Momo Prototipo steering wheel |
JamesJ |
Oct 23 2020, 09:53 PM
Member Group: Members Posts: 223 Joined: 30-April 20 From: Sunnyvale, CA Member No.: 24,202 Region Association: Northern California |
Hello,
I am considering purchasing this wheel for my ‘74. As far as I can tell, they only come new in 350mm size. From what I have read, the small diameter of the wheel mostly blocks the left and right gauges, and some of the tach as well. For those of you who have or have had this wheel, in addition to the hub, do I need a 1” or 2” spacer to solve the visibility problem or do I need an eccentric spacer? |
oakdalecurtis |
Oct 24 2020, 12:00 AM
Oakdalecurtis Group: Members Posts: 1,327 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California |
I use the JSWest eccentric spacer with mine, way better. As mentioned, more leg room and better visual with the gauges. When driving, unless you're a track monster, the normal small turns of the wheel make the center offset undetectable. (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 25th May 2024 - 02:02 AM |
