2 Pages V < 1 2
> JWest Black Friday Make Up Sale, Since you guys missed it
GBX0073
post Dec 11 2022, 10:11 PM
Post #21
Thanks James
Your sale pushed me to get a shifter even with other projects Needed to get the engine back in the car (IMG:style_emoticons/default/smile.gif)
BeatNavy
post Dec 12 2022, 04:50 PM
Post #22
I'd like to get the 914 Fog Light Module, but I just (finally) upgraded my headlights to LED. I now have that LED headlight/Fog Light issue that is well known. The fix is well known as well: disconnect the blue/white wire at fuse #1 and ground directly to chassis. All described here: http://www.914world.com/bbs2/index.php?showtopic=344457
So: Can I still install the JWest fog light mod? How does that change/impact the issue or solution? In other words, can I have LED headlights, the JWest fog light mod, and have everything work the way it's supposed to?
I did some searching and couldn't find anything definitive.
Thanks for any help.
JWest
post Dec 12 2022, 05:08 PM
Post #23
QUOTE(BeatNavy @ Dec 12 2022, 04:50 PM) *
This is documented in the fog module instructions - once you have done the high beam feature defeat by grounding the white/blue wire, the fog module will work fine with LED headlights.
James
BeatNavy
post Dec 12 2022, 05:16 PM
Post #24
James, you are the man. Thanks, I'll order that mod now (IMG:style_emoticons/default/beerchug.gif)
2 Pages V < 1 2
- Lo-Fi Version Time is now: 31st July 2025 - 11:39 AM
