Quick jack - first impression |
draganc |
Dec 7 2020, 01:13 PM
Senior Member Group: Members Posts: 725 Joined: 2-November 09 From: central new jersey Member No.: 11,000 Region Association: North East States |
Hello folks,
Just a few FYI only pics of my 7000 type quick jack. It’s slightly longer than the 5000 but it fits just nicely under a teener and lifts the car about 12” of the ground, with the medium and tall rubber blocks. Not a endorsement per se for QJ and there are also other compact lifts, but if you do any work on cars you do want one of them! I was first reluctant to spend the $1200 (HD had a special, with $300 off) but now I could kick my a$$ for not having bought it sooner, like years sooner. Happy wrenching fellas! |
Olympic 914 |
Dec 7 2020, 01:27 PM
Group: Members Posts: 1,670 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Caution using both sets of rubber blocks.
I had my car shift, and almost fall off using both. I have since cut blocks of wood that fit inside the trays and no longer worry about the rubber blocks shifting. I never use the rubber blocks anymore. |
draganc |
Dec 7 2020, 01:40 PM
Caution using both sets of rubber blocks. I had my car shift, and almost fall off using both. I have since cut blocks of wood that fit inside the trays and no longer worry about the rubber blocks shifting. I never use the rubber blocks anymore. Thanks for the note! Do you have a 5000 or 7000 model and how/why did your car shift! I raised the lift, with both blocks, just about a 1/4 before it touched the body’s lifting dough nuts, aligned them center on the blocks and lifted it all they way without movement. I did however notice that the front of the lift engage about 3/4” early than the rear. |
Dec 7 2020, 02:29 PM
Anytime I use a lift, I lift the car a couple inches off the ground and then push and shove each end of the car. I also don’t use a breaker bar on the lift. Just impact wrenches.
kroelofsen |
Dec 7 2020, 02:32 PM
Member Group: Members Posts: 100 Joined: 27-June 19 From: The Netherlands Member No.: 23,255 Region Association: Europe |
Envy... Nice lift!
iankarr |
Dec 7 2020, 02:36 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,473 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Anytime I use a lift, I lift the car a couple inches off the ground and then push and shove each end of the car. I also don’t use a breaker bar on the lift. Just impact wrenches. (IMG:style_emoticons/default/agree.gif) I only needed to see my car jump once on the lift (also a QJ) when trying to use a breaker bar on a stuck axle nut. Never again. Congrats on the QJ BTW. I love mine. Really great solution if you don't have a high enough ceiling in your carage for a 4 post. And I just use the one set of taller rubber blocks. Lifts plenty high enough to drop the engine and do pretty much anything else. Be safe and enjoy... |
drem914 |
Dec 7 2020, 02:49 PM
Senior Member Group: Members Posts: 1,030 Joined: 16-May 08 From: Trabuco Canyon, CA Member No.: 9,062 Region Association: Southern California |
Anytime I use a lift, I lift the car a couple inches off the ground and then push and shove each end of the car. I also don’t use a breaker bar on the lift. Just impact wrenches. (IMG:style_emoticons/default/agree.gif) I love mine. Really great solution if you don't have a high enough ceiling in your garage for a 4 post. And I just use the one set of taller rubber blocks. Lifts plenty high enough to drop the engine and do pretty much anything else. Be safe and enjoy... Agree, We also use it for our Boxster and BMW 328I for oil changes, all with the tall blocks. |
draganc |
Dec 7 2020, 02:55 PM
Anytime I use a lift, I lift the car a couple inches off the ground and then push and shove each end of the car. I also don’t use a breaker bar on the lift. Just impact wrenches. 100% (IMG:style_emoticons/default/agree.gif) |
Cairo94507 |
Dec 7 2020, 03:51 PM
Michael Group: Members Posts: 9,759 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Absolutely. I always lift it off the ground a few inches and then walk around the car pulling and pushing on all 4 corners. Safety first. (IMG:style_emoticons/default/beerchug.gif)
jim_hoyland |
Dec 8 2020, 05:25 AM
Get that VIN ? Group: Members Posts: 9,301 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Nice piece of equipment (IMG:style_emoticons/default/smile.gif) What does each side weigh ? How do you store them when not in use; and, how are they raised ?
mlindner |
Dec 8 2020, 05:37 AM
Senior Member Group: Members Posts: 1,521 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
any chance that is high enough to pull engine.
