drem914
Mar 9 2021, 11:23 AM
Dumb question here, but is it possible to go in through the oil fill port (on a 4cyl) to vacuum siphon out about a half qt. of oil?
I had over-filled when I did my last oil change.
I didn't want to pull out the quick jacks and pull the drain plug unless I had to.
TIA
bdstone914
Mar 9 2021, 11:38 AM
QUOTE(drem914 @ Mar 9 2021, 11:23 AM)
TIA
That is a 8mm OD tube so sucking oil tube so sucking oil through it may not be easy.
You could change oil filters and that will take out about 1/2 quart.
@drem914
bdstone914
Mar 9 2021, 11:39 AM
QUOTE(bdstone914 @ Mar 9 2021, 11:38 AM)
TIA
Or remove the filter, drain it and reinstall as many times as needed to bring down the oil level.
@drem914
drem914
Mar 9 2021, 12:14 PM
QUOTE(bdstone914 @ Mar 9 2021, 09:39 AM)
TIA
@drem914Thanks Bruce.
Looks like it goes up on the QJ either way.
Rider914
Mar 9 2021, 12:58 PM
My car does this on its own, just park it on the cleanest driveway you can find. Bonus is that it's also self-lubricating.
Root_Werks
Mar 9 2021, 01:22 PM
I had a pump that sucked oil out on my boat years back. Dunno if there's a direct path to a low point on a 914 sump/pan though?
ClayPerrine
Mar 9 2021, 01:49 PM
If you are looking at the dipstick indicator, a half a quart over full in a 914-4 is not a bad thing. It will keep the pump from sucking air on hard turns. We have run 914s that way for years with no issues.
Clay
Krieger
Mar 9 2021, 04:09 PM
QUOTE(ClayPerrine @ Mar 9 2021, 11:49 AM)
Clay
100% I have another mark on my dipstick that is the same distance above the top mark as the factory low mark. That is where I measure mine cold. If you still feel the need to to remove oil you can use a Mityvac in the dipstick tube.
r_towle
Mar 9 2021, 07:33 PM
Gotta say, I don’t have any half filled quarts of oil.
I get close, I pour till the quart is empty
I bit extra on an oil cooled motor is all good
Front yard mechanic
Mar 9 2021, 08:23 PM
I bought a cheap fluid extractor from harbor freight comes with a thin tube that fits the dipstick just get the oil hot before .it works ok on oil but works well to remove brake fluid
stugray
Mar 14 2021, 01:31 PM
An extra half quart will not hurt anything.
I intentionally fill mine about that much extra for racing to avoid the oil pump sucking air under hard cornering.
ClayPerrine
Mar 15 2021, 02:03 PM
QUOTE(Krieger @ Mar 9 2021, 05:09 PM)
Clay
QUOTE(stugray @ Mar 14 2021, 02:31 PM)
WOW! That echo took a LONG time to come back.
drem914
Mar 15 2021, 02:33 PM
Well I didn't have to do any of that, just ran the engine real hard over the weekend with a hour long 80+mph run on the freeway as a precursor to a couple hours of mountain driving with lots of curves and then a long freeway drive back. Will have to see where it went since I am not getting any visible drips below.
