FS Heater J Tube block off plates for cars with out heat, Set of two plates with hardware - $27.50 per set shipped |
bdstone914 |
Apr 1 2020, 11:34 AM
bdstone914 Group: Members Posts: 4,522 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Edit, Have ten more sets available.
I have seen many cars that deleted all of the heater parts and left the J tube holes in the tins open where the fan can suck hot air in. I made these to cover the holes and look better than a paint cap stuffed in the hole. I can supply them bare if you want to paint to a special tin color. Had them made from .047" mild steel. Bent the tuck tabs by hand. Each set consists of two plates , 6mm socket head screws. washers and nuts. Price is $27.50 per set shipped. PMs will be sent to those who replied to this thread. Attached thumbnail(s) |
JeffBowlsby |
Apr 1 2020, 04:13 PM
914 Wiring Harnesses Group: Members Posts: 8,510 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
I think a better solution is something like this. These could be powder coated or maybe could even be found already black. Even some plastics could be acceptable - the factory J-tube delete cap on the passenger side is a polyethylene plastic.
Attached image(s) |
bdstone914 |
Apr 1 2020, 08:49 PM
@JeffBowlsby
I think a better solution is something like this. These could be powder coated or maybe could even be found already black. Even some plastics could be acceptable - the factory J-tube delete cap on the passenger side is a polyethylene plastic. [/quote Good idea but I do not find that type of metal cap plug available in sizes over 2". Larger plastic plugs are available but the only ones I found were bright green. Also the clearance to the vertical wall on the cylinder tin is only 3mm so the head may hit. One issue I see is that most tins are bent up and the plate may not sit flat. |
Lo-Fi Version | Time is now: 18th May 2024 - 08:57 PM |
