Freshening up an older 914-6 conversion:, Making a 914-6 Conversion your own |
Root_Werks |
Mar 25 2020, 11:22 AM
Village Idiot Group: Members Posts: 8,319 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Michelle and I picked up our new to us 914-6 over the weekend. We practiced social distancing and kept safe. Two days home, 920 miles, the 914 never missed a beat.
Here's a picture at a rest stop about 30% of the way home. Attached thumbnail(s) |
Root_Werks |
Mar 25 2020, 11:26 AM
The engine is a 2.7 with CIS, Aluminum case, 993 cam towers and cams with hydro lifters. Seat of the pants has me thinking around 180hp.
The paint sucks. BUT, I don't care, it's a solid 914 with about 3 Mayco paint jobs slathered over the original Anacona Blue. I originally thought I wouldn't repaint for a year or so, but that I won't make it that long. This thing needs to be stripped and painted correctly. From the Sellers original Ad: The one of a kind engine is built as a tribute to the Porsche air cooled engine design with components and improvements considered the best over the 30+ year history of the 911 engine design evolutions. Engine approximately 5000 miles on rebuild - 1968 early sand cast case (#3380133) bored for 2.7, oil bypass modification, oil squirters added. Work done by Ollies - Original 911S 8.5:1 CIS pistons and Nikasil cylinders. - 74 911S heads with 46/40 valves rebuilt by Ted Robinson at German Precision. - 94 993 cams with keyway, 993 cam towers, 993 valve covers and 993 hydraulic lifters. - Hydraulic chain tensioners. - 911SC aluminum 4 rib oil pump 911-107-008-05 - Original 74 911S CIS fuel injection. - Genuine 914-6 oil tank. Exhaust 993 heat exchangers into dual inlet stock muffler Wheels Genuine Fuchs alloys, rear are deep sixes Brakes and suspension - Front 911S front struts, calipers and rotors with 3.5" caliper mounting - Rear 911S calipers and rotors with drum-in-hat parking brake - 180lb rear springs MSD electronic ignition and distributor module. Body in original condition except for paint. Original paint was L97B Anacona Blue Metallic. No rust. Owned since 1987 |
Lo-Fi Version | Time is now: 15th May 2024 - 12:35 AM |
