Powder coat or paint muffler? |
Tdskip |
May 15 2021, 09:15 AM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
I have a muffler that needs to be protected before it goes back on a 2 L car, I’ve had a good experience with high temp powder coating manifolds on other cars, King to hear what you all think about doing that for a muffler.
Thanks! |
Shivers |
May 15 2021, 09:25 AM
Senior Member Group: Members Posts: 2,373 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
https://madisonpowdercoating.com/ceramic-co...0and%20mufflers.
I'm sure you can find someone here that can do this for you. |
Tdskip |
May 15 2021, 09:30 AM
https://madisonpowdercoating.com/ceramic-co...0and%20mufflers. I'm sure you can find someone here that can do this for you. Good morning and thanks for the fast response. I have a shop that I use for that, so we’re thinking the same thing. |
Olympic 914 |
May 15 2021, 09:49 AM
Group: Members Posts: 1,668 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Had a local Powdercoat company do mine.
The highest temp powder they had was 800 deg and only in a satin black. Its holding up good so far but has mellowed out to a charcoal grey color. it faded evenly though so not a real problem. But something to keep in mind. Guy I know had the pipes on his Harley done in the same stuff, He didn't like the color change. Ceramic may be better. |
Krieger |
May 15 2021, 11:24 AM
Advanced Member Group: Members Posts: 4,710 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
Why don't you ceramic coat it? It will last a long time.
euro911 |
May 15 2021, 01:15 PM
Why don't you ceramic coat it? It will last a long time. Question ... do they, or can they dunk the muffler to coat the inside? ... or just the exterior? (IMG:style_emoticons/default/unsure.gif) ... asking for a friend (IMG:style_emoticons/default/laugh.gif) |
Jett |
May 15 2021, 02:21 PM
Senior Member Group: Members Posts: 1,638 Joined: 27-July 14 From: Seattle Member No.: 17,686 Region Association: Pacific Northwest |
We use ceramic coating, as everyone has mentioned.. it looks good, and lasts a long time.
Triaddave |
May 15 2021, 07:30 PM
Member Group: Members Posts: 244 Joined: 31-December 03 From: olympia,wa Member No.: 1,478 |
The powder coat will burn off. Best to ceramic coat
Lucky9146 |
May 15 2021, 08:42 PM
Always Wanted A Bigger Go Cart Group: Members Posts: 1,613 Joined: 22-September 14 From: Poway California Member No.: 17,942 Region Association: Southern California |
We use ceramic coating, as everyone has mentioned.. it looks good, and lasts a long time. @Jett That looks fantastic! Sent you a PM I have used ceramic and recommend it, go with Jett's Look (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/white914.jpg) |
Maltese Falcon |
May 15 2021, 09:58 PM
Advanced Member Group: Members Posts: 4,641 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
914_7T3 |
May 15 2021, 11:04 PM
Please forgive me, I'm new to all of this! Group: Members Posts: 1,853 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California |
Ceramic Coat
barefoot |
May 16 2021, 06:01 AM
Senior Member Group: Members Posts: 1,273 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
Ceramic is best if bling if what you're after. However rattle can hi temp paint works very well also
VaccaRabite |
May 17 2021, 08:58 AM
En Garde! Group: Admin Posts: 13,443 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
After ceramic coating, you will be amazed at how much heat stays in the pipes and does not radiate out from the pipes! Going from coated steel headers to uncoated SSI exchangers was night and day different. First time I got under the car with the exchangers on it I burned the heck out of my hand they were so much hotter.
Zach |
Mark Henry |
May 17 2021, 09:15 AM
I had the high heat powdercoat on my bug mufflers, IMO it's crap, it didn't last long.
My MSDS /6 headers are real ceramic and the PO and I have 4 seasons on them, except for some stains they look brand new. Right now I'm trying a local guy, but I can't report anything other than they look good. |
914_teener |
May 17 2021, 02:19 PM
914 Guru Group: Members Posts: 5,197 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
After ceramic coating, you will be amazed at how much heat stays in the pipes and does not radiate out from the pipes! Going from coated steel headers to uncoated SSI exchangers was night and day different. First time I got under the car with the exchangers on it I burned the heck out of my hand they were so much hotter. Zach After ceramic coating, you will be amazed at how much heat stays in the pipes and does not radiate out from the pipes! This is a desirable effect of ceramic coating engine exhaust components. |
Mark Henry |
May 17 2021, 03:49 PM
After ceramic coating, you will be amazed at how much heat stays in the pipes and does not radiate out from the pipes! Going from coated steel headers to uncoated SSI exchangers was night and day different. First time I got under the car with the exchangers on it I burned the heck out of my hand they were so much hotter. Zach After ceramic coating, you will be amazed at how much heat stays in the pipes and does not radiate out from the pipes! This is a desirable effect of ceramic coating engine exhaust components. (IMG:style_emoticons/default/agree.gif) My MSDS headers I can grab and hang onto them in about 5 minutes after shut down. My tangerine T4 headers also run way cooler than stock HE's. I have a set of new NOS 2.0 HE's and banana that I just had ceramic coated, I'll take some temps when I get it installed mid summer. |
Lo-Fi Version | Time is now: 15th May 2024 - 12:59 PM |
