Sold - NOS German 215mm Flywheel and Parts, Good German Stuff! |
Nie Zu Alt |
Sep 10 2020, 01:42 PM
Member Group: Members Posts: 173 Joined: 1-June 05 From: Centennial, CO Member No.: 4,184 Region Association: Rocky Mountains |
IronHillRestorations |
Sep 10 2020, 02:21 PM
I. I. R. C. Group: Members Posts: 6,724 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
That's a good deal! GLWTS
rjames |
Sep 10 2020, 02:28 PM
I'm made of metal Group: Members Posts: 3,942 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
It would be great to measure the specs on this before it gets sold/installed as there only seems to be exact measurements documented for the 914-6 flywheel.
Good luck with the sale! |
914forme |
Sep 10 2020, 05:54 PM
rjames this is a type-4 flywheel
914sgofast2 |
Sep 10 2020, 06:25 PM
Senior Member Group: Members Posts: 620 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
PM sent for purchase.
Sep 10 2020, 06:37 PM
It would be great to measure the specs on this before it gets sold/installed as there only seems to be exact measurements documented for the 914-6 flywheel. Good luck with the sale! Functionally the same dimensions. Clutch components for 4's and 6's are the same, at least now days they are. |
rjames |
Sep 10 2020, 07:06 PM
Nie Zu Alt |
Sep 10 2020, 08:20 PM
Exactly. There isn't any documentation for the type-4 flywheel that I'm aware of. The one picture with measurements that floats around is for the 6 cyl.
[/quote] I'll get a dimensioned drawing posted in the next day or so. Happy to do so! Doug |
Nie Zu Alt |
Sep 10 2020, 09:52 PM
Folks,
See this thread.... Flywheel Specifications Dimensions on this flywheel match the "New" values for dimensions "A" & "B" called out in the popular diagram shown in the above thread. But....As mentioned in the thread, dimension "C" on the flywheel DOES NOT match the diagram. The dimension on the uncut -4 flywheel is 8mm (.314"). This looks to be the difference between the -4 and -6 flywheel. I then tried what Captain Crusty mentioned. Would the hub of the clutch disk hit the bolt heads? No, not even close. The hub of the clutch disk easily clears the flywheel mounting bolt heads. I'm not sure how folks want to record this info as this ad will disappear after a while. Feel free to grab my post and park it where it will do the general community some good. Thanks! Doug Heitkamp |
Lo-Fi Version | Time is now: 29th May 2024 - 08:46 PM |
