Full Version: Rear 5-Lug with 944 Parts, PART III
now let's put it all together!
944 turbo CV on the 914 axle shaft:
user posted image
both ends:
user posted image
915 (911) coarse spline tranny output shaft bolted to the 944 CV:
user posted image
944 turbo stub axle bolted to the 944 CV:
user posted image
early 911 hub (real 5-lug!) bolted to the 944 stub axle:
user posted image
and the complete axle: boldblue.gif
user posted image
i like it!
smash.gif Andy
one more ...
redshift
Oh noes Andy!
Aren't you fogetting at least .... something?
M
-hint... WHERE IS THE CAR!?-
QUOTE(redshift @ Aug 7 2005, 07:47 PM)
you know how it is ...
since i powdercoated the suspension yellow, i can't keep up with the car anymore ...
it's simply too fast ...
this was just a test run, making sure all the parts fit together OK. which they do.
look out for my next "how to" on installing the rear mueller roller bearings and the 911 e-brake setup.
once those are done, the new axles will be installed. i promise ...
smash.gif driving.gif smilie_flagge24.gif Andy
Dr Evil
Yo dog,
aren't you missing the keeper thing that fits in the groove at the end of the CV and presses against the CV in pic #1? What holds the tranny side CV fast to the axle?
914MF
Is there a reason you did not use the 944 axles? Were they too long? Nice pictures smilie_pokal.gif
QUOTE(Dr Evil @ Aug 7 2005, 08:07 PM)
Yo dog
wassup bro ...
as i said in the post above, this is just a test fitting. no need to put all those little clips on there just yet.
also, you might notice that the CVs are still missing the grease ...
cool.gif Andy
QUOTE(914MF @ Aug 7 2005, 08:11 PM)
yes, 944 axle is ~1" too long ...
see this thread for more details:
http://www.914world.com/bbs2/index.php?act=...f=2&t=36170
cool.gif Andy
rick 918-S
rick 918-S
Anyone have a part cost breakdown? What do the early flanges go for used? Can you use non-turbo 944 stuff? ie, axle flange, CV's, etc.....?
Dr Evil
He he, word player. I noticed Mikey's lathing to fix the prob too. Thanks for putting all of this stuff up for everyone. Someday I wanna do this conversion. I wish that I would not have sold my early 911 hubs rolleyes.gif
Engman
At least now we have a solution to the NLA cv joints on the 914.
Nice work guys!
Now pics in the car!
M
seanery
what bearing will you use?
QUOTE(seanery @ Aug 7 2005, 10:17 PM)
i've got the stock (FAG) 914/4 wheel bearings ...
the early 911 hubs have the same dia. as the 914/4 hubs and will slide right into a stock 914/4 bearing ...
wink.gif Andy
seanery
sweet!!!
QUOTE(rick 918-S @ Aug 7 2005, 08:29 PM)
Mr. EASY let me borrow all the parts to make sure it would all work together before he was going to charge me ...
hmmm, i think i'll drop by there tomorrow with a sixpack of beer for the guys,
now that i think about it, that was awfully nice of them!
pray.gif Andy
michelko
hey,
whats wrong with your camera?
JFJ914
Andy, what is the diameter of the C/V's? 100mm or 108mm?
Answered my own question. 100mm from Part II!
TimT
hey,
Those pic´s are so ...hmmm...clear!
agree.gif werd
Stephane
Good job Andy!
Two questions come to mind;
1st- Is the 944 stub & 914 stub axle the same overal lenght?
2nd- Does the 944 Cv have the same articulation as the 914 CV.
Cheers
Stephane
Mueller
QUOTE(Stephane @ Aug 8 2005, 04:25 PM)
Good job Andy!
Cheers
Stephane
these 944 axles are too long...see this thread for more info...
944 CV usage wtih 914 axles
the 914 axle must be machined a little to work with the 944 CV
IPB Image
QUOTE(Mueller @ Aug 8 2005, 04:46 PM)
the 944 Stub Axle is the same width as the 914 stub axle on the CV side of the wheel-bearing, the only difference is that the actual thread that sticks out on the wheel side (outside) seems to be a bit longer ...
smile.gif Andy
PS: i don't have a 914 stubby handy, but i can take exact measurements once i get back to EASY ...
if by that you mean the degree of rotation, yes, the two CVs are completely identical, except the 944 CV is bigger ...
wink.gif Andy
Stephane
That's great, this sounds like a more affordable way to convert to 5 lug & I bet these parts are easier to find to.
