| PaulFV8 |
Jan 2 2022, 01:43 PM
Member ![]() ![]() Group: Members Posts: 86 Joined: 2-August 20 From: Virginia, USA Member No.: 24,562 Region Association: None
I’m in for a set SS, I will use 911 front struts
Thanks |
| jim_hoyland |
Jan 2 2022, 04:52 PM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,144 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
Order submitted for two sets of rubber hoses. Thanks
| jwinner |
Jan 3 2022, 06:33 PM
Newbie ![]() Group: Members Posts: 23 Joined: 5-August 14 From: Milwaukee, WI Member No.: 17,736 Region Association: Upper MidWest |
PMB Performance DirectFit™ DOT Stainless Brake Line Specifications Built to the Following Standards • DOT - FMVSS 106 • SAE - J1401 • ISO - 3996 • GB - 16897-2010 Composition • PTFE (Teflon®) inner lining • Braided 304 Stainless Steel Covering • Clear UV Protective PVC Outer Cover • Steel fittings: Triple Zinc and Nickel finishes Features • High-performance ultra-low expansion rate of 0.000295cc/ft. at 4,000 psi (ZeroFlex™) • ZeroFlex™ offers extremely precise pedal modulation and feel • DirectFit™ OE designed fittings and vehicle specific lengths accommodate ease of installation • Tough UV protective PVC outer coating to protect the braid and resist impact and abrasions • Protective fitting caps reduce fatigue • Tested to exceed DOT standards • All lines pressure tested to 4250 psi • Ultra-high burst pressure rated to 12,550-13,500 psi • Extreme temperature resistance -70℃/-94°F to +260℃/500°F • Compatibility: for all non-petroleum brake fluids DOT3, DOT4, DOT4 LV, DOT5.1 Lifetime Warranty on all Stainless Steel Line Sets Group Buy Pricing: $99.00 (914World members only weigh in on this thread, not available for this price online) ***Pricing Good Through January 15th*** PMB Performance DirectFit™ DOT Rubber Brake Line Specifications Built to the Following Standards • DOT - FMVSS 106 • SAE - J1401 • ISO - 3996 • GB - 16897-2010 Unique 5-Layer Composition • EPDM Inner Layer (excellent resistance to non-petroleum-based fluids)) • Polyester (OET) Inner Braid • EPDM Middle Interleaf (prevents abrasion) • PVA Outer Braid (provides strong bonding between layers) • EPDM Outer Layer for Excellent Ozone and UV Resistance Features • High-performance low expansion rate of 0.14cc/ft. at 1,500 psi (LowFlex™) • LowFlex™ offers extremely precise pedal modulation and feel over other rubber lines • DirectFit™ OE designed fittings and vehicle specific lengths accommodate ease of installation • Tough UV and Ozone protective EPDM outer coating • Tested to exceed DOT standards • Unique 5-Layer Composition • 10-Year Warranty • Extreme temperature resistance -50℃/-122°F to +121℃/250°F • Compatibility: for all non-petroleum brake fluids DOT3, DOT4, DOT4 LV, DOT5.1 10-Year Warranty on all Rubber Line Sets Group Buy Pricing: $39.95 (914World members only weigh in on this thread, not available for this price online) ***Pricing Good Through January 15th*** Great deal, thank you Eric/PMB! Please put me down for a set of stainless DirectFit lines for my 914-6 conversion (911SC front, 914 rear) with washers. Thank you, James Winner |
| Eric_Shea |
Jan 11 2022, 12:44 PM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
(IMG:style_emoticons/default/icon_bump.gif) wrapping it up this week gang. Thank you to everyone who participated in the buy. Saturday is the last day. (IMG:style_emoticons/default/smilie_pokal.gif)
| Literati914 |
Jan 11 2022, 01:43 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,392 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
If I can still get in on this ... Id take two sets of rubber lines for later struts. thx.
| gandalf_025 |
Jan 12 2022, 09:38 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,534 Joined: 25-June 09 From: North Shore, Massachusetts Member No.: 10,509 Region Association: North East States |
I’m in for a set of stainless for a
70-6… |
| rfinegan |
Jan 12 2022, 09:45 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,228 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region
I will take a set of SS line for my 75 914
-Thanks Robert |
| Chris H. |
Jan 12 2022, 10:37 AM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,108 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest
I'll take one set of rubber lines for a '75.
| ndfrigi |
Jan 12 2022, 11:19 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,993 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California
Thank you Eric! Got mine yesterday! Except still in the box and no need to check until I need to install them.
| beech4rd |
Jan 12 2022, 11:56 AM
Member ![]() ![]() Group: Members Posts: 349 Joined: 10-January 07 From: Highwoods, Saugerties, NY Member No.: 7,445 Region Association: North East States
I'm in for a set of rubber lines for a '73
Thank You! Chris |
| rhodyguy |
Jan 12 2022, 12:27 PM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,254 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
I mailed payment today. The meter is running on this one.
| dstudeba |
Jan 12 2022, 12:28 PM
Member ![]() ![]() Group: Members Posts: 122 Joined: 3-December 21 From: San Diego Member No.: 26,128 Region Association: Southern California
1 set of rubber lines for a 74 914 please
| JRust |
Jan 12 2022, 05:29 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,317 Joined: 10-January 03 From: Albany Oregon Member No.: 129 Region Association: Pacific Northwest
Hey Eric do you have the Hard lines available as well (The piece attaching the caliper to these lines) ? On my 73 resto I know I am missing at least one of the rear lines. So be nice to just do them all new. Already have your calipers for it
| Luke M |
Jan 12 2022, 05:54 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,612 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States
(IMG:style_emoticons/default/icon_bump.gif) wrapping it up this week gang. Thank you to everyone who participated in the buy. Saturday is the last day. (IMG:style_emoticons/default/smilie_pokal.gif) Hi Eric, Did you get my pm? |
| Alain V. |
Jan 13 2022, 06:58 AM
Member ![]() ![]() Group: Members Posts: 212 Joined: 15-March 13 From: Kansas Member No.: 15,655 Region Association: None
Oooops almost missed this.
I'll take a set of SS lines. send me a pm please, thanks! |
| johnswint3 |
Jan 13 2022, 08:26 AM
Newbie ![]() Group: Members Posts: 6 Joined: 17-September 18 From: Georgia Member No.: 22,496 Region Association: South East States
I'm in for a rubber set for a 74.
| Kansas 914 |
Jan 13 2022, 09:19 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,008 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains
Hi Eric,
I am in for 1 set of rubber lines for the Willow car. |
| jesse7flying |
Jan 13 2022, 09:26 AM
Member ![]() ![]() Group: Members Posts: 140 Joined: 9-August 16 From: Burleson,TX Member No.: 20,281 Region Association: None
I'm in for a set of rubber lines for my '71. Thx
Jesse |
| relentless |
Jan 13 2022, 04:12 PM
Member ![]() ![]() Group: Members Posts: 352 Joined: 1-April 07 From: Oregon Member No.: 7,636 |
Eric, I'd like a set in rubber for my 76. Thanks
| maf914 |
Jan 13 2022, 04:17 PM
Not a Guru! ![]() ![]() ![]() ![]() Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None
Eric, I would like one set of SS and one set of rubber for a stock 76. Thank you.
Lo-Fi Version | Time is now: 17th October 2026 - 11:52 AM |
