Radio Identification/Installation, Reinstalling the radio in '72 914 |
Baumgardner |
Aug 7 2020, 02:23 PM
Newbie Group: Members Posts: 34 Joined: 2-May 20 From: Cincinnati, Ohio Member No.: 24,213 Region Association: Upper MidWest |
When I received my '72 914, the radio was not connected and previous owner indicated they hadn't tried to hook it up. I pulled the radio and sent it in to check out. I was told it was a Blaupunkt “Emden” model and that it worked fine. Here is pic of the radio with some codes which I have NOT been able to identify. At this point, I'm trying to figure out how to properly reconnect this. I was told the brown wire was for speakers, the blue wire was for "illumination", and should connect to dash lights, and the black wire was the power feed. The antennae feed connection is in the rear. I'm a little hesitant about properly wiring this. For one thing, I assume I need to attach a ground from the back of the radio to the chassis? Any advice on this would be greatly appreciated, either in confirming the model or advice on reconnection? Thank you.
michael7810 |
Aug 7 2020, 08:43 PM
Senior Member Group: Members Posts: 1,081 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region |
the radio guy should be able to help
Baumgardner |
Aug 8 2020, 07:07 AM
the radio guy should be able to help Hey Michael! Hope all is well! Unfortunately the radio guy is in New York and I've lost some faith in him since he identified it as a Blaupunkt! He did get it working though (he sent me a video). He did advise me on the wires, but I don't believe he is in any way a 914 guy or has any car specific knowledge on connections... After searching through some other postings here, it appears factory Blaupunkt's weren't really found in US cars and this Motorola was one of the common dealer installed options so I'm pretty sure this was original with the car... I don't think the speakers were original though or even if they are correct for this radio so I'll probably replace those as I get this figured out. Time to study some wiring diagrams I guess!... I doubt I even play the radio much if at all, but I like the idea of a working radio (just so I can "yeah" if a passenger ever says "does the radio work". (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 19th May 2024 - 10:41 AM |
