Freshening up an older 914-6 conversion:, Making a 914-6 Conversion your own |
Root_Werks |
Mar 25 2020, 11:22 AM
Village Idiot Group: Members Posts: 8,319 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Michelle and I picked up our new to us 914-6 over the weekend. We practiced social distancing and kept safe. Two days home, 920 miles, the 914 never missed a beat.
Here's a picture at a rest stop about 30% of the way home. Attached thumbnail(s) |
nditiz1 |
Jun 10 2021, 05:29 AM
Senior Member Group: Members Posts: 1,188 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
Can you provide more pics of your regulator relocation and PMB lines?
I am now on my second set of PMB lines. They sent me a plug and T fitting to use with the early style location. The center line they provided is not long enough to get to the new location unless I add another coupler to the line coming out of the firewall. Looks like you mounted yours vertically and have no T fitting. |
Root_Werks |
Jun 10 2021, 08:46 AM
Can you provide more pics of your regulator relocation and PMB lines? I am now on my second set of PMB lines. They sent me a plug and T fitting to use with the early style location. The center line they provided is not long enough to get to the new location unless I add another coupler to the line coming out of the firewall. Looks like you mounted yours vertically and have no T fitting. PMB sent me an early "kit" which had all hard lines. I wound up using a line that was probably intended for something else. I started by installing the L & R caliper hardlines. Figured they would determine where the regulator would sit. Then I sorted through the remaining hard lines until I found one that was long enough to bend to meet the mounted regulator. It was a PITA pulling whatever line I used in and out of the tunnel making small bends until it fit nicely. Also had to rotate the mounting bracket on the regulator 180. Wound up making a little jig from wood, putting the regulator in a vise so I wouldn't have to worry about breaking a good seal on the halves. |
Lo-Fi Version | Time is now: 15th May 2024 - 06:12 PM |
