The French 914/6 1972 Sonauto, Full restoration |
KBMC1304 |
Apr 20 2021, 04:40 PM
Member Group: Members Posts: 227 Joined: 23-January 21 From: Algiers Member No.: 25,113 Region Association: France |
I just found tangerine 914/6 72"
mb911 |
Apr 28 2021, 09:04 AM
914 Guru Group: Members Posts: 6,851 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Are you brazing it all?
peteyd |
Apr 28 2021, 10:06 AM
Senior Member Group: Members Posts: 707 Joined: 27-March 08 From: Elora, Ontario, Canada Member No.: 8,858 Region Association: Canada |
Are you brazing it all? I hope this is not the case!! This needs to be done properly! The way this is going, rust is going to come through within a couple years after paint. This is just the tip of the iceberg. You need to cut the entire sail panel off and blast behind there. I'm sorry to say, but this is not the correct way to be doing a restoration on a 914 |
KBMC1304 |
Apr 28 2021, 11:30 AM
Are you brazing it all? I hope this is not the case!! This needs to be done properly! The way this is going, rust is going to come through within a couple years after paint. This is just the tip of the iceberg. You need to cut the entire sail panel off and blast behind there. I'm sorry to say, but this is not the correct way to be doing a restoration on a 914 I cut the rust panel at the limit + 1MM on both sides. I use primer filler pro before welding the new part. |
Lo-Fi Version | Time is now: 17th May 2024 - 05:54 PM |
