> Group Buy: Announcing PMB DirectFit Brake Lines, ***Pricing Good Through January 15th***
Eric_Shea
post Dec 27 2021, 04:59 PM
Post #81
PMB Performance
PMB Performance DirectFit™ DOT Stainless Brake Line Specifications
Built to the Following Standards
• DOT - FMVSS 106
• SAE - J1401
• ISO - 3996
• GB - 16897-2010
Composition
• PTFE (Teflon®) inner lining
• Braided 304 Stainless Steel Covering
• Clear UV Protective PVC Outer Cover
• Steel fittings: Triple Zinc and Nickel finishes
Features
• High-performance ultra-low expansion rate of 0.000295cc/ft. at 4,000 psi (ZeroFlex™)
• ZeroFlex™ offers extremely precise pedal modulation and feel
• DirectFit™ OE designed fittings and vehicle specific lengths accommodate ease of installation
• Tough UV protective PVC outer coating to protect the braid and resist impact and abrasions
• Protective fitting caps reduce fatigue
• Tested to exceed DOT standards
• All lines pressure tested to 4250 psi
• Ultra-high burst pressure rated to 12,550-13,500 psi
• Extreme temperature resistance -70℃/-94°F to +260℃/500°F
• Compatibility: for all non-petroleum brake fluids DOT3, DOT4, DOT4 LV, DOT5.1
Lifetime Warranty on all Stainless Steel Line Sets
Group Buy Pricing: $99.00 (914World members only weigh in on this thread, not available for this price online) ***Pricing Good Through January 15th***
PMB Performance DirectFit™ DOT Rubber Brake Line Specifications
• DOT - FMVSS 106
• SAE - J1401
• ISO - 3996
• GB - 16897-2010
Unique 5-Layer Composition
• EPDM Inner Layer (excellent resistance to non-petroleum-based fluids))
• Polyester (OET) Inner Braid
• EPDM Middle Interleaf (prevents abrasion)
• PVA Outer Braid (provides strong bonding between layers)
• EPDM Outer Layer for Excellent Ozone and UV Resistance
Features
• High-performance low expansion rate of 0.14cc/ft. at 1,500 psi (LowFlex™)
• LowFlex™ offers extremely precise pedal modulation and feel over other rubber lines
• Tough UV and Ozone protective EPDM outer coating
• Unique 5-Layer Composition
• 10-Year Warranty
• Extreme temperature resistance -50℃/-122°F to +121℃/250°F
10-Year Warranty on all Rubber Line Sets
Group Buy Pricing: $39.95 (914World members only weigh in on this thread, not available for this price online) ***Pricing Good Through January 15th***
Eric_Shea   Group Buy: Announcing PMB DirectFit Brake Lines   Dec 27 2021, 04:59 PM
NARP74   I'm in for a set of SS   Dec 27 2021, 05:39 PM
mepstein   I’ll take a set of rubber lines.   Dec 27 2021, 05:58 PM
iankarr   Beautiful work. Congrats, @Eric_Shea ! Thank...   Dec 27 2021, 06:04 PM
bossboy302   In for set of rubber lines-thx.   Dec 27 2021, 06:16 PM
treemn   One set of each style please. Thanks Eric!   Dec 27 2021, 07:38 PM
GermermanCarGuy   I'm in for a set of rubber lines. Thanks in ad...   Dec 27 2021, 08:27 PM
BillJ   Eric- i have my calipers on the way to you right n...   Dec 27 2021, 09:09 PM
Eric_Shea   Eric- i have my calipers on the way to you right ...   Dec 28 2021, 01:57 PM
Van B   Could you make some (stainless) for my 996 too?...   Dec 27 2021, 09:18 PM
Eric_Shea   Could you make some (stainless) for my 996 too?...   Dec 28 2021, 01:58 PM
Van B   Could you make some (stainless) for my 996 too?...   Dec 28 2021, 05:57 PM
Lg914   In for a set of stainless.   Dec 27 2021, 09:24 PM
Movin6   I'll take a set of SS for a 914-6! Please ...   Dec 27 2021, 09:35 PM
SKL1   Eric- one set SS for 914-6 front and rear caliper...   Dec 27 2021, 09:53 PM
