| bbrock |
Sep 11 2021, 10:46 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains
After about 1,700 miles of driving my freshly restored car with rebuilt engine, I’ve decided I’ve had my fun with Weber carbs and distributor-based ignition and am ready to step up to modern EFI and coil on plug ignition. Even with the jetting that came out of the box leaving the carbs running rich, the performance has been fantastic. What is not fantastic is the garage stinking of gasoline, no compensation for altitude, and being generally too fiddly to set up for my taste. My trials with the ignition are documented in another thread. Yes, I know a 1-2-3 would solve those problems but for the money, I’d rather invest in modern COP ignition as part of an EFI upgrade.
My goal is a smooth, efficient, and reliable street machine that I can drive from sea level to 11,000 ft. without starving or choking on fuel. Efficiency is at least as important as performance. As long as I can get at least the stockish 100 hp, I’ll be happy and beyond that, I’d like to wring as many mpg out as possible. The engine is a mostly stock euro-spec 2L engine. The only mod is a fairly mild Elgin 6048 camshaft with 256 duration for the carbs. A source of pride of this build is this custom 911/914-6 inspired air cleaner I made which I think looks cool and really silences the carbs. ![]() Now for the questions: • Single throttle body or ITB? I think I’ve made a decision but still interested in thoughts. I was thinking about welding injector bungs onto the carb manifolds and using my carbs as throttle bodies. The main appeal is that I would keep my cool air cleaner to make the other kids jealous. However, it seems the stock throttle body would greatly simplify the conversion. Also, even though the custom intake is designed to allow access for servicing and easy air filter replacement, it does crowd an already crowded engine bay and makes working in there just that much more of a challenge. My stock TB needs some TLC and might have to be sent for professional refurbishing. I think I could sell my carb setup to cover that cost but not sure. The upshot is that I’ve all but decided to go back to the stock TB, but curious what others think. • N Alpha, Speed Density, or MAF? I’ve been reading up on this and think I understand pros and cons, but still a little confused about sensors needed. With my efficiency goal, I think MAF is the way to go. It looks to me that cutting off the tube connecting the stock air cleaner to the TB and replacing it with a MAF could be a really slick way to add MAF in stealth fashion. Has anyone done this? If not, how does one find the right MAF to use? Other than dimensions, what else needs to be considered? Another question is about MAP + MAF vs MAF only. I’m a little confused about advantages or when a MAP sensor is needed if you have a MAF. • Barometric correction – this is an important feature for my location, but the hardware needed to implement it is a little confusing. It seems like if you are running a MAP, then barometric correction is obtained by adding a second pressure sensor (another MAP?) to read reference atmospheric pressure to make corrections to the fuel mixture. How does it work with MAF? Do you only need one pressure sensor to read atmosphere? Or do you still need to reference it against manifold pressure? I assume a lot of this is done in the software but I haven’t looked to far into the tuning part yet. I’m more trying to figure out a shopping list for parts at this point. • Anyone running a CAM sync and sequential spark and injection? Again with the efficiency goal, this is appealing. Looks like Mario is working on a new version which isn’t available yet, are there alternatives available? It seems people say you still need a crank position sensor even with a cam sensor in the mix. It isn’t entirely clear why though. Lastly, and this is mostly just curiosity, but is it correct to think that the lifespan (in miles) of spark plugs are cut in half with wasted spark? I have many more questions but this is already too long so will save them for later. TIA |
| VaccaRabite |
Oct 12 2021, 10:22 AM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,837 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
I worry that the larger picture of building an EFI for a 4 banger aircooled motor is getting lost in the weeds here.
These aren't exactly smooth running motors to begin with, and the engine bay is somewhat open to the elements. I'd reconsider using the Microquirt and adding some simplicity back into your equation. The operational differences between wasted spark and individually controlled plugs isn't going to be noticeable when you are driving the car, but will make it more challenging to build and tune - increasing the time before you are back to driving the car again. Zach |
| bbrock |
Oct 12 2021, 11:10 AM
I worry that the larger picture of building an EFI for a 4 banger aircooled motor is getting lost in the weeds here. Was it that obvious? (IMG:style_emoticons/default/av-943.gif) You've probably given the best advice of all here, but I'm already down the rabbit hole. Here's the view from my window today so I'm already done driving until the middle of June '22. I need something to occupy myself on these long winter nights (IMG:style_emoticons/default/biggrin.gif) |
bbrock Going to Megasquirt Sep 11 2021, 10:46 AM
BeatNavy Brent, you'll enjoy the challenge and learning... Sep 11 2021, 01:43 PM
Morph914 Brent, I will be watching this closely as I may sw... Sep 11 2021, 02:13 PM
Chris914n6 I'd run Speeduino over MS as it's a newer ... Sep 11 2021, 02:44 PM
JamesM
I'd run Speeduino over MS as it's a newer... Sep 11 2021, 04:53 PM
Superhawk996 Just sayin' . . . .
