What should I do about the engine?, I've got a few choices, need your input |
Type 47 |
Nov 30 2022, 08:11 PM
Senior Member Group: Members Posts: 782 Joined: 1-June 10 From: St. Louis, MO Member No.: 11,790 Region Association: None |
So, finally after 10 years we are getting it put back together. Things are progressing OK, many issues but things are moving forward to the point where I need to think about what to do when it comes time to put in the engine.
I little history: 75' 2.0 with 62k miles. the PO had replaced the FI with weber carbs but had put the FI in a box. The strategy for the rebuild is to get the car from parts in a box to functioning. The debate about FI vs. Carbs will wait for another time (we did put both SS fuel lines in the tunnel). So we are putting the Webers back on initially. Here is my engine question: I have 3 engines. Behind door #1 is the 62k engine running fine when car was disassembled. A 75' 2.0. The issues with this, is the emissions crap that was done to the heads. When I realize the emissions crap, I was like WTF what are these tubes?? this engine has no heat exchangers but some kind of exhaust system that eliminate the heat for the HVAC system. Has full engine tin, alt, etc. Behind door#2 is a late 73' 2.0 core with no tin. behind door#3 is 74' 1.8 that has been apparently upgraded with a big bore kit. This engine has SS heat exchangers. So what do I do???? 1. just spray WD-40 in the spark plug hole of the original and cross my fingers? 2. rebuild the 73' and put the 2L sheet metal from the original engine on it (it would fit right??)? 3. I can't see a scenario where the 1.8 works. Maybe trade heat exchangers for one to fit on the 2.0s, rebuild and sell it. 4. or put the heads from the 73' on the original engine? My tech (son) is really getting tired of putting on seals and is jonesing to rip into redoing an engine. please advise |
mihai914 |
Dec 2 2022, 08:06 AM
Senior Member Group: Members Posts: 800 Joined: 2-March 05 From: Montreal, QC Member No.: 3,697 Region Association: None |
I'm in a very similar situation as the OP with multiple engines and plenty of plans and options.
As others have mentioned, go with the engine that is closest to get you driving the car. Focus on one engine and one only, then you can think about the other builds if still needed. And if I were to start from scratch, I would just bring the original engine to a reputable builder and have him do it. I.E. not gather other engines and buy parts to rebuild 2-3 engines. Once you start doing stuff yourself and you get overwhelmed with the project or life, it's very hard to bring your parts to a builder and ask him to just assemble what you have (which is understandable). |
Type 47 |
Dec 2 2022, 10:15 AM
I'm in a very similar situation as the OP with multiple engines and plenty of plans and options. As others have mentioned, go with the engine that is closest to get you driving the car. Focus on one engine and one only, then you can think about the other builds if still needed. And if I were to start from scratch, I would just bring the original engine to a reputable builder and have him do it. I.E. not gather other engines and buy parts to rebuild 2-3 engines. Once you start doing stuff yourself and you get overwhelmed with the project or life, it's very hard to bring your parts to a builder and ask him to just assemble what you have (which is understandable). All very true, especially if it was just me. fortunately, I have my son helping who is an automotive technician. My other son is a Gold Meister certified Porsche technician but is very busy and doesn't live close by. |
Lo-Fi Version | Time is now: 18th May 2024 - 05:05 PM |