ndfrigi   @Eric_Shea 1 set of rubber lines for 74 pls. than...   Dec 27 2021, 10:07 PM
jim_hoyland   Do the front 911M calipers take the same hose as t...   Dec 27 2021, 10:34 PM
Eric_Shea   Do the front 911M calipers take the same hose as ...   Dec 28 2021, 02:00 PM
djway   2 rubber pls   Dec 27 2021, 10:52 PM
dlee6204   I'll take a rubber set.   Dec 28 2021, 03:42 AM
Luke M   I'm in for a set of the late 914 SS lines but ...   Dec 28 2021, 08:15 AM
Eric_Shea   I'm in for a set of the late 914 SS lines but...   Dec 28 2021, 02:20 PM
Luke M   [quote name='Luke M' post='2970053' date='Dec 28 ...   Dec 28 2021, 02:43 PM
Eric_Shea   [quote name='Luke M' post='2970053' date='Dec 28...   Dec 28 2021, 02:50 PM
Luke M   [quote name='Luke M' post='2970128' date='Dec 28 ...   Dec 28 2021, 04:08 PM
Eric_Shea   Your saying that the early 914 fronts will work w...   Dec 28 2021, 05:03 PM
sixaddict   I am in for one set of rubber lines. Thanks   Dec 28 2021, 08:52 AM
rhodyguy   A set of rubber ones please. Are these to be order...   Dec 28 2021, 08:56 AM
Eric_Shea   A set of rubber ones please. Are these to be orde...   Dec 28 2021, 02:48 PM
branston   I'll take a set of rubber. How do we get paym...   Dec 28 2021, 09:12 AM
DRPHIL914   Eric, I am in for a set of SS lines for my ...   Dec 28 2021, 10:45 AM
Mikey914   Nice   Dec 28 2021, 11:04 AM
bobboinski   I'll take one set of rubber, please.   Dec 28 2021, 11:07 AM
Steve   I will take two rubber sets   Dec 28 2021, 11:46 AM
emerygt350   1 set of rubber please.   Dec 28 2021, 12:11 PM
JamesM   Sign me up for 3 stainless and 1 rubber!   Dec 28 2021, 02:03 PM
TJB/914   :D Eric, I'll take a rubber set for my 1974 ...   Dec 28 2021, 06:57 PM
DBF   I would like a set of rubber lines. New to the fo...   Dec 28 2021, 08:56 PM
roundtwo   Looking good! I'll take a set of the rubbe...   Dec 28 2021, 09:02 PM
914e   I can't decide on rubber or stainless so I wil...   Dec 28 2021, 10:47 PM
DaveB   I'll take a set of rubber lines. DaveB   Dec 28 2021, 11:21 PM
Rleog   I have a ‘74 914/4 with stock rear and ‘88 Car...   Dec 29 2021, 05:23 AM
Zimms   One set of Stainless, please   Dec 29 2021, 07:49 AM
TX914   I'll take one set of SS lines for a 76 please....   Dec 29 2021, 09:00 AM
akp2002   I would like a set of the 914 SS lines please.   Dec 29 2021, 10:20 AM
mlmgm   Eric, Two SS sets for 914’s please Thanks, M...   Dec 29 2021, 10:49 AM
burlybryan   Eric, I would like a set of rubber lines for my ...   Dec 29 2021, 11:23 AM
mb911   I would like a set of rubber ones   Dec 29 2021, 11:29 AM
Jack Standz   I'll take an early stainless set and an early ...   Dec 29 2021, 11:53 AM
troth   Better put a rubber set aside for the U-boat. -To...   Dec 29 2021, 12:03 PM
Hollybrook   A set of SS please: 1973 914-4 1.7L.   Dec 29 2021, 12:08 PM
fiacra   I'll take a rubber set for my 1975 1.8. Thank...   Dec 29 2021, 01:10 PM
markhoward   Would like 2 SS sets. One is for a standard 78 91...   Dec 29 2021, 01:51 PM
Mike Bellis   I'm in if they fit my 930 calipers. Do they?   Dec 29 2021, 03:42 PM
Eric_Shea   I'm in if they fit my 930 calipers. Do they? ...   Dec 29 2021, 06:01 PM
Mike Bellis   How do I buy? Early SS kit. special link? Crank...   Dec 29 2021, 06:15 PM
Eric_Shea   How do I buy? Early SS kit. special link? Cran...   Dec 29 2021, 06:35 PM
pvollma   I'd like a set of stainless steel for a 76. Th...   Dec 30 2021, 07:26 PM
71six   I would like a set of the rubber lines for a 1973 ...   Dec 31 2021, 03:27 PM
