| Mueller |
Aug 8 2005, 05:46 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
QUOTE(Stephane @ Aug 8 2005, 04:25 PM) Good job Andy! Two questions come to mind; 1st- Is the 944 stub & 914 stub axle the same overal lenght? 2nd- Does the 944 Cv have the same articulation as the 914 CV. Cheers Stephane these 944 axles are too long...see this thread for more info... 944 CV usage wtih 914 axles the 914 axle must be machined a little to work with the 944 CV (IMG:http://www.914world.com/bbs2/uploads/post-11-1123464006.jpg) |
| SirAndy |
Aug 8 2005, 05:54 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,473 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE(Mueller @ Aug 8 2005, 04:46 PM) the 914 axle must be machined a little to work with the 944 CV yes, but he asked about the "stub" axle ... (IMG:style_emoticons/default/wink.gif) the 944 Stub Axle is the same width as the 914 stub axle on the CV side of the wheel-bearing, the only difference is that the actual thread that sticks out on the wheel side (outside) seems to be a bit longer ... (IMG:style_emoticons/default/smile.gif) Andy PS: i don't have a 914 stubby handy, but i can take exact measurements once i get back to EASY ... |
| SirAndy |
Aug 8 2005, 05:56 PM
if by that you mean the degree of rotation, yes, the two CVs are completely identical, except the 944 CV is bigger ... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Andy |
| Stephane |
Aug 8 2005, 06:17 PM
Newbie ![]() Group: Members Posts: 45 Joined: 13-February 04 From: New Brunswick, Canada Member No.: 1,653 |
That's great, this sounds like a more affordable way to convert to 5 lug & I bet these parts are easier to find to.
Keep us posted please! Stephane |
| cha914 |
Aug 8 2005, 06:27 PM
MUSR 8 - 5lug conversion done wed - drive 500miles thrus ![]() ![]() ![]() Group: Members Posts: 739 Joined: 31-December 02 From: Austin, TX Member No.: 63 |
actually I think the 944 CV's will give you more articulation, if I remember correctly from my dune buggy research, the bug CV's are the worst (probably pretty close to the 914's), then the 944 and TIV bus CVs are next, and then the 930 CV's give the best articulation and will handle the most power...
here is a good site with the different sizes: http://www.blindchickenracing.com/How_to/C..._joints_101.htm Tony |
| sechszylinder |
Aug 12 2005, 12:12 PM
Member ![]() ![]() Group: Members Posts: 271 Joined: 9-April 03 From: /earth/europe/germany/berlin Member No.: 545 Region Association: None
hi Andy,
thats a really nice work !!! I've had the same idea to convert the rear to five lug using 944 parts . But i'm still looking for the right cvs. 944 rear axle Whats the partnumber of the 944 stub axles your using ? Mine came of a 944 turbo and have the part # 951.332.235.01. They fit right into the ealy 911 hubs, but they are a little bit longer than the original 911 stubs ( approx. 1/2 ") . greetings from Berlin (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_flagge6.gif) Benno |
| SirAndy |
Aug 12 2005, 02:02 PM
QUOTE(sechszylinder @ Aug 12 2005, 11:12 AM) Mine came of a 944 turbo and have the part # 951.332.235.01. ok, just got back from EASY with some more info ... 1 - yes, same part number on the 944 stubbies. they fit just fine. 2 - the CVs don't have to be from a 944 turbo, ALL 944s with aluminum trailing arms have the same halfshaft and CVs, however there are 3 different types of stub axles and hubs on those (later) 944s. 3 - the donor 944 needs to be post-mid-85 4 - Price: used 944 turbo axle (including the stub axle) ~$100 per axle (*) 5 - Price: used coarse spline 915 output flange ~$75 per flange (*) (IMG:style_emoticons/default/boldblue.gif) Andy * prices may very depending on your haggling skills. you can increase your haggling skills using manna from slashed goblins. |
| Aaron Cox |
Aug 12 2005, 02:19 PM
Professional Tinkerer ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,548 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California |
will 944 AUTOMATIC CV's and Stubs work?
