Anyone have this dogtooth removal tool?, that i could borrow/rent temporarily? |
Aaron Cox |
Jul 13 2005, 03:10 PM
dogtooth removal tool for a 901.
anyone have one they could lend me (id pay shipping and give you some collateral) (IMG:http://content.performanceproducts.com/main/106045/106045_200_1.jpg) |
Joe Ricard |
Jul 13 2005, 03:15 PM
When I removed my synchros I just used a BIG ASS pair of retaining ring pliers. $10.00 at any tool store.
I don't understand how the tool you have pictured works. Isn't that for taking the dog teeth off the gear. of something like that. |
Aaron Cox |
Jul 13 2005, 03:23 PM
thats what i meant, dogteeth...post edited
TimT |
Jul 13 2005, 03:29 PM
grasshopper, you can use an appropriate sized socket, and a vise
if the dog teeth are toast, which I think they are, clamp the gear/dogteeth and socket in a vise, use a freshly dressed cold chisel, and start to drive the dog teeth off, rotate the gear, repeat... |
DNHunt |
Jul 13 2005, 03:38 PM
Just like Tim I used a sharp chisel to persuade the dogteeth. Not too different from wisdom teeth.(IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Come to think about it I probably could have found something on the oral surgery tray that would have worked.
Just work slow and easy and use something to protect the gear (wood or rubber). Dave |
rick 918-S |
Jul 13 2005, 04:01 PM
Hey nice rack! -Celette Group: Members Posts: 20,458 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
If you have to wreck it to remove it How do you install one? Can you freeze the gear and then heat the dog tooth thing what ever it is?
What the heck is it anyway?!?! |
TimT |
Jul 13 2005, 04:17 PM
Cold gear, hot dog ring
Place hot dog ring on cold gear, quickly press together in vise, Place gear on sturdy surface ( I have an anvil in my garage, along with a 40 lb square block of lead) take a brass drift and tap all around the dog ring to make sure its seated.. Sometimes when the planets align, the dog ring just slips on real nice |
Lo-Fi Version | Time is now: 16th May 2024 - 12:09 AM |
