Thinking of re-powering my SBC V8 car, In the planning stages need ideas for budgeting |
Rider914 |
Jul 21 2020, 10:31 AM
Member Group: Members Posts: 276 Joined: 13-April 04 From: Palm Beach Member No.: 1,923 |
I have a '72 that has been V8 converted for the last 30 years.
The old SBC is tired and leaky and I would love to switch to an LS for more power and fuel injection. Definitely LS3 or maybe LS7 if they have fixed the valve problems. Minimum of 600 hp, more is better. It has massive tires so traction isn't a problem. I could be talked into turbos... Must ditch the 901 tail-shifter. The Boxter S sounds promising. I dream of a sequential but $$. Car is a garage queen that will get some track but 98% street and shows. 200 miles a year. What crate engine should I look at? ECU/Spark? Just trying to get the budget numbers. Would like to shoot for $20k or so. Thanks |
ClayPerrine |
Jul 21 2020, 10:35 AM
Life's been good to me so far..... Group: Admin Posts: 15,465 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I have a '72 that has been V8 converted for the last 30 years. The old SBC is tired and leaky and I would love to switch to an LS for more power and fuel injection. Definitely LS3 or maybe LS7 if they have fixed the valve problems. Minimum of 600 hp, more is better. It has massive tires so traction isn't a problem. I could be talked into turbos... Must ditch the 901 tail-shifter. The Boxter S sounds promising. I dream of a sequential but $$. Car is a garage queen that will get some track but 98% street and shows. 200 miles a year. What crate engine should I look at? ECU/Spark? Just trying to get the budget numbers. Would like to shoot for $20k or so. Thanks The Cayman 6 speed would be easier to install in a V-8 car than what I did for mine. And you can buy a sequential shifter conversion for it too. Axles are available that will just bolt up with no issues. (BTDT). Clay |
Cairo94507 |
Jul 21 2020, 10:41 AM
Michael Group: Members Posts: 9,759 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Spend some time reading @tygaboy Chris's thread. He has an LS with a 6 speed Boxster transaxle and a whole lot more. He is around 650HP if I remember correctly. I think there is so much that goes into making a 914 with that kind of HP safe. Chris, Tony and several others have been there and wrote the book. I do not think $20K is going to do it safely with a 600HP engine.
Rider914 |
Jul 21 2020, 10:51 AM
Spend some time reading @tygaboy Chris's thread. He has an LS with a 6 speed Boxster transaxle and a whole lot more. He is around 650HP if I remember correctly. I think there is so much that goes into making a 914 with that kind of HP safe. Chris, Tony and several others have been there and wrote the book. I do not think $20K is going to do it safely with a 600HP engine. It currently has about 375hp and needs way more - Already has roll bar, giant tires, brakes, and suspension. I'm tired of the burning eyes from carburetor and tip-toeing around the sloppy and weak 901. Safe? yeah definitely not, no TC, ABS or airbags, but I also stunt motorcycles for fun lol. I won't be letting my grandma drive it. I will check out Chris and Tony - Thanks! |
thelogo |
Jul 21 2020, 11:40 AM
Senior Member Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
I have a '72 that has been V8 converted for the last 30 years. The old SBC is tired and leaky and I would love to switch to an LS for more power and fuel injection. Definitely LS3 or maybe LS7 if they have fixed the valve problems. Minimum of 600 hp, more is better. It has massive tires so traction isn't a problem. I could be talked into turbos... Must ditch the 901 tail-shifter. The Boxter S sounds promising. I dream of a sequential but $$. Car is a garage queen that will get some track but 98% street and shows. 200 miles a year. What crate engine should I look at? ECU/Spark? Just trying to get the budget numbers. Would like to shoot for $20k or so. Thanks 600 horse engine in a 914 ? Is it for bonnelville or what Just use a afterburning turbofan . Whats really the difference at that point I mean is this seceretly gerald weigart posting ? . And can we see pic of this 200 mile a year show car? |
