Quick Jack Assistance is Needed Please., One side is stuck up |
913B |
Jul 18 2020, 05:40 PM
Senior Member Group: Members Posts: 847 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
If anyone had run into this before or have any helpful tips, it would be appreciated. If not no worries I plan to call their troubleshooting hotline Monday.
I was able to lift a vehicle up then down, didn't really come all the way down but good enough to slide the QJ out and pretty much applied my weight on them to finish going all the way down. Curiosity got the best of me so I lifted them with no weight they both went up. And only one came back down slowly. The other side appears to be stuck and would not come down or up. It is currently stuck in the up position. The thing I have tried is to ensure the side tank was pressurized to 50psi. I tried swapping the hydraulic lines still that one side won't move. The other side works fine up and down. So it seems it's not the lines or the hydraulic unit. But the that particular cylinder? Any thoughts for the weekend. Thanks, everyone! |
Aualexa1 |
Jul 18 2020, 05:52 PM
Newbie Group: Members Posts: 45 Joined: 17-June 17 From: South Jersey Member No.: 21,189 Region Association: MidAtlantic Region |
Cairo94507 |
Jul 19 2020, 06:45 AM
Michael Group: Members Posts: 9,772 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
I agree with the weight. When I raise my lift (not a quick jack though) if there is not a car on it, it takes a long time to go all the way down. And in the winter time, it is really slow. I used the recommended hydraulic fluid BTW. Of course with a car on the lift it goes down quite nicely. (IMG:style_emoticons/default/beerchug.gif)
Olympic 914 |
Jul 19 2020, 08:12 AM
Group: Members Posts: 1,671 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Check the air pressure in the cylinders. Mine started acting wonky and the air was low.
I don't remember the pressure, But it will be listed in the manual. Edit. Sorry i didn't see you already checked the pressure...… |
914sgofast2 |
Jul 19 2020, 09:00 AM
Senior Member Group: Members Posts: 617 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
The Quick Jacks need weight on them to come down. Put a couple of cinder blocks on the one stuck in the up position, then hit the down function on the control button. If that doesn’t work, then slowly open the bleed screw on the offending lift, but don’t get your hand or fingertips caught when it crashes down!
Robarabian |
Jul 19 2020, 09:14 AM
914 A Roo Group: Members Posts: 592 Joined: 11-February 19 From: Simi Valley, Kalifornia Member No.: 22,865 Region Association: Southern California |
914werke |
Jul 19 2020, 11:35 AM
"I got blisters on me fingers" Group: Members Posts: 10,081 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
it says specifically in the instructions you must always have weight on the lifts when raising/lowering them
pilothyer |
Jul 19 2020, 09:56 PM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
15 psi.. Check the air pressure in the cylinders. Mine started acting wonky and the air was low. I don't remember the pressure, But it will be listed in the manual. Edit. Sorry i didn't see you already checked the pressure...… Put 50 PSI (NO MORE) in the cylinders. It won't take much as they are small, Their job is to return to full down position. |
Coondog |
Jul 19 2020, 11:15 PM
Advanced Member Group: Members Posts: 2,089 Joined: 24-September 15 From: Apple Valley Calif Member No.: 19,195 Region Association: Southern California |
Just stand on it while lowering.
913B |
Jul 19 2020, 11:48 PM
I tried stack a set of tire and wheels on it and no dice.
drem914 |
Jul 20 2020, 07:55 AM
Senior Member Group: Members Posts: 1,030 Joined: 16-May 08 From: Trabuco Canyon, CA Member No.: 9,062 Region Association: Southern California |
Robarabian |
Jul 20 2020, 08:24 AM
Put them side by side.. you cant stand on just one the other will rise. Get the whole family and a few neighbors.. divide up the people and stand on both of them... with a few hundred pounds only, they will come down slow.
I tried stack a set of tire and wheels on it and no dice. |
Robarabian |
The instructions say a max of 15... so be careful with that much pressure..
913B |
Jul 20 2020, 10:12 AM
Hmm my instruction manual says 50 psi max not 15 that’s kind of odd, maybe older models. I recently bought my QJ less than 1 yr ago. Good idea I will get the entire family to balance on them and see if they will go down.
KELTY360 |
Jul 20 2020, 10:43 AM
914 Neferati Group: Members Posts: 5,031 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
Hmm my instruction manual says 50 psi max not 15 that’s kind of odd, maybe older models. I recently bought my QJ less than 1 yr ago. Good idea I will get the entire family to balance on them and see if they will go down. Be sure to get pics of this. (IMG:style_emoticons/default/biggrin.gif) |
eric9144 |
Jul 20 2020, 01:53 PM
Advanced Member Group: Members Posts: 2,734 Joined: 30-March 11 From: San Diego, CA Member No.: 12,876 Region Association: Southern California |
Hmm my instruction manual says 50 psi max not 15 that’s kind of odd, maybe older models. I recently bought my QJ less than 1 yr ago. Good idea I will get the entire family to balance on them and see if they will go down. Same, I have the 7500# version and it wanted 40-50 PSI--could be model dependent. |
pilothyer |
Jul 22 2020, 11:22 AM
The instructions say a max of 15... so be careful with that much pressure.. 15 psi.. Check the air pressure in the cylinders. Mine started acting wonky and the air was low. I don't remember the pressure, But it will be listed in the manual. Edit. Sorry i didn't see you already checked the pressure...… Put 50 PSI (NO MORE) in the cylinders. It won't take much as they are small, Their job is to return to full down position. Watch this official Quick Jack Video (2:00 into the video starts the air it up part.) QUICK JACK |
913B |
Jul 22 2020, 04:21 PM
I tried stack a set of tire and wheels on it and no dice. I had the happened to me when I first bought mine and I set a bunch of cases of water bottles on it. You just need weight. when you call customer service they will say 300 lbs. (ask me how I know) Yup, that was the trick. I stacked a set of tires and my kids and I stood on it, >#300 I operated a few more times to bleed the system but just lifted to about the first lock. It still needs a little assistance to finally rest all the way down, but hopefully, after time it will be better. Thanks, everyone, |
Lo-Fi Version | Time is now: 20th May 2024 - 08:29 PM |
