MN 914 build, Metal roof, Brembo brakes, Subaru EJ20TT, receiver hitch..., Info on my build |
914Subaru |
Sep 4 2021, 10:14 PM
Member Group: Members Posts: 59 Joined: 19-October 08 From: Duluth, MN Member No.: 9,667 Region Association: Upper MidWest |
FS
I purchased this car in 2008 working on it off and on and around 2018 it was far from done but could be driven. Around Christmas time I jokingly asked my son to go with me to the 2020 Red Rocks Classic and to my surprise he said yes. From that point on it was a mad dash to get it ready and I worked on it all the way up until we left getting 3 hours of sleep the night before. I even installed some temporary carpet when we stop at Estes park for the night. 3,500 miles later I would have to say that was one of my all time favorite weeks of my life. The temporary carpet is still in the car with a few other loose ends to finish up. The car is an amazing drive that zips around effortlessly. Original fuchs wheels: 16 x 6 front 205/55R16 and 16 x 7 rear 225/50R16. Calipers are Porsche 944 Turbo Brembo. Rear brake rotors and E brake 911 and 911 center mount E-brake handle. Front rotors are AP Racing 28mm x 328mm Weltmeister adjustable front sway bar 19 mm diameter. Rear sway bar included but not installed. 944 CV joints, 911 stub shafts with T2 axles. Transmission Subaru five speed with coupler and rear cover. Shift lever is Subaru with direct mechanical linkage rod. Subaru twin turbo engine, Japan only, EJ 20 TT, completely stock(280hp) The conversion utilizes all Subaru mounts including the top link eliminating vibration and noise. Metal roof that stiffens and strengthens the chassis. Rear pinch welds on the B-pillar have been removed and fully TIG welded. The transition from the B pillar to the rear quarters is the shape you get after removing the trim and pinch weld. The rear quarters are original metal that has been re-shaved for wider tires and to retain the narrow body look. To save weight it has a fiberglass hood, trunk lid and rear bumper. 1-1/4 receiver hitch with cargo box mounts and cargo box included. Originally a Texas car. Paint is base clear to the original metalic silver color. Johnny’s Autobody in Wisconsin did the final bodywork and paint. Picture of the fresh paint This is what it looked like when I first got it home. The original car looks a lot better than it really was. Typical truck rust repair and also the entire floor. I was able to move the rotisserie in and out of the garage which was very handy for sandblasting. It was made entirely from stuff I purchased at an auction for about $40. The rotisserie is no more other that I still have the casters. 1987 Porsche 944 Turbo Calipers Short Drive Video https://www.youtube.com/watch?v=EMiUI5mhW50 Walk around video next to a 944 https://www.youtube.com/watch?v=SNIYW9a19X8 Cold Start Video https://www.youtube.com/watch?v=6jXnhQcwF4Y Shifter Video https://www.youtube.com/watch?v=gP73spLjl5I Attached image(s) |
914Subaru |
Sep 8 2021, 08:29 AM
I upgraded the CV joints to handle the 280hp. I used;
911 stub axles and flanges. 944 turbo CV joints. 914 Wheel bearing. I am 99% sure the axles are from a VW bay window bus. Custom made bearing spacer. I made the Subaru to Porsche CV joint adapters. Now you can just buy them and that is what I recommend. 944 Turbo Calipers (Brembo) Front Rotors AP Racing 28mm x 328mm Rear Rotors 911 Future Project: The front brake setup will only accept 16x6 Fuchs, wheel spacers are required to space the wheel away from the caliper. To fit 16x7 Fuchs or 15x7 phone dialers the option I was considering was to build up another set of struts with Porsche 911 Carrera 84-89 rotors, Stomski Racing adapter, Boxster calipers 986.351.421.03 / 986.351.422.03 and 911 strut with 3.5 c/c caliper bolt spacing. A future maybe brake project At this point I would maybe go Safari with a set of Elephant Racing lifted struts. Interior is a work in progress. Aluminum fuel cell has been fitted with the Subaru in-tank fuel pump, fuel level sensors and vent valve with rollover check valve. A baffle was added to create a small chamber for the pump pickup. Subaru pump assemblies have a jet pump on the return line and that is used to pull fuel from the main area to the smaller baffled area of the pump so the pump doesn't get starved from fuel when the tank runs low. Also shown in picture is the Subaru hydraulic clutch master cylinder and Subaru brake master cylinder. Subaru STI hanging pedals, power brakes and hydraulic clutch all work flawless. Note the calipers are Porsche 944 turbo and that car has power brakes also so using power brakes with these calipers works well. |
Lo-Fi Version | Time is now: 17th May 2024 - 07:19 PM |
