Turn key, battery goes flat, ignition switch smoky. |
jaredmcginness |
Nov 30 2020, 08:25 PM
... Group: Members Posts: 502 Joined: 12-June 19 From: Baltimore Member No.: 23,209 Region Association: MidAtlantic Region |
Me again.
It’s gonna be one problem post a day, until next years Octeener fest. (IMG:style_emoticons/default/idea.gif) So close here to firing this motor (in the car)(works fine outside of it) I’m thinking I have a short somewhere in the ignition, but everything seems to check out. Notes: Early car, early VW style switch. (After market) Turn key, ACC works fine, fuel pump relay clicks, all electrics work. 12v to coil, 12v to starter, power supply relay is good. Turn key to run, Nothing - power goes flat, as long as I hold the key down. Messing around a bit, tried again and the ignition switch/column starts smoking and the IGNS wires are warm. I believe once she smokes she’s done. I’ll buy a new switch tomorrow, but I’m trying to probe if this sounds like more than a switch. All my wiring matches the bowlsby pages. Battery is new. Switch was new (but probably Taiwan crap), new ground to battery and new ground strap. Cleaned every ground I can find. Does not even considering the idea of cranking. Starter cranks fine when manually jumped. Now that my smoke is out, queue the ‘Replacement Can’ comments. (IMG:style_emoticons/default/bye1.gif) |
Superhawk996 |
Dec 1 2020, 06:42 AM
914 Guru Group: Members Posts: 5,777 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
I’m thinking I have a short somewhere in the ignition, but everything seems to check out. Me too. You posted a lot of other good info on what parts you have but the only thing that really matter is wheter or not the Digital Multimeter says things check out. DMM and wiring diagram are your friend. All else is speculation. Let me find the link to half split troubleshooting method I've previously posted. Post #6 http://www.914world.com/bbs2/index.php?showtopic=340700 |
Lo-Fi Version | Time is now: 3rd May 2024 - 10:03 PM |
