Mallory parts search |
colingreene |
Jun 2 2020, 09:49 AM
Senior Member Group: Members Posts: 729 Joined: 17-October 13 From: Southern California Member No.: 16,526 Region Association: Southern California |
Everyone knows mallory was bought by MSD at this point.
I have a Mallory Distributor that I suspect may need points. I dont have a ton of interest in converting it to something else at this time. Aircooled.net was 0 help in helping me find parts for it. Does anyone have a set of points for it or know of where to get one or even better something widely available but would work? The distributor number that I have is a Mallory 2354109 its a single point distributor. |
Mark Henry |
Jun 2 2020, 10:05 AM
I convert them to pertronix, you would have to look at the pertronix site but they have a kit for mallory. The other option is I beleive aircooled.net sells the unilight module.
The points are generic to mallory so try summit, speed shops, etc. |
914043 |
Jun 2 2020, 10:07 AM
Member Group: Members Posts: 87 Joined: 2-April 19 From: California Member No.: 23,007 Region Association: Central California |
Everyone knows mallory was bought by MSD at this point. I have a Mallory Distributor that I suspect may need points. I dont have a ton of interest in converting it to something else at this time. Aircooled.net was 0 help in helping me find parts for it. Does anyone have a set of points for it or know of where to get one or even better something widely available but would work? The distributor number that I have is a Mallory 2354109 its a single point distributor. try speedwaymotors.com seem to have what you may need. |
maf914 |
Jun 2 2020, 02:50 PM
Summit and Jegs still have some Mallory products.
I don't know if these are what you need. https://www.summitracing.com/parts/maa-2504...xRoCI0YQAvD_BwE https://www.summitracing.com/parts/maa-2504...xRoCI0YQAvD_BwE |
914Sixer |
Jun 2 2020, 03:55 PM
914 Guru Group: Members Posts: 8,886 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Try over on theSamba.com
colingreene |
Jun 4 2020, 09:01 AM
Thanks guys Ill check out the link. I have 0 interest in putting a Pertronix in my distributor as I had nothing but problems on my old distributor.
StarBear |
Jun 4 2020, 09:59 AM
Senior Member Group: Members Posts: 1,887 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
Thanks guys Ill check out the link. I have 0 interest in putting a Pertronix in my distributor as I had nothing but problems on my old distributor. Yeah, me too. Unknown why they work perfectly in some cars and horribly in others. Had one in but took it out. Others with same 1.8L engine work fine. |
colingreene |
Jun 5 2020, 05:09 PM
But before i get buck wild i borrowed a distributor from a friend that was known good and will be putting it in my car to see if this could be the source of my problems.
Optimusglen |
Jun 6 2020, 03:53 AM
Senior Member Group: Members Posts: 909 Joined: 26-February 16 From: Minneapolis Member No.: 19,709 Region Association: Upper MidWest |
Hope you can figure it out!
colingreene |
Jun 24 2020, 01:01 PM
Distributor is the problem.
Replaced the Condenser, and now it wont run. Replaced also the points re gapped it still wont run. turned the car over with the key and you can see small sparks indicating that the points are seeing voltage, as is the coil. also used a test light to see if the points are opening and closing as needed. The light stays on and momentarily shuts off as the points open sort of baffled at this point what I am doing wrong. Turns out for my distributor the points part number is 25042 and the condenser is 400 |
colingreene |
Aug 4 2020, 10:22 PM
Replaced parts, Re timed. Car ran well for about 15 miles, after that its been getting progressively worse with no apparent reason.
I had taken it to a local shop because I was out of time and tools to have them look at it, they checked it out replaced the points and condenser and re timed it but its still developing the same symptoms, im pretty frustrated at this point. I dont have a ton of money to throw at it at this point as i am building its replacement right now. 2.8L 10.5:1 compression twin plug and DC60 cams. |
stinkindiesel |
Aug 5 2020, 03:21 PM
Member Group: Members Posts: 184 Joined: 14-June 13 From: Georgetown, TX Member No.: 16,012 Region Association: Southwest Region |
I dont have a ton of money to throw at it at this point as i am building its replacement right now. 2.8L 10.5:1 compression twin plug and DC60 cams. You didn't by any chance happen to mention the "replacement" in front of the car did you? These cars are like girlfriends. Never mention replacement in their presence. Bad mojo. Gary |
914sgofast2 |
Aug 5 2020, 03:33 PM
Senior Member Group: Members Posts: 617 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
Could be the electrical section in your ignition switch is going bad.
colingreene |
Aug 16 2020, 03:19 PM
I bypassed the switch by going from the battery direct to the coil.
Mark Henry |
Aug 16 2020, 05:09 PM
Did that help?
QUOTE Car ran well for about 15 miles, after that its been getting progressively worse with no apparent reason. That sounds like you have an incompatible coil and it's burning down the points rub block. I've run into this a few times with Bosch dizzy's and the owner installed a generic coil. Check the ohms between the + and - of the coil, it should read between 2-3 ohms. |
VaccaRabite |
Aug 17 2020, 06:40 AM
En Garde! Group: Admin Posts: 13,445 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Did that help? QUOTE Car ran well for about 15 miles, after that its been getting progressively worse with no apparent reason. That sounds like you have an incompatible coil and it's burning down the points rub block. I've run into this a few times with Bosch dizzy's and the owner installed a generic coil. Check the ohms between the + and - of the coil, it should read between 2-3 ohms. Or you may have to add a resistor block to the coil power supply line. I had to do that when I was running a Mallory, and IIRC it was one of the thins they said you had to do in the instruction booklet. You also need to run spiral wound plug wires with the Mallory to keep from burning up the optical unit. Zach |
nditiz1 |
Aug 17 2020, 06:56 AM
Senior Member Group: Members Posts: 1,188 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
If you want to pay for shipping both ways, I have a spare pertonix in a 009 you can barrow since this is only a temporary thing.
colingreene |
Aug 18 2020, 01:25 PM
Did that help? QUOTE Car ran well for about 15 miles, after that its been getting progressively worse with no apparent reason. That sounds like you have an incompatible coil and it's burning down the points rub block. I've run into this a few times with Bosch dizzy's and the owner installed a generic coil. Check the ohms between the + and - of the coil, it should read between 2-3 ohms. Or you may have to add a resistor block to the coil power supply line. I had to do that when I was running a Mallory, and IIRC it was one of the thins they said you had to do in the instruction booklet. You also need to run spiral wound plug wires with the Mallory to keep from burning up the optical unit. Zach Its not optical, hence why I was looking for points. The coil that was on the car was 3.0 Ohms The shop i took it to put one on that was 1.5.... Ive ordered a new coil and spark plug wires as my coil to distributor wire checked out weird. |
colingreene |
Aug 18 2020, 01:26 PM
Did that help? QUOTE Car ran well for about 15 miles, after that its been getting progressively worse with no apparent reason. That sounds like you have an incompatible coil and it's burning down the points rub block. I've run into this a few times with Bosch dizzy's and the owner installed a generic coil. Check the ohms between the + and - of the coil, it should read between 2-3 ohms. No, bypassing it did not help. I did buy a new purple label coil, ill test it before install it. |
colingreene |
Sep 29 2020, 05:20 PM
New coil, new wires cleaned the points seems to be running fine now.
I bought a air meter for doing my carbs from pelican and it showed up the wrong size so i said F it and am printing the parts to make it work. Just figured i would give a update on this as im trouble shooting something else right now (wipers) and its nice to find a resolution when you search old threads. |
Lo-Fi Version | Time is now: 21st May 2024 - 02:43 PM |