Keep us posted please!
Stephane
cha914
actually I think the 944 CV's will give you more articulation, if I remember correctly from my dune buggy research, the bug CV's are the worst (probably pretty close to the 914's), then the 944 and TIV bus CVs are next, and then the 930 CV's give the best articulation and will handle the most power...
here is a good site with the different sizes:
http://www.blindchickenracing.com/How_to/C..._joints_101.htm
Tony
sechszylinder
hi Andy,
thats a really nice work !!!
I've had the same idea to convert the rear to five lug using 944 parts . But i'm still looking for the right cvs.
944 rear axle
Whats the partnumber of the 944 stub axles your using ? Mine came of a 944 turbo and have the part # 951.332.235.01.
They fit right into the ealy 911 hubs, but they are a little bit longer than the original 911 stubs ( approx. 1/2 ") .
Benno
QUOTE(sechszylinder @ Aug 12 2005, 11:12 AM)
ok, just got back from EASY with some more info ...
1 - yes, same part number on the 944 stubbies. they fit just fine.
2 - the CVs don't have to be from a 944 turbo, ALL 944s with aluminum trailing arms have the same halfshaft and CVs, however there are 3 different types of stub axles and hubs on those (later) 944s.
3 - the donor 944 needs to be post-mid-85
4 - Price: used 944 turbo axle (including the stub axle) ~$100 per axle (*)
5 - Price: used coarse spline 915 output flange ~$75 per flange (*)
boldblue.gif Andy
* prices may very depending on your haggling skills.
you can increase your haggling skills using manna from slashed goblins.
Aaron Cox
will 944 AUTOMATIC CV's and Stubs work?
ClayPerrine
QUOTE(Aaron Cox @ Aug 12 2005, 02:19 PM)
IIRC.. the stubs are the same. But I think that the axles are different for an Auto.
But I have been known to be wrong.
BTW... I beat everyone here to it. I have this setup on my car right now. I have driven it and it works fine.
QUOTE(ClayPerrine @ Aug 12 2005, 01:32 PM)
Aaron Cox
clay -
the AUTOMATIC axles look to have the same CV's and STubs....BUT the axle length is different....
QUOTE(Aaron Cox @ Aug 12 2005, 01:49 PM)
they're actually not *that* rare ...
there were a few years somewhere between '75 and '80 when the 915 used the coarse splined input shafts ...
and the price may very well vary from different vendors, what i listed is what *i* payed ...
cool.gif Andy
Jeroen
QUOTE(sechszylinder @ Aug 12 2005, 07:12 PM)
Benno, check out the mittelmotor website
they have a special offer on the 944 cv's during their "Sommerfest"
sechszylinder
hey jeroen,
thanx for the hint. A friend of mine will pick up some stuff for me at MM sommerfest ...
Benno
sechszylinder
hi folks,
I've had a look at the parts catalog of mittelmotor (www.mittelmotor.de).
They list only two different cv's for the 944.
1. 82 -89 all 944
2. S2 and Turbo
According to PET there must be at least three different CV's, which means that 82-85 are
different from those used on the later cars.
Benno
QUOTE(sechszylinder @ Aug 13 2005, 12:12 AM)
Could someone bring a little bit light into the darkness ?
there's 3 different types of axles for the 944, but only 2 different types of CVs ...
same CV for:
944 '83-'91 and pre '87 944 turbo
different CV for:
944 turbo '87-'91
here's the number off the CVs i have:
C 153120198027 LOBRO 17 91 W-GERMANY
wink.gif Andy
sechszylinder
QUOTE (SirAndy @ Aug 13 2005, 02:17 PM)
QUOTE (sechszylinder @ Aug 13 2005, 12:12 AM)
same CV for:
different CV for:
944 turbo '87-'91
wink.gif Andy
that means, that you can use any 944 (as well 924S) CV from 83 thru 91 in combination with modified 914 axles and the early turbo stubs.
Later CVs from S2 and Turbos will not work, due to a different splining on the axle side.
now i will go out and hunt for parts ;-)
Benno
neo914-6
Andy,
Nice job, BTW...
QUOTE(Neo914-6 @ Aug 14 2005, 08:54 PM)
somewhere in here, but it has a different title ...
i'll merge all previous threads into a "HOW TO" article once i get the axles installed ...
type.gif Andy
Gary
If anyone's looking to do this, there's a pair of 994 stubs on ebay, item 7992744129. Part numbers from the picture match. One more day to the auction. No association with the seller, thought someone might be interested...