https://thedubshop.com/du... Sep 11 2021, 03:10 PM
r_towle Buy ITBs that look like carbs
Buy manifolds with i... Sep 11 2021, 03:22 PM
JamesM Throttle Body? Given you already have the cool ai... Sep 11 2021, 04:30 PM
930cabman
Throttle Body? Given you already have the cool a... Sep 11 2021, 04:44 PM
JamesM
Looks awfully confusing. Is the Weber setup that ... Sep 11 2021, 04:56 PM
Montreal914 Will follow this thread with great interest. :pop... Sep 11 2021, 05:02 PM
GregAmy I go to all the trouble to write this stuff up...
... Sep 11 2021, 06:03 PM
bbrock
I go to all the trouble to write this stuff up...... Sep 11 2021, 06:41 PM
JamesM Mario at the dubshop makes some awesome parts and ... Sep 12 2021, 12:18 AM
GregAmy And I have read ALL of it! In fact, I blame y... Sep 12 2021, 09:57 AM
bkrantz Brent, welcome to the club. You may make progress... Sep 11 2021, 07:21 PM
bbrock
Brent, welcome to the club. You may make progres... Sep 11 2021, 08:15 PM
Montreal914 In case you haven't seen/read my partial adven... Sep 11 2021, 08:59 PM
moto914 Hi. Running Microsquirt with ITBs here.
The kno... Sep 12 2021, 08:47 AM
bbrock @[url=http://www.914world.com/bbs2/index.php?showu... Sep 12 2021, 10:49 AM
JamesM
[b]@[url=http://www.914world.com/bbs2/index.php?s... Sep 13 2021, 04:46 PM
bbrock
I still think you are adding needless complexity ... Sep 13 2021, 07:51 PM
JamesM
Sadly, the more complicated it looks, the more I... Sep 13 2021, 11:07 PM
Superhawk996
Sadly, the more complicated it looks, the more I... Sep 14 2021, 05:38 AM
bbrock
@[url=http://www.914world.com/bbs2/index.php?show... Sep 15 2021, 08:08 AM
Superhawk996
I tried, but can't let this slide. . . .
... Sep 15 2021, 08:41 AM
Montreal914 For ITBs, you have probably read that some people ... Sep 12 2021, 12:25 PM
bbrock Good to know about the MAP sensors. Looks like mo... Sep 13 2021, 08:26 AM
GregAmy
Good to know about the MAP sensors. Looks like m... Sep 13 2021, 10:28 AM
falcor75 I went the ITB route for my 2.3 but my car isnt bu... Sep 13 2021, 11:14 PM
GregAmy What I'm not happy about is the low idle at st... Sep 14 2021, 06:00 AM
jd74914
What I'm not happy about is the low idle at s... Sep 14 2021, 07:10 AM
ClayPerrine If you don't have manifold vacuum at idle, but... Sep 14 2021, 06:54 AM
VaccaRabite James is the man, and I'd take his thoughts as... Sep 14 2021, 08:13 AM
bbrock @[url=http://www.914world.com/bbs2/index.php?showu... Sep 14 2021, 12:05 PM
JamesM
[b]@[url=http://www.914world.com/bbs2/index.php?s... Sep 14 2021, 01:08 PM
Montreal914
[b]@[url=http://www.914world.com/bbs2/index.php?s... Sep 14 2021, 09:09 PM
bbrock
WOW! Really impressive! :worship:
...T... Sep 14 2021, 10:36 PM
ClayPerrine
But... yeah. I think I'm going ahead with se... Sep 16 2021, 06:21 AM
Superhawk996
Check out the MS3 Pro Module.
