8 Pages V « < 5 6 7 8 >
> Engine build Take 2, The rebirth of my 2270
DNHunt
post Aug 7 2005, 08:11 PM
Post #121
914 Wizard? No way. I got too much to learn.
This may be the toughest thing to do. Getting the wire locks in to retain the wrist pins. Nerve racking too, cause it would be easy to drop them.
DNHunt
post Aug 7 2005, 08:12 PM
Post #122
Safely in.
DNHunt
post Aug 7 2005, 08:13 PM
Post #123
Oil cooler seals
DNHunt
post Aug 7 2005, 08:23 PM
Post #124
Stuff for the front seal under the hub. I almost forgot the O-ring. 2" PVC works well for driving in the seal.
DNHunt
post Aug 7 2005, 08:25 PM
Post #125
PVC in action
DNHunt
post Aug 7 2005, 08:30 PM
Post #126
The big job of the day was balancing the new flywheel bolts. The old ones jake had supplied were exactly the same weight. Using a scale and then a balance and removing ever so slight an amount the new ones are all equal in weight. They are also clearance slightly.
DNHunt
post Aug 7 2005, 08:33 PM
Post #127
Replacing the graphite coated washer in the flywheel.
lapuwali
post Aug 7 2005, 08:35 PM
Post #128
Not another one!
QUOTE (DNHunt @ Aug 7 2005, 06:11 PM)
A shop rag or two stuffed into the cylinder spigot will do a lot to prevent bits from falling into the case. This is generally good practice whenever the case is assembled, and you're putting things onto it (like a certain wavy washer that made a bit for freedom). Just remember to pull them out before you put the cylinders on. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
DNHunt
post Aug 7 2005, 08:38 PM
Post #129
Here is the spacing sleeve in the end of the crankshaft. It keeps the pilot bearing in place.
DNHunt
post Aug 7 2005, 08:40 PM
Post #130
Damn James that's a good idea. That would have made that set less stressful.
Dave
DNHunt
post Aug 7 2005, 08:42 PM
Post #131
An old stub axle is just the right size to seat the rear main seal. The three shims are in already with a little lube.
DNHunt
post Aug 7 2005, 08:49 PM
Post #132
Flywheel is on with the O-ring, 3 shims, spacing sleeve, pilot bearing, felt washer, seal, 5 hole washer and 5 bolts torqued to 80 lbs. Clutch is in place.
DNHunt
post Aug 7 2005, 08:52 PM
Post #133
Pressure plate installed. The bolts are numbered with a stamp and the corresponding holes are numbered so I won't throw off the balance.
DNHunt
post Aug 7 2005, 08:55 PM
Post #134
Gerry adjusting the valves
bd1308
post Aug 7 2005, 08:57 PM
Post #135
Sir Post-a-lot
still havent figured valves out
i will though when i tear apart a engine.
DNHunt
Post #136
Long Block DONE! (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
Dave
Eric Taylor
post Aug 7 2005, 10:39 PM
Post #137
Congradulations Dave (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) It must be a wonderful feeling to have it back together. I call a ride at WCC 06 (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
Eric
914forme
post Aug 8 2005, 05:47 AM
Post #138
Great Job, Must feel really good to get this rebuild done again, and let us know the performance of this Raby combo - I am thinking about it for my 4cly car.
(IMG:http://www.914world.com/bbs2/html/emoticons/mueba.gif) Keep up the great work.
Jake Raby
post Aug 8 2005, 07:35 AM
Post #139
Engine Surgeon
Dave, Hurry up and get that damn thing running!
914forme,
I have tons of folks you could contact about the "Performance" of one of my kits like Dave is putting together here, most of them are not on this board.
DNHunt
post Aug 8 2005, 07:51 AM
Post #140
It's going in Labor Day weekend. I hate to wait but, I'm headed to Whistler for the PCA thing up there and I just don't have enough time to get it in, running, tuned, retorqued and valves adjusted, oil changed and some miles on it. It's killing me to wait. Sometimes it's damn hard acting like and adult. I'll just run Old Smoky. I'll lay down a smoke screen on the AX course. The tail draggers got to have something to wine about.
I have a real good feeling about this one. When we torqued the case down it spun so nice and easy and now it just feels more precise.
Dave
- Lo-Fi Version Time is now: 27th August 2025 - 02:58 AM
