Can I remove oil without using the drain plug?, Need to pull out some oil over fill before next oil change |
drem914 |
Mar 9 2021, 11:23 AM
Senior Member Group: Members Posts: 1,030 Joined: 16-May 08 From: Trabuco Canyon, CA Member No.: 9,062 Region Association: Southern California |
Dumb question here, but is it possible to go in through the oil fill port (on a 4cyl) to vacuum siphon out about a half qt. of oil?
I had over-filled when I did my last oil change. (IMG:style_emoticons/default/headbang.gif) I didn't want to pull out the quick jacks and pull the drain plug unless I had to. TIA |
bdstone914 |
Mar 9 2021, 11:38 AM
Dumb question here, but is it possible to go in through the oil fill port (on a 4cyl) to vacuum siphon out about a half qt. of oil? I had over-filled when I did my last oil change. (IMG:style_emoticons/default/headbang.gif) I didn't want to pull out the quick jacks and pull the drain plug unless I had to. TIA That is a 8mm OD tube so sucking oil tube so sucking oil through it may not be easy. You could change oil filters and that will take out about 1/2 quart. @drem914 |
bdstone914 |
Mar 9 2021, 11:39 AM
Dumb question here, but is it possible to go in through the oil fill port (on a 4cyl) to vacuum siphon out about a half qt. of oil? I had over-filled when I did my last oil change. (IMG:style_emoticons/default/headbang.gif) I didn't want to pull out the quick jacks and pull the drain plug unless I had to. TIA That is a 8mm OD tube so sucking oil tube so sucking oil through it may not be easy. You could change oil filters and that will take out about 1/2 quart. Or remove the filter, drain it and reinstall as many times as needed to bring down the oil level. @drem914 |
drem914 |
Mar 9 2021, 12:14 PM
Dumb question here, but is it possible to go in through the oil fill port (on a 4cyl) to vacuum siphon out about a half qt. of oil? That is a 8mm OD tube so sucking oil tube so sucking oil through it may not be easy. I had over-filled when I did my last oil change. (IMG:style_emoticons/default/headbang.gif) I didn't want to pull out the quick jacks and pull the drain plug unless I had to. TIA You could change oil filters and that will take out about 1/2 quart. Or remove the filter, drain it and reinstall as many times as needed to bring down the oil level. @drem914 Looks like it goes up on the QJ either way. (IMG:style_emoticons/default/smash.gif) |
Rider914 |
Mar 9 2021, 12:58 PM
Member Group: Members Posts: 276 Joined: 13-April 04 From: Palm Beach Member No.: 1,923 |
My car does this on its own, just park it on the cleanest driveway you can find. Bonus is that it's also self-lubricating.
Root_Werks |
Mar 9 2021, 01:22 PM
Village Idiot Group: Members Posts: 8,321 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
I had a pump that sucked oil out on my boat years back. Dunno if there's a direct path to a low point on a 914 sump/pan though?
ClayPerrine |
Mar 9 2021, 01:49 PM
Life's been good to me so far..... Group: Admin Posts: 15,469 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
If you are looking at the dipstick indicator, a half a quart over full in a 914-4 is not a bad thing. It will keep the pump from sucking air on hard turns. We have run 914s that way for years with no issues.
Clay |
Krieger |
Mar 9 2021, 04:09 PM
Advanced Member Group: Members Posts: 4,712 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
If you are looking at the dipstick indicator, a half a quart over full in a 914-4 is not a bad thing. It will keep the pump from sucking air on hard turns. We have run 914s that way for years with no issues. Clay (IMG:style_emoticons/default/agree.gif) 100% I have another mark on my dipstick that is the same distance above the top mark as the factory low mark. That is where I measure mine cold. If you still feel the need to to remove oil you can use a Mityvac in the dipstick tube. |
Mar 9 2021, 07:33 PM
Gotta say, I don’t have any half filled quarts of oil.
I get close, I pour till the quart is empty I bit extra on an oil cooled motor is all good |
Front yard mechanic |
Mar 9 2021, 08:23 PM
Senior Member Group: Members Posts: 1,164 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None |
I bought a cheap fluid extractor from harbor freight comes with a thin tube that fits the dipstick just get the oil hot before .it works ok on oil but works well to remove brake fluid
stugray |
Mar 14 2021, 01:31 PM
An extra half quart will not hurt anything.
I intentionally fill mine about that much extra for racing to avoid the oil pump sucking air under hard cornering. |
ClayPerrine |
Mar 15 2021, 02:03 PM
If you are looking at the dipstick indicator, a half a quart over full in a 914-4 is not a bad thing. It will keep the pump from sucking air on hard turns. We have run 914s that way for years with no issues. Clay (IMG:style_emoticons/default/agree.gif) 100% I have another mark on my dipstick that is the same distance above the top mark as the factory low mark. That is where I measure mine cold. If you still feel the need to to remove oil you can use a Mityvac in the dipstick tube. An extra half quart will not hurt anything. I intentionally fill mine about that much extra for racing to avoid the oil pump sucking air under hard cornering. WOW! That echo took a LONG time to come back. (IMG:style_emoticons/default/biggrin.gif) |
drem914 |
Mar 15 2021, 02:33 PM
Well I didn't have to do any of that, just ran the engine real hard over the weekend with a hour long 80+mph run on the freeway as a precursor to a couple hours of mountain driving with lots of curves and then a long freeway drive back. Will have to see where it went since I am not getting any visible drips below.
Lo-Fi Version | Time is now: 18th May 2024 - 02:24 PM |