iankarr |
Dec 8 2020, 07:39 AM
bdstone914 |
Dec 8 2020, 07:56 AM
Make sure when lowering the car that both release catches are pulled. I was doing a demo of one in a parking lot that was not entirely flat. One catch was not pulled and the BMW quickly started to list to one side. Would not have been a good demo to put a nice BMW on its side.
wobbletop |
Dec 8 2020, 08:47 AM
Member Group: Members Posts: 382 Joined: 8-December 06 From: Ontario, Canada Member No.: 7,335 Region Association: Canada |
Nice piece of equipment (IMG:style_emoticons/default/smile.gif) What does each side weigh ? How do you store them when not in use; and, how are they raised ? I've had one for a while. Each side is maybe 80lb? You wouldn't want to carry them around too long, but they have roller wheels on one end so you don't have to lift them. They stay beside my car all summer since I'm always changing wheels/brakes. They are not very high to step over. In the winter, once the winter tires are on, I just lean them up against the garage wall. There is a separate hydraulic pump with dry fit connections. If the car is going to be on the lift for a while, I'll disconnect the hoses so I'm not stepping over them all the time. I love mine. Got them on sale at Costco. |
drem914 |
Dec 8 2020, 09:21 AM
Nice piece of equipment (IMG:style_emoticons/default/smile.gif) What does each side weigh ? How do you store them when not in use; and, how are they raised ? I've had one for a while. Each side is maybe 80lb? You wouldn't want to carry them around too long, but they have roller wheels on one end so you don't have to lift them. They stay beside my car all summer since I'm always changing wheels/brakes. They are not very high to step over. In the winter, once the winter tires are on, I just lean them up against the garage wall. There is a separate hydraulic pump with dry fit connections. If the car is going to be on the lift for a while, I'll disconnect the hoses so I'm not stepping over them all the time. I love mine. Got them on sale at Costco. I got them there last summer during a clearance. Mine stay under my car in the center when not in use, but you can get wall hooks to hang them on if you want. I have an area marked out with tape for storage) Very handy and sturdy. @Jim_Hoyland call me and I can go through any question you might have. |
930cabman |
Dec 8 2020, 09:50 AM
Advanced Member Group: Members Posts: 3,064 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Anytime I use a lift, I lift the car a couple inches off the ground and then push and shove each end of the car. I also don’t use a breaker bar on the lift. Just impact wrenches. Great reminder, habits can be good or not good. I have tried to develop the same, always give the car on the lift a good shake when it's a couple inches off the floor and never a breaker bar. Safety first, especially when under a 2000+ car |
MM1 |
Dec 8 2020, 11:23 AM
914 obsession continues Group: Members Posts: 608 Joined: 9-May 18 From: Thousand Oaks, CA Member No.: 22,105 Region Association: Southern California |
Can anyone compare the QJ to the EZ Car lift?
VaccaRabite |
Dec 8 2020, 12:08 PM
En Garde! Group: Admin Posts: 13,444 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Can anyone compare the QJ to the EZ Car lift? EZ Car lifts a little higher (26 inches) Quick Jacks seem more stable. I'll take strength and stability over 6 inches of lifting. That said, I've used Quick Jacks, I've only seen EZ Car demoed. In the end I bought a MaxJax 2 post on a black friday special last year. Its been world changing for my auto hobby. Zach |
914werke |
Dec 8 2020, 12:20 PM
"I got blisters on me fingers" Group: Members Posts: 10,066 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
@vaccarabite Zach can you opine on the ease or speed of setup on the MaxJack(MJ) vs the QuickJack (QJ)?
I think for the $ the QJ is GREAT & damn speedy to get a car up on compared to comparable height Jack stands. I just wish it was a bit taller. I was looking hard at a set of MJ's. Did you mount them permanently? |
MM1 |
Dec 8 2020, 12:27 PM
Can anyone compare the QJ to the EZ Car lift? EZ Car lifts a little higher (26 inches) Quick Jacks seem more stable. I'll take strength and stability over 6 inches of lifting. That said, I've used Quick Jacks, I've only seen EZ Car demoed. In the end I bought a MaxJax 2 post on a black friday special last year. Its been world changing for my auto hobby. Zach Thanks, Zach - appreciate your impressions. |
Lo-Fi Version | Time is now: 17th May 2024 - 06:02 PM |
