OT bought a shark |
OT bought a shark |
mb911 |
Jan 9 2021, 09:41 AM
914 Guru Group: Members Posts: 6,823 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
mb911 |
Jan 21 2021, 07:21 PM
ddire333 |
Jan 22 2021, 11:12 AM
Member Group: Members Posts: 91 Joined: 2-November 20 From: ireland Member No.: 24,835 Region Association: Europe |
And some replacement harnesses.. I need to check them out and repair as needed but nice to be all set.. I think I might need another harness yet but close. That is much worse than mine was, but all do able. Looks like it might have been the main positive lead to the charging post that caused it, its not fused and can contact the frame, (the protective sleeve cracks) you get alot of heat fast, and return fuel line is right beside. common enough cause on 928's |
mb911 |
Jan 22 2021, 12:23 PM
And some replacement harnesses.. I need to check them out and repair as needed but nice to be all set.. I think I might need another harness yet but close. That is much worse than mine was, but all do able. Looks like it might have been the main positive lead to the charging post that caused it, its not fused and can contact the frame, (the protective sleeve cracks) you get alot of heat fast, and return fuel line is right beside. common enough cause on 928's Likely for sure.. I need to make sure I have all the harnesses I need. Going to make sure the ones going in are in good condition and repair what needs to be done.. I can't wait for spring to at least wash off all the nasty fire damage. |
Lo-Fi Version | Time is now: 5th May 2024 - 04:59 PM |
