 2021, 10:21 AM
Root_Werks   Looks clean and detailed, nice!   Apr 29 2021, 10:43 AM
930cabman   Lookin good and thanks for posting your progress. ...   Apr 29 2021, 12:05 PM
- Lo-Fi Version Time is now: 4th November 2026 - 03:12 PM
