Group Buy: Announcing PMB DirectFit Brake Lines, ***Pricing Good Through January 15th*** |
Eric_Shea |
Dec 27 2021, 04:59 PM
PMB Performance Group: Admin Posts: 19,274 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
PMB Performance DirectFit™ DOT Stainless Brake Line Specifications Built to the Following Standards • DOT - FMVSS 106 • SAE - J1401 • ISO - 3996 • GB - 16897-2010 Composition • PTFE (Teflon®) inner lining • Braided 304 Stainless Steel Covering • Clear UV Protective PVC Outer Cover • Steel fittings: Triple Zinc and Nickel finishes Features • High-performance ultra-low expansion rate of 0.000295cc/ft. at 4,000 psi (ZeroFlex™) • ZeroFlex™ offers extremely precise pedal modulation and feel • DirectFit™ OE designed fittings and vehicle specific lengths accommodate ease of installation • Tough UV protective PVC outer coating to protect the braid and resist impact and abrasions • Protective fitting caps reduce fatigue • Tested to exceed DOT standards • All lines pressure tested to 4250 psi • Ultra-high burst pressure rated to 12,550-13,500 psi • Extreme temperature resistance -70℃/-94°F to +260℃/500°F • Compatibility: for all non-petroleum brake fluids DOT3, DOT4, DOT4 LV, DOT5.1 Lifetime Warranty on all Stainless Steel Line Sets Group Buy Pricing: $99.00 (914World members only weigh in on this thread, not available for this price online) ***Pricing Good Through January 15th*** PMB Performance DirectFit™ DOT Rubber Brake Line Specifications Built to the Following Standards • DOT - FMVSS 106 • SAE - J1401 • ISO - 3996 • GB - 16897-2010 Unique 5-Layer Composition • EPDM Inner Layer (excellent resistance to non-petroleum-based fluids)) • Polyester (OET) Inner Braid • EPDM Middle Interleaf (prevents abrasion) • PVA Outer Braid (provides strong bonding between layers) • EPDM Outer Layer for Excellent Ozone and UV Resistance Features • High-performance low expansion rate of 0.14cc/ft. at 1,500 psi (LowFlex™) • LowFlex™ offers extremely precise pedal modulation and feel over other rubber lines • DirectFit™ OE designed fittings and vehicle specific lengths accommodate ease of installation • Tough UV and Ozone protective EPDM outer coating • Tested to exceed DOT standards • Unique 5-Layer Composition • 10-Year Warranty • Extreme temperature resistance -50℃/-122°F to +121℃/250°F • Compatibility: for all non-petroleum brake fluids DOT3, DOT4, DOT4 LV, DOT5.1 10-Year Warranty on all Rubber Line Sets Group Buy Pricing: $39.95 (914World members only weigh in on this thread, not available for this price online) ***Pricing Good Through January 15th*** |
Jack Standz |
Dec 29 2021, 11:53 AM
Member Group: Members Posts: 272 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None |
I'll take an early stainless set and an early rubber set.
Both sets with washers please. |
Lo-Fi Version | Time is now: 2nd May 2024 - 10:24 AM |
