Removing/Reinstalling Rear Axles |
Dunc |
Apr 18 2022, 11:34 AM
Newbie Group: Members Posts: 37 Joined: 4-July 14 From: Kennewick, WA Member No.: 17,590 Region Association: Pacific Northwest |
I tried searching for this item on the site, but did not find anything specific enough.
I want to remove the rear axles and replace them with some high performance axles/CVs. The Haynes and the Porsche Factory Manual indicate that removal includes driving the axle out of the swing arm. Must that be done in order to replace just the axles/CVs? It seems that merely removing the bolts at both inboard and outboard flanges should do the job. What am I missing? |
Shivers |
Apr 18 2022, 11:38 AM
Senior Member Group: Members Posts: 2,379 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
No. There are bolts like what you see on the cv by the trans, on the outer cv.
Optimusglen |
Apr 18 2022, 06:52 PM
Senior Member Group: Members Posts: 909 Joined: 26-February 16 From: Minneapolis Member No.: 19,709 Region Association: Upper MidWest |
No. There are bolts like what you see on the cv by the trans, on the outer cv. Right, there are bolts on the outer end identical to the inner end. One thing to take note of, the lock washers are one-time use. It's important to source new lock washers for all CV bolts, make sure the surfaces are clean and dry when reassembling, and torque to spec. |
914werke |
Apr 18 2022, 07:03 PM
"I got blisters on me fingers" Group: Members Posts: 10,066 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Thats the hard way.
Its easier to remove the .5 shaft complete. |
Dunc |
Apr 19 2022, 10:51 AM
Thanks you guys. I appreciate the help. Maybe take a shot at removal this weekend.
Dunc |
mgphoto |
Apr 19 2022, 02:16 PM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
bdstone914 |
Apr 19 2022, 03:55 PM
You may need to lower the control arm on the drivers to clear the starter. Remove the top nut on the shock to drop the trailing arm as needed.
Van B |
Apr 19 2022, 04:27 PM
Senior Member Group: Members Posts: 1,586 Joined: 20-October 21 From: Maryland Member No.: 26,011 Region Association: None |
What on earth are high performance axles for a 914? Are they painted red or something??
Dunc |
Apr 20 2022, 10:29 AM
What on earth are high performance axles for a 914? Are they painted red or something?? Ha. I hear ya! The car is Renegade conversion to a sb chev engine. It is my understanding that the CV's are the weak point in the drive train. So this is the mod I am making now until I update the entire drive train sometime in the future. |
Dunc |
Apr 20 2022, 10:43 AM
Van B |
Apr 20 2022, 11:48 AM
Ah, yeah I get it now lol!
Lo-Fi Version | Time is now: 18th May 2024 - 03:26 AM |
