AAR hose setup, new hose installation |
MLinde |
Apr 13 2020, 09:22 PM
Newbie Group: Members Posts: 11 Joined: 31-March 20 From: Boyertown, PA Member No.: 24,084 Region Association: MidAtlantic Region |
Hi, I acquired my '73 1.7L a few weeks ago and now have a high idle (3000RPM). Since many of the hoses appeared to be cracking, I decided that would be the best place to start. I've now begun to swap them out from a kit and am not finding the most comprehensive diagram that matches with the configuration as setup when I obtained the vehicle. Seems that there are a couple of ways to hook up the AAR based on diagrams I have found.
1.) connect with one hose to the plenum and other to air intake hose (elbow). 2.) my current setup--with both connectors split where the two additional connection are to two ports on the deceleration valve. Am I correct in my interpretation, and if so, are there reasons to hook up one way or the other? Thanks! Mike |
BeatNavy |
Apr 14 2020, 05:39 AM
Good idea to replace vacuum lines if they are in poor shape. Here's a pic of an early 1.7L Unfortunately I'm not aware of a late model 1.7L diagram out there, and things do change year-to-year, even among same engine setups. Your current setup is incorrect. It shouldn't connect to decel valve. It should be one port to manifold, one to air intake (it matters which port to which). The decel valve should have two ports connected to manifold vacuum and one to the air box (also matters which ports). Here's the early 1.7L setup in general: (IMG:http://www.914world.com/bbs2/uploads_offsite/bowlsby.net-17042-1586864377.1.jpg) Here's 2.0 setup that shows decel valve (because the early 1.7L didn't have it and it's not in diagram above). I'm just providing this pic for decel valve routing. You need to hookup your decel valve similarly - 2 ports on the ends to manifold vacuum and the one on the side to air box. (IMG:http://www.914world.com/bbs2/uploads_offsite/bowlsby.net-17042-1586864377.2.jpg) There are three basic types of vacuum: ambient (which means basically attached to air cleaner), manifold (past or below throttle body), and ported (on throttle body above throttle plate). Doesn't really matter where something is connected as long as it's getting the right "type" of vacuum. |
MLinde |
Apr 14 2020, 06:19 AM
Thanks very much, Rob! I think this will help. I'll keep you posted. Other than the high idle, the car seems to run well...
BeatNavy |
Apr 14 2020, 07:28 AM
(IMG:style_emoticons/default/beerchug.gif) Good luck.
Not sure how far you are from "East Stroudsburg," but we are TRYING (covid permitting) to get a summer gathering of East Coast teeners there in July. Here's the thread: http://www.914world.com/bbs2/index.php?showtopic=343706 rc |
MLinde |
Apr 14 2020, 07:39 AM
I'm southwest of Quakertown (Allentown area), so E. Stroudsburg would be doable. Hopefully by July it would be in good enough shape to make the trip to East Stroudsburg. I'd also like to replace the seatbelts. A good cleaning didn't help with retraction issue. Having fun learning something new everyday.
euro911 |
Apr 14 2020, 07:48 AM
I think there's a thread on how to disassemble and tighten up the springs in the retractor mechanism somewhere in the forum - you might try searching for it. Also, IIRC, there's a member here that refurbishes them ... Jeffery ( @914_7T3 ) recently has his belts & retractors refurbished by the gentleman - maybe he'll chime in on the matter (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/popcorn[1].gif) |
BeatNavy |
Apr 14 2020, 07:49 AM
Having fun learning something new everyday. That is the RIGHT attitude with these cars, because they give you plenty of opportunities (IMG:style_emoticons/default/smile.gif) |
StarBear |
Apr 14 2020, 08:32 AM
Senior Member Group: Members Posts: 1,886 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
Having fun learning something new everyday. That is the RIGHT attitude with these cars, because they give you plenty of opportunities (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/agree.gif) ABSOLUTELY! |
914_7T3 |
Apr 14 2020, 12:12 PM
Please forgive me, I'm new to all of this! Group: Members Posts: 1,853 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California |
(IMG:style_emoticons/default/welcome.png) I think there's a thread on how to disassemble and tighten up the springs in the retractor mechanism somewhere in the forum - you might try searching for it. Also, IIRC, there's a member here that refurbishes them ... Jeffery ( @914_7T3 ) recently has his belts & retractors refurbished by the gentleman - maybe he'll chime in on the matter (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/popcorn[1].gif) Please refer to post #7 & #29 from @flacaproductions in the below thread for tips on how to tighten the retractors. http://www.914world.com/bbs2/index.php?showtopic=341695 (IMG:style_emoticons/default/beerchug.gif) |
MLinde |
Apr 14 2020, 01:03 PM
Thanks, All!!!
Lo-Fi Version | Time is now: 18th May 2024 - 11:34 AM |
