Needing some old-timer's advice on adjusting valves the proper way |
macnichol |
Jul 17 2020, 09:04 PM
Newbie Group: Members Posts: 40 Joined: 12-June 20 From: Indianapolis, IN Member No.: 24,372 Region Association: NineFourteenerVille |
It is time for the next installment in my Indiana barn-find 914 and it is time to adjust the valves! I want to just check the valve adjustments before attempting to start it up for the first time in 6-7 years. I am not sure what all the p/o did to it, he had mismatched plugs in there so I don't quite trust his judgment. Does anyone on here have any tip/tricks for valve adjustment? I've done some research and spoken to a local air-cooled expert so I know I will need the following
19mm / 21mm wrench 13mm wrench Medium sized flat bladed screwdriver. feeler gauge 2 new valve cover gaskets Next time, I will hopefully have access to a lift to do the oil change work and drain that extremely antique fuel! |
Rand |
Jul 17 2020, 09:12 PM
Rand |
Jul 17 2020, 09:16 PM
And btw, a dime is more useful than a screwdriver to turn the adjuster screws in tight quarters... err dimes. |
914rat |
Jul 26 2020, 09:31 PM
Member Group: Members Posts: 279 Joined: 3-July 06 From: Maryland Member No.: 6,362 |
Captain Krusty's method worked fabulos for me.
Lo-Fi Version | Time is now: 20th May 2024 - 09:46 PM |