Clay
:yikes: ... Sep 16 2021, 07:39 AM
bbrock
[quote name='ClayPerrine' post='2945887' date='Se... Sep 16 2021, 08:24 AM
jd74914
But... yeah. I think I'm going ahead with se... Sep 16 2021, 09:08 AM
Mike D. Ahhh, yes! The beginning of another 7 year thr... Sep 15 2021, 10:31 PM
jd74914 They're certainly right in terms of the poor s... Sep 16 2021, 08:52 AM
Superhawk996
Modern injectors are objectively better. . . . I... Sep 16 2021, 11:38 AM
bbrock
[quote name='jd74914' post='2945908' date='Sep 16... Sep 16 2021, 05:00 PM
bbrock An additional 800 miles of seat time in my car has... Oct 9 2021, 08:44 AM
Superhawk996
- Do I need a crank sensor? To go full sequentia... Oct 9 2021, 09:07 AM
JamesM
If you want to run... Oct 9 2021, 04:53 PM
nditiz1 I have only seen the crankfire setup that McMark w... Oct 9 2021, 01:15 PM
bbrock
I have only seen the crankfire setup that McMark ... Oct 9 2021, 01:51 PM
Frank S
I have only seen the crankfire setup that McMark... Oct 9 2021, 03:56 PM
ClayPerrine Add a 36-1 wheel behind the fan replacing the spac... Oct 9 2021, 04:56 PM
bbrock This is all great info everyone! Looks like I... Oct 9 2021, 06:17 PM
JamesM
You raise an interesting question about injector... Oct 10 2021, 01:15 AM
bbrock Okay, here's some fun with math. I calculated ... Oct 10 2021, 12:20 PM
Superhawk996 I didn't check your math. I'm impressed th... Oct 10 2021, 04:15 PM
bbrock
I didn't check your math. I'm impressed t... Oct 10 2021, 04:18 PM
bbrock Found a major error in my calculations. I accident... Oct 10 2021, 07:03 PM
JamesM
Found a major error in my calculations. I acciden... Oct 11 2021, 02:21 AM
bbrock
With larger injectors you lose some level of prec... Oct 11 2021, 11:59 AM
jd74914
With larger injectors you lose some level of pre... Oct 11 2021, 12:38 PM
bbrock
I'm not sure this is really a 'code' ... Oct 11 2021, 02:08 PM
JamesM Im just going to leave this here to give you more ... Oct 12 2021, 12:33 PM
jd74914 Pulses of ~10 ms aren't too bad.
But...
I d... Oct 11 2021, 03:00 PM
bbrock
But...
I ... Oct 11 2021, 04:04 PM
Frank S Fuel Injector Size:
https://thedubshop.com/pages.... Oct 11 2021, 03:49 PM
bbrock
Fuel Injector Size:
https://thedubshop.com/pages... Oct 11 2021, 07:45 PM
Frank S
I looked into the daughter board and you still ha... Oct 11 2021, 10:55 PM
JamesM It sounds like you really want to go with the 36lb... Oct 12 2021, 01:17 AM
jd74914
I've looked at Mario's and a couple other... Oct 12 2021, 07:18 AM
jd74914
Good info!
I actually have a toothed cam w... Oct 12 2021, 07:08 AM
crash914 Call Mario.
Ask about the MAX EFI. will integrat... Oct 11 2021, 04:06 PM
bbrock Well no reason to stop this insanity now, so here... Oct 11 2021, 07:24 PM
Superhawk996 You're becoming a real Geek. :lol:
I've... Oct 12 2021, 08:13 AM
bbrock You guys are awesome! :trophy:
I was reading... Oct 12 2021, 08:38 AM
Superhawk996
Here's the view from my window today so I... Oct 12 2021, 01:54 PM
JamesM
I worry that the larger picture of building an EF... Oct 12 2021, 12:04 PM
bbrock
I worry that the larger picture of building an E... Oct 12 2021, 12:35 PM
bbrock
Im just going to leave this here to give you more... Oct 12 2021, 12:36 PM
KELTY360 Obviously, while the snow is on the ground you nee... Oct 12 2021, 01:36 PM
bbrock
Obviously, while the snow is on the ground you ne... Oct 12 2021, 01:57 PM
KELTY360
Obviously, while the snow is on the ground you n... Oct 12 2021, 02:00 PM
bbrock
:chair: Don't be such a cynic. With all th... Oct 12 2021, 02:31 PM
Superhawk996
BTW... :idea:
see PM Oct 12 2021, 02:37 PM
jd74914
That question was for the collective. I expected ... Oct 13 2021, 07:24 AM
ClayPerrine If you want distributorless ignition, there is an ... Oct 13 2021, 06:28 AM
Frank S Had a chance to check some of my data.
With the 21... Oct 14 2021, 09:58 AM
bbrock
With the 2... Oct 14 2021, 05:49 PM
JamesM
With the ... Oct 15 2021, 10:15 AM
bbrock
[quote name='bbrock' post='2952564' date='Oct 14 ... Oct 15 2021, 06:21 PM
Frank S
Still not sure how much precision is being sacrif... Oct 15 2021, 11:58 PM
JamesM
Still not sure how much precision is being sacrif... Oct 16 2021, 10:56 PM
Frank S And here how it looks like if you integrate the MS... Oct 14 2021, 10:03 AM
bbrock
And here how it looks like if you integrate the M... Oct 14 2021, 05:36 PM
Frank S
And here how it looks like if you integrate the ... Oct 15 2021, 01:57 AM
bbrock I've been wondering if there is an advantage i... Oct 16 2021, 10:42 PM
JamesM
I've been wondering if there is an advantage ... Oct 16 2021, 11:04 PM![]() ![]() |
Lo-Fi Version | Time is now: 21st January 2026 - 12:18 PM |