| ClayPerrine |
Aug 12 2005, 02:32 PM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,542 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
QUOTE(Aaron Cox @ Aug 12 2005, 02:19 PM) will 944 AUTOMATIC CV's and Stubs work? IIRC.. the stubs are the same. But I think that the axles are different for an Auto. But I have been known to be wrong. BTW... I beat everyone here to it. I have this setup on my car right now. I have driven it and it works fine. |
| SirAndy |
Aug 12 2005, 02:45 PM
QUOTE(ClayPerrine @ Aug 12 2005, 01:32 PM) BTW... I beat everyone here to it. I have this setup on my car right now. I have driven it and it works fine. (IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) |
| Aaron Cox |
Aug 12 2005, 02:49 PM
clay -
the AUTOMATIC axles look to have the same CV's and STubs....BUT the axle length is different.... not happy about the price and rareness of the 915 flanges though (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) |
| SirAndy |
Aug 12 2005, 02:54 PM
QUOTE(Aaron Cox @ Aug 12 2005, 01:49 PM) not happy about the price and rareness of the 915 flanges though (IMG:style_emoticons/default/sad.gif) they're actually not *that* rare ... there were a few years somewhere between '75 and '80 when the 915 used the coarse splined input shafts ... and the price may very well vary from different vendors, what i listed is what *i* payed ... (IMG:style_emoticons/default/cool.gif) Andy |
| Jeroen |
Aug 12 2005, 05:03 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
QUOTE(sechszylinder @ Aug 12 2005, 07:12 PM) I've had the same idea to convert the rear to five lug using 944 parts . But i'm still looking for the right cvs. Benno, check out the mittelmotor website they have a special offer on the 944 cv's during their "Sommerfest" |
| sechszylinder |
Aug 13 2005, 12:51 AM
hey jeroen,
thanx for the hint. A friend of mine will pick up some stuff for me at MM sommerfest ... Benno |
| sechszylinder |
Aug 13 2005, 01:12 AM
hi folks,
now i'm comletely confused. (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) I've had a look at the parts catalog of mittelmotor (www.mittelmotor.de). They list only two different cv's for the 944. 1. 82 -89 all 944 2. S2 and Turbo According to PET there must be at least three different CV's, which means that 82-85 are different from those used on the later cars. Could someone bring a little bit light into the darkness ? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) Benno |
| SirAndy |
Aug 13 2005, 04:17 PM
QUOTE(sechszylinder @ Aug 13 2005, 12:12 AM) Could someone bring a little bit light into the darkness ? there's 3 different types of axles for the 944, but only 2 different types of CVs ... same CV for: 944 '83-'91 and pre '87 944 turbo different CV for: 944 turbo '87-'91 here's the number off the CVs i have: C 153120198027 LOBRO 17 91 W-GERMANY (IMG:style_emoticons/default/wink.gif) Andy |
| sechszylinder |
Aug 14 2005, 04:03 AM
o.k. Andy, now i think i've got it (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) that means, that you can use any 944 (as well 924S) CV from 83 thru 91 in combination with modified 914 axles and the early turbo stubs. Later CVs from S2 and Turbos will not work, due to a different splining on the axle side. o.k. thats it (IMG:http://www.914world.com/bbs2/html/emoticons/mueba.gif) now i will go out and hunt for parts ;-) Benno |
| neo914-6 |
Aug 14 2005, 09:54 PM
neo life ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,086 Joined: 16-January 03 From: Willow Glen (San Jose) Member No.: 159 |
Andy,
Where's part I of this triology? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) Nice job, BTW... |
| SirAndy |
Aug 14 2005, 10:26 PM
QUOTE(Neo914-6 @ Aug 14 2005, 08:54 PM) Where's part I of this triology? (IMG:style_emoticons/default/confused24.gif) somewhere in here, but it has a different title ... i'll merge all previous threads into a "HOW TO" article once i get the axles installed ... (IMG:style_emoticons/default/type.gif) Andy |
| Gary |
Aug 16 2005, 10:14 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 749 Joined: 12-January 03 From: Mount Airy, MD Member No.: 134 Region Association: MidAtlantic Region
If anyone's looking to do this, there's a pair of 994 stubs on ebay, item 7992744129. Part numbers from the picture match. One more day to the auction. No association with the seller, thought someone might be interested...
Lo-Fi Version | Time is now: 15th April 2026 - 08:00 PM |
