splitting the case before i split my head, any tricks for dissolving RTV? |
iankarr |
May 15 2020, 07:48 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,473 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Hi guys,
The hits keep on coming with this bumblebee engine. Seems the "builder" slathered the sealing surfaces of the case with black (or maybe gray) RTV and I can't figure out how to break its grip. All the bolts are out (yes, the hidden one too), but the sides won't budge. Even with a spreader under tension for a few hours. I only wish I didn't have to get this case decked...I'm sure it wouldn't leak (IMG:style_emoticons/default/wink.gif) Any ideas / tips / tricks? |
914werke |
May 15 2020, 09:35 PM
"I got blisters on me fingers" Group: Members Posts: 10,059 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
By spreader do you mean the little spit tool that mounts in the Oil pump opening?
Bartlett 914 |
May 15 2020, 09:42 PM
Hi guys, The hits keep on coming with this bumblebee engine. Seems the "builder" slathered the sealing surfaces of the case with black (or maybe gray) RTV and I can't figure out how to break its grip. All the bolts are out (yes, the hidden one too), but the sides won't budge. Even with a spreader under tension for a few hours. I only wish I didn't have to get this case decked...I'm sure it wouldn't leak (IMG:style_emoticons/default/wink.gif) Any ideas / tips / tricks? Often it is a nut or screw you have missed. Be certain you have them all before using force |
iankarr |
May 15 2020, 10:00 PM
By spreader do you mean the little spit tool that mounts in the Oil pump opening? No...just a hand/squeeze clamp/spreader. Not a lot of force, either. Just a consistent push to hopefully pull the RTV apart. I double checked all the bolts against @mcmark ‘s diagram http://www.914world.com/bbs2/index.php?showtopic=50873 and all 20 plus the big ones are out. Looks like the RTV is acting like glue. Oy. |
Superhawk996 |
May 16 2020, 08:44 AM
914 Guru Group: Members Posts: 5,819 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
By spreader do you mean the little spit tool that mounts in the Oil pump opening? No...just a hand/squeeze clamp/spreader. Not a lot of force, either. Just a consistent push to hopefully pull the RTV apart. I double checked all the bolts against @mcmark ‘s diagram http://www.914world.com/bbs2/index.php?showtopic=50873 and all 20 plus the big ones are out. Looks like the RTV is acting like glue. Oy. As always, if you're sure you have all case fasteners removed, a little heat is your friend. You may have some galvanic corrosion around a stud or two. Penetrating fluid 1st. Then I'd pick the side of the case with more holes than studs and then only heat only that one side to enourage a little thermal espansion of the holes on that side and softening of the RTV as the heat attempts to cross though the RTV on its way to the cold side case 1/2. We need an emoji without the helmet. Just a big flame from the fire wrench! (IMG:style_emoticons/default/welder.gif) |
JeffBowlsby |
May 16 2020, 09:40 AM
914 Wiring Harnesses Group: Members Posts: 8,505 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Google says to try soaking cured silicone:
Vinegar, iso alcohol, Goo Gone, lacquer thinner, acetone. |
iankarr |
May 16 2020, 10:42 AM
Thanks guys. Any downside to soaking the case in those? Discoloration? Weakening?
PlaysWithCars |
May 16 2020, 11:05 AM
Senior Member Group: Members Posts: 524 Joined: 9-November 03 From: Southeast of Seattle Member No.: 1,323 Region Association: Pacific Northwest |
Vinegar is acidic so there might be an undesirable reaction tot it, but the others shouldn't cause issues. Just be careful. You're going to end up with a lot of flammable liquid and fumes from the others.
bdstone914 |
May 16 2020, 11:23 AM
bdstone914 Group: Members Posts: 4,521 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@cuddy_k
' date='May 15 2020, 06:48 PM' post='2815652'] Hi guys, The hits keep on coming with this bumblebee engine. Seems the "builder" slathered the sealing surfaces of the case with black (or maybe gray) RTV and I can't figure out how to break its grip. All the bolts are out (yes, the hidden one too), but the sides won't budge. Even with a spreader under tension for a few hours. I only wish I didn't have to get this case decked...I'm sure it wouldn't leak (IMG:style_emoticons/default/wink.gif) Any ideas / tips / tricks? [/quote] Get one of the oil pump spreaders. In addition to that i have used a scissors jack between the lower case to trans studs. |
sixnotfour |
May 16 2020, 11:42 AM
914 Wizard Group: Members Posts: 10,430 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Just helped a shop get a 911 apart...they had left pressure with a splitter, no go,,,
some all torch heat and it popped.. It didnt leak, but sure needed a rebuild.. |
914e |
May 16 2020, 02:55 PM
Member Group: Members Posts: 496 Joined: 21-February 20 From: Arizona Member No.: 23,951 Region Association: Southwest Region |
I have used air pressure to remove chill plates from inverters. I don't know how you could seal a case well enough to do that though.
Maybe something like this https://www.homedepot.com/p/Calculated-Indu..._-206697086-_-N |
May 16 2020, 05:36 PM
iankarr |
May 16 2020, 05:51 PM
Thanks guys. Will hit this from all fronts. The oil pump spreader (which looks like a fun tool btw) will be here next week. I'll report back...
Mark Henry |
May 17 2020, 11:38 AM
Also make sure all the wavy washers have been removed, they hang up on the threads.
76-914 |
May 17 2020, 01:29 PM
I can't wait to see what went on inside. I'll stay tuned for the next hit. (IMG:style_emoticons/default/happy11.gif)
Larmo63 |
May 17 2020, 01:39 PM
Forrest hammered and hammered on his 3.0 aluminum case before he found that last hidden bolt inside on the transmission side.
(IMG:style_emoticons/default/smash.gif) |
iankarr |
May 17 2020, 02:36 PM
Got it!
Ended up using Jake Raby's method from his DVD of just a little leverage between the fan hub and front seal. No direct prybar contact with the case. It cracked open enough for me to shoot WD40 in there and gently drive some wood wedges in to keep it apart. A little finessing and it came apart. Well, once I removed the bale for the oil tower, which got hung up. doh! Pics coming... |
Superhawk996 |
May 17 2020, 02:42 PM
Got it! Ended up using Jake Raby's method from his DVD of just a little leverage between the fan hub and front seal. No direct prybar contact with the case. It cracked open enough for me to shoot WD40 in there and gently drive some wood wedges in to keep it apart. A little finessing and it came apart. Well, once I removed the bale for the oil tower, which got hung up. doh! Pics coming... (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beer3.gif) |
Mark Henry |
May 17 2020, 07:41 PM
Diesel stinks but it softens up RTV enough that it comes off somewhat easy with a brass wire brush.
Lo-Fi Version | Time is now: 15th May 2024 - 08:59 PM |