Retired tech   I’m in for a set of early rubber lines and washe...   Jan 1 2022, 04:04 PM
PaulFV8   I’m in for a set SS, I will use 911 front struts...   Jan 2 2022, 01:43 PM
jim_hoyland   Order submitted for two sets of rubber hoses. Than...   Jan 2 2022, 04:52 PM
jwinner   [b][size=4]PMB Performance DirectFit™ DOT St...   Jan 3 2022, 06:33 PM
Eric_Shea   :bump: wrapping it up this week gang. Thank you to...   Jan 11 2022, 12:44 PM
Luke M   :bump: wrapping it up this week gang. Thank you t...   Jan 12 2022, 05:54 PM
Eric_Shea   :bump: wrapping it up this week gang. Thank you ...   Jan 15 2022, 11:47 AM
Literati914   If I can still get in on this ... Id take two sets...   Jan 11 2022, 01:43 PM
gandalf_025   I’m in for a set of stainless for a 70-6…   Jan 12 2022, 09:38 AM
rfinegan   I will take a set of SS line for my 75 914 -Thank...   Jan 12 2022, 09:45 AM
Chris H.   I'll take one set of rubber lines for a '7...   Jan 12 2022, 10:37 AM
ndfrigi   Thank you Eric! Got mine yesterday! Except...   Jan 12 2022, 11:19 AM
beech4rd   I'm in for a set of rubber lines for a '73...   Jan 12 2022, 11:56 AM
rhodyguy   I mailed payment today. The meter is running on th...   Jan 12 2022, 12:27 PM
dstudeba   1 set of rubber lines for a 74 914 please   Jan 12 2022, 12:28 PM
JRust   Hey Eric do you have the Hard lines available as w...   Jan 12 2022, 05:29 PM
Eric_Shea   Hey Eric do you have the Hard lines available as ...   Jan 15 2022, 11:46 AM
Alain V.   Oooops almost missed this. I'll take a set of ...   Jan 13 2022, 06:58 AM
johnswint3   I'm in for a rubber set for a 74.   Jan 13 2022, 08:26 AM
Kansas 914   Hi Eric, I am in for 1 set of rubber lines for th...   Jan 13 2022, 09:19 AM
jesse7flying   I'm in for a set of rubber lines for my '7...   Jan 13 2022, 09:26 AM
relentless   Eric, I'd like a set in rubber for my 76. Tha...   Jan 13 2022, 04:12 PM
maf914   Eric, I would like one set of SS and one set of ru...   Jan 13 2022, 04:17 PM
jc73-914   Hi Eric, I’d like to get a set of SS please. Th...   Jan 13 2022, 10:11 PM
808 WRX   I would like one late rubber set. Thank you! ...   Jan 14 2022, 01:11 AM
seanpaulmc   Hello Eric - I will take a rubber set for a ...   Jan 14 2022, 07:35 AM
vitamin914   Please have Holly PM me to order a set of SS lines...   Jan 14 2022, 01:29 PM
915-1   One early rubber line set please...thanks!   Jan 14 2022, 05:46 PM
Rob914   One set of early stainless please.   Jan 14 2022, 06:43 PM
hex9145   i would like a set of the SS   Jan 14 2022, 09:08 PM
oldfartwithaporsche   Please put me down for a set of SS.   Jan 14 2022, 10:02 PM
gcrotvik   4 sets of the PMB Performance DirectFit™ DOT Rub...   Jan 14 2022, 10:23 PM
wes   One set of SS please and thanks Eric.   Jan 14 2022, 10:49 PM
dyw914   One set of rubber lines for a 73 please.   Jan 15 2022, 10:29 AM
Unpretentious   Eric, I’d liked to get a late rubber set. Than...   Jan 15 2022, 11:07 AM
RAX914   I’ll take a rubber set for a ‘72 please   Jan 15 2022, 11:10 AM
mb911   Ordered and paid. Thanks for offering these.   Jan 15 2022, 11:19 AM
Puebloswatcop   Eric, I'd like 1 set of SS lines for a '74...   Jan 15 2022, 11:24 AM
Eric_Shea   Eric, I'd like 1 set of SS lines for a '7...   Jan 15 2022, 11:40 AM
Eric_Shea   ***Last Day for the Group Buy Pricing Gang*** Tha...   Jan 15 2022, 11:42 AM
euro911   Eric ( @Eric_Shea ), sorry I'm late to the par...   Jan 15 2022, 01:57 PM
Closed TopicStart new topic
- Lo-Fi Version Time is now: 17th October 2026 - 11:52 AM