Rider914 |
Jul 21 2020, 12:00 PM
600 horse engine in a 914 ? Is it for bonnelville or what Just use a afterburning turbofan . Whats really the difference at that point I mean is this seceretly gerald weigart posting ? . And can we see pic of this 200 mile a year show car? [/quote] Lol - Its definately not a show car, just goes to car shows for fun... Some old pictures of it around here somewhere. Used to be a daily driver - burried in a garage for last 10 years. |
tygaboy |
Jul 21 2020, 12:29 PM
914 Guru Group: Members Posts: 5,292 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California |
"If more is better then too much is just enough!" (IMG:style_emoticons/default/aktion035.gif)
My LS3 dyno'd 518 hp/464 torque at the crank. Tony's (screen name Cracker) has an LS7 that dyno'd 533 hp at the wheels. We both run the Boxster 6-speed (G86-20) and Renegade adapter set up. I have Boxster calipers, Tony has 997s up front and Boxster S on the rear, if I recall correctly. Both run GT flares w/9" rear wheels. Tony's car has some mods to the rear flares and I think he can get a 275 under his. I'm limited to 245. Tony uses his nearly exclusively as a track car and he sports a big front splitter and big rear wing. He runs with the 911 Cup cars. Yes, he and his car are FAST. Mine is designed as to be a "race rod": Some elements of race car, some of hot rod. I may do an occasional track day but for me, it's more about the journey of the design and build process. That's a long way around to: Sure, go big power! Just don't skimp on an appropriate trans, braking system, chassis and safety upgrades. I figure I'll be traction limited with the power I'll have - especially on street tires - so I'm not interested in chasing more. Just my opinion... I'd be happy to share anything I may know. PM me if you'd like to chat at some point. Chris |
tygaboy |
Jul 21 2020, 01:56 PM
I forgot to mention that I'm running the Borla 8-stack set up with Holley HP ECU. Stock cam and reversed turbo-forward headers. Borla mentioned that I could expect at least 50 more hp by just swapping in a cam upgrade. See my build thread for pics as well as a video of it on the dyno.
I do have the stock LS intake / valley tray that has already been modified to run reversed. Along with that, a never installed Current Performance reverse intake engine loom, stock computer, throttle body and DBW throttle pedal. I might be talked into selling. |
thelogo |
Jul 21 2020, 02:05 PM
Thread hyjack .since this seems to be the crowd
Is this a steal ... Great price or crack pipe . ? https://losangeles.craigslist.org/wst/cto/d...7160940133.html |
burton73 |
Jul 21 2020, 03:45 PM
burton73 Group: Members Posts: 3,524 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Get a 915 with wevo kit for trans or a 930 4 speed with cable shifting like I have for my V8 car. The question is do you need that much power. I thought I wanted over 600 HP just because my 930 and 930 CVs can take the big power but a number of guys say that is just too much and the tires will never get traction. I have always thought more is better
Bob B I do not know this builder but there are a number of builders across the country. 537 HP “THE BEAST” The ultimate “street-and-strip” small block Chevy. When celebrities or hardcore Chevy enthusiasts want the best money can buy, it’s a no brainer. We offer 3 cam different selections that range from 525 to 550 HP customizing your ultimate engine to sound and perform just the way you want it! Pricing starting at $8,300! Fule Injection https://westcoastengines.com/383-stroker/ • 537 HP / 499 TQ • Street-and-Track • 91 Premium Pump Gas • Lopey Sound • 3 Year Warranty |
Andyrew |
Jul 21 2020, 04:40 PM
We've got an twin turbo LS6 914 coming out sometime around the end of the year and can tell you impressions then, but realistically its hard to put down traction much above 500CHP on the street on street tires...
See if you can get a ride in a 500hp 914. Its a different ball game than 375HP. |
Chris914n6 |
Jul 21 2020, 05:22 PM
Jackstands are my life. Group: Members Posts: 3,320 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
For 200 miles a year ??
