6 Pages V < 1 2 3 4 5 > »
Closed TopicStart new topic
> Group Buy: Announcing PMB DirectFit Brake Lines, ***Pricing Good Through January 15th***
DaveB
post Dec 28 2021, 11:21 PM
Post #41
I'll take a set of rubber lines.
DaveB
Rleog
post Dec 29 2021, 05:23 AM
Post #42
I have a ‘74 914/4 with stock rear and ‘88 Carrera entire front crossmember/suspension.
I’d like a set of stainless lines for this. Thanks a lot.
Zimms
post Dec 29 2021, 07:49 AM
Post #43
One set of Stainless, please
TX914
post Dec 29 2021, 09:00 AM
Post #44
Alan-B
I'll take one set of SS lines for a 76 please.
Thanks!
akp2002
post Dec 29 2021, 10:20 AM
Post #45
I would like a set of the 914 SS lines please.
mlmgm
post Dec 29 2021, 10:49 AM
Post #46
Eric,
Two SS sets for 914’s please
Thanks, Mark
burlybryan
post Dec 29 2021, 11:23 AM
Post #47
Eric,
I would like a set of rubber lines for my '74 please.
Thanks!
mb911
post Dec 29 2021, 11:29 AM
Post #48
I would like a set of rubber ones
Jack Standz
post Dec 29 2021, 11:53 AM
Post #49
I'll take an early stainless set and an early rubber set.
Both sets with washers please.
troth
post Dec 29 2021, 12:03 PM
Post #50
Better put a rubber set aside for the U-boat.
-Tom
Hollybrook
post Dec 29 2021, 12:08 PM
Post #51
A set of SS please: 1973 914-4 1.7L.
fiacra
post Dec 29 2021, 01:10 PM
Post #52
Person.Woman.Man.Camera.TV. = MCI
I'll take a rubber set for my 1975 1.8. Thanks!
markhoward
post Dec 29 2021, 01:51 PM
Post #53
Would like 2 SS sets. One is for a standard 78 911sc while the other is for a 76 914 with stock rear calipers along with 3” aluminum brembos on T struts up front. Guidance on what to get appreciated.
Mike Bellis
post Dec 29 2021, 03:42 PM
Post #54
Resident Electrician
I'm in if they fit my 930 calipers. Do they?
Eric_Shea
post Dec 29 2021, 06:01 PM
Post #55
PMB Performance
QUOTE(Mike Bellis @ Dec 29 2021, 02:42 PM) *
Great question Mike, short answer - Yes.
This is worth saying because we're getting a lot of these questions:
Calipers do not matter for the soft lines. These lines go between the body and the strut up front and the body and the control arm in the rear. What matters is the strut and the control arm mounting tabs.
Early cars used the same front soft line as the 911, 911SC, 930 and 911 Carrera. The part number is 901 355 632 02. It's longer that the rear line but, the rear line on an early car uses the same 14mm end and spring for the control arm tab.
Early cars will use this clip on the body tab:
And this spring on the strut tab:
Here's a early/or 911 strut as an example:
If you have upgraded to 911 struts up front (and many have) you'll want an early set.
Later cars used a larger 16mm end with the clip journal in it on the strut. They in turn use the same clip as the body tab so both ends of the larger 16mm ends for these clips.
Here's that clip again. On later cars this will be on the strut as well as the body tab:
Here's a few shots of them on a later car:
Now on to the rear which is essentially the same. The early cars have a tab on the control arm which has the precision 14mm hole for the early line.
Here's an early 914-6 rear control arm tab (same as an early 914-4). These have the 14mm precision holes and use the springs:
Later cars have the 16mm hole and slotted tab. The body tabs both front and rear do not change for all cars. Only the control arm and strut tabs change.
Here's a late 914-4 rear control arm. These take the later 16mm hose ends with the clip journal:
Here's where it becomes important. If you have 911 struts up front and later control arms in the rear you'll want to order an "Early" kit and let Holly know what your configuration is. We will make a note and shipping will include (2) 13.5mm washers to center your rear lines on the tab. You will also need (2) springs (Part #803 611 715) which can be had for a couple bucks online.
Here's a picture of an early rear line with the washer on a late arm:
Bottom line is calipers don't matter - Struts and control arms do. (IMG:style_emoticons/default/wink.gif)
Hope that helps,
Eric
Mike Bellis
post Dec 29 2021, 06:15 PM
Post #56
How do I buy?
Early SS kit.
special link? Crank call PMB?
Eric_Shea
post Dec 29 2021, 06:35 PM
Post #57
PMB Performance
QUOTE(Mike Bellis @ Dec 29 2021, 05:15 PM) *
How do I buy?
Early SS kit.
Holly will reach out via PM (IMG:style_emoticons/default/wink.gif)
pvollma
post Dec 30 2021, 07:26 PM
Post #58
I'd like a set of stainless steel for a 76. Thanks!
71six
post Dec 31 2021, 03:27 PM
Post #59
I would like a set of the rubber lines for a 1973 911S please. Last winter my 1973 914 2.0 received PMB restored calipers and new brake lines and my 1971 914-6 received PMB restored rear calipers and Brembo front calipers and new brake lines. This winter the 911S will receive the same treatment to complete the trio.
Thanks,
Mark
Retired tech
post Jan 1 2022, 04:04 PM
Post #60
I’m in for a set of early rubber lines and washers if possible
Have 73 914 but has early 911 struts with spring clip type retainer not u clip
Thanks
- Lo-Fi Version Time is now: 17th October 2026 - 11:08 AM