$1200 on a FiTech carb replacement and be done. |
dan10101 |
Jul 21 2020, 05:24 PM
TORQUE-o-holic Group: Members Posts: 1,140 Joined: 29-April 03 From: Eagle Point, Or Member No.: 626 Region Association: Pacific Northwest |
(IMG:style_emoticons/default/chowtime.gif) The Cayman 6 speed would be easier to install in a V-8 car than what I did for mine. And you can buy a sequential shifter conversion for it too. Axles are available that will just bolt up with no issues. (BTDT). Clay You had me at sequential... (IMG:style_emoticons/default/chowtime.gif) |
Rand |
Jul 21 2020, 05:35 PM
Thread hyjack .since this seems to be the crowd Is this a steal ... Great price or crack pipe . ? https://losangeles.craigslist.org/wst/cto/d...7160940133.html See the first post. It's what they are trying to get away from. Cast iron blocks not ideal in a light car. |
thelogo |
Jul 21 2020, 06:26 PM
Thread hyjack .since this seems to be the crowd Is this a steal ... Great price or crack pipe . ? https://losangeles.craigslist.org/wst/cto/d...7160940133.html See the first post. It's what they are trying to get away from. Cast iron blocks not ideal in a light car. Great price though right ? a flared finished car for 18k ... Thats pretty ideal Id be going turbo /4 if i got it |
Mueller |
Jul 21 2020, 06:41 PM
If KEP makes an adapter setup for the Gen V LS replacement motor I'd go with Porsche 6 speed transaxle and LV1 V6 and turbo it. Basically it is the new LT1 engine with 2 less cylinders.
Shorter so it'll fit better. There is a Grand National on youtube I've seen that is pretty impressive with this motor in it. |
Rider914 |
Jul 22 2020, 07:17 AM
For 200 miles a year ?? $1200 on a FiTech carb replacement and be done. Now you sound like my wife lol. Except she says sell it... But yes that would be the smart thing - Good advice - perhaps just do a cable or hydraulic shifter conversion to the 901. It is really sloppy. |
Rider914 |
Jul 22 2020, 07:24 AM
We've got an twin turbo LS6 914 coming out sometime around the end of the year and can tell you impressions then, but realistically its hard to put down traction much above 500CHP on the street on street tires... See if you can get a ride in a 500hp 914. Its a different ball game than 375HP. Yeah anything over 500hp is probably just mine is bigger than yours d*ck waving but you know I like mine to be bigger than yours. And I am used to sportbikes and the pull they have from 60-150. I just sold my ZX-10R that would rip your arms off at 100. I am in love with the sound of the V8 with a heavy cam, it is the sound of my people so I wouldn't consider any other engine even if it is better... |
Rider914 |
Jul 22 2020, 07:26 AM
Get a 915 with wevo kit for trans or a 930 4 speed with cable shifting like I have for my V8 car. The question is do you need that much power. I thought I wanted over 600 HP just because my 930 and 930 CVs can take the big power but a number of guys say that is just too much and the tires will never get traction. I have always thought more is better Bob B Bob - Whats the rough price difference bettwen a prepped 915 / 930 and a prepped Boxter S? Advantages? Thanks |
Jett |
Jul 22 2020, 08:29 AM
Senior Member Group: Members Posts: 1,638 Joined: 27-July 14 From: Seattle Member No.: 17,686 Region Association: Pacific Northwest |
I have an LS2 crate motor with a new ProCharger (gear driven) supercharger, and FAST electronics (cost was $21k). There are zero miles, and would let it go for $15K. Would love to put the motor in a pre 50’s Chevy truck, but if you want to put it in a 914 (IMG:style_emoticons/default/smile.gif)
I replaced the motor setup with a 700HP LS7 (sodium filled titanium valves), with the computer and upgraded Holley fuel injection, it cost $34K total —with a 15% discount on the LS7 at the time. Additionally the chassis and rear end needed to support the power. Art Morrison created a one-off frame to handle the power and added a very sophisticated four link. |
Lo-Fi Version | Time is now: 17th May 2024 - 10:37 AM |
