I need a new muffler.....1971, 1.7L, what are my options? |
potomacmidget |
Dec 18 2022, 09:08 PM
I gotta have more cowbell.... Group: Members Posts: 161 Joined: 27-March 11 From: Maryland Member No.: 12,860 Region Association: North East States |
Hi -
The Bursch exhaust on my 1971 1.7L is beyond repair at this point. I unbolted it and need to purchase a new unit. I am pretty open on replacements, meaning I don't have to replace it with another Bursch (of course would like to keep the price manageable but that is another topic...). With that said, minus the Bursch, the car is bone stock and so I would need a new system, the gaskets and the associated bolts as they are not in good shape (I am unsure of the bold size, any help there appreciated too). I did the measurements from a picture I found on the site and I definitely have the dimensions for the 1.7 L HX. I read in another thread that the tailpipe on a vendor's unit was not compatible with the stock rear valence, so I guess I need to avoid that unit (Dansk?). I know that 914rubber has a stainless steel system too - anyone have any experience wit that one? Any advice appreciated. Thanks in advance. Best, Reg |
rhodyguy |
Dec 19 2022, 08:26 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,080 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
If the piping is still ok, simply replace the muffler with a like sized unit. Salvage the whole exit pipe. Use 2 rectangular flanges, weld on pipe, for the piping to muffler pipe piece rather than a solid weld. 1.7/1.8 HE flanges are slightly dif than the 2.0 versions as are the gaskets.
windforfun |
Dec 19 2022, 11:44 AM
Senior Member Group: Members Posts: 1,789 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
I went with a Dansk rig that I think I purchased from AA. It was plug & play. The tailpipe was included.
mb911 |
Dec 19 2022, 02:43 PM
914 Guru Group: Members Posts: 6,851 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
wonkipop |
Dec 19 2022, 03:19 PM
Advanced Member Group: Members Posts: 4,299 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
the dansk should go straight in the earlier 914.
its the later design single piece muffler without the smaller hot dog outlet pipe and the design superseded the earlier type and was intended as the replacement part from 74 on. so the tailpipe should exit the hole in the earlier valence as far as i can work out. maybe others know better, but the single piece muffler was the intended replacement part for all 1.7 914s after the 1.8 came out in 74. i've got a 74 and sit in far off australia. even getting a dansk here is a pain in the arse by the time freight and customs and aus $ conversion happens. which forced me to make an interesting discovery. the 914 muffler is just the kombi (bus) / 412 muffler upside down. all VW did was weld the exhaust inlet pipe flanges on upside down compared to a bus/412 muffler. its interesting if you look around the VW parts retailers. the bus muffler by dansk goes for about half the $ of the 914 one. and as far as i can tell its the same thing. if you are handy with a grinder and a welder you can buy the bus one and do a bit of cut and shut on the inlet flanges and you are in business. buy the tailpipe section on its own, its available as a separate part. i don't have a dansk, i managed to find a stainless steel bus muffler here in aus 20 years ago and have modified it as above. should outlast me. EDIT. i can see how a dansk would screw up after looking up a early 4 with the deep rear valence. no way would it fit. 73/74 much further to left and edge of car on tailpipe. interesting, if porsche thought the later muffler superseded they would have had to be fitting a later rear valence as well? it might be pretty hard to find one of those early mufflers with the extra hot dog tail pipe section that turns out before the left hand end of main muffler - if you have an early valence. looks like that is what the tail pipe would have to do. which is kind of a geometric impossibility with later dansk type full width muffler and where inlet pipes from engine land. that early valence outlet is inboard of end of muffler! i'm pretty sure its an early VW 411 muffler. maybe an NOS is a possibility if you searched around? or get the dansk and get a later valence to go with it. |
dr914@autoatlanta.com |
Dec 20 2022, 10:32 AM
914 Guru Group: Members Posts: 7,858 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
the dansk factory duplicate looks good fits well and gives you stock performance, better off the line that ANY aftermarket variety, (not that they exist these days)
nathanxnathan |
Dec 20 2022, 04:22 PM
Member Group: Members Posts: 282 Joined: 16-February 18 From: Laguna Beach, CA Member No.: 21,899 Region Association: Southern California |
Busdepot sells an Ernst muffler that is what the Dansk is trying to be. Basically it is an OEM 1.8 muffler. Side exit. The original 1.7 muffler was a Leistritz center exit that is a little smaller, but NLA.
Dansk and Walker (czechoslovakia), the feel/production quality pales compared to the real-deal Ernst. This is a really nice piece imo https://www.busdepot.com/071251053e |
wonkipop |
Dec 20 2022, 06:14 PM
Busdepot sells an Ernst muffler that is what the Dansk is trying to be. Basically it is an OEM 1.8 muffler. Side exit. The original 1.7 muffler was a Leistritz center exit that is a little smaller, but NLA. Dansk and Walker (czechoslovakia), the feel/production quality pales compared to the real-deal Ernst. This is a really nice piece imo https://www.busdepot.com/071251053e yes and no. a bus muffler is different. but its only in the way the inlet flange plates are oriented. here is the original factory 914 muffler that was once on my car. its a 74 1.8 here is bus (or late 412) single piece german factory muffler. notice how the VW application has the inlet flange plates welded at 180 degree rotation to a 914. they used the same basic muffler but that was the difference. this allowed the 914 to retain its lhs tailpipe location in these later single piece mufflers. the bus and the type 4 exited on the rhs. all the crazy dents and creases in the muffler are because it tucked up under the fan housing and allowed for the oil dipstick filler tube because they faced up in the bus. they end up facing down in the 914 and make no sense because its not tucked up under a fan housing. (IMG:style_emoticons/default/biggrin.gif) anyway you are right about one thing. that ernst muffler is a much better buy. and it will bolt straight on but you will end up with a rhs tailpipe and the muffler will end up closer to the heat shield under the trunk. which is ok. a way around that is modify the valence and just go with that. or you can do what i did which was modify the bus muffler and cut the inlet flanges off and reweld them back on 180 degree rotated. either way, the dansk bus muffler or the ernst bus muffler is a way better buy than the dansk 914 muffler because either dansk or the retailers are having 914 owners on. its the same muffler apart from the flange orientation and they generally retail for double. thats bs - out and out bs on dansk's part. if you are handy with a grinder and a welder grab the bus muffler. make your own tailpipe or buy the dansk 914 tailpipe and use that. i know because i have done it. i have a modified bus muffler on my car. a high quality stainless steel one i got hold of 20 years ago. i'm not sure if it was made by an australian VW parts supplier or if it came from germany, but its a very high quality bus muffler i got hold of and modified. (IMG:style_emoticons/default/beerchug.gif) |
wonkipop |
Dec 20 2022, 06:39 PM
here are some photos of back when i modded the bus muffler.
about 4 years ago. i did run it unmodified for a while before that with a modded tailpipe out the rhs just for convenience when i first had to change the muffler. (that was when the penny dropped about the rotated flanges. when we first looked at the muffler both my mechanic and i thought, aha its just a bus muffler. but then after getting hold of one and going to tfit it we both said, oh no its not quite a bus muffler. (IMG:style_emoticons/default/smile.gif) )then i took it off and did it properly a bit later on. the photos have reminded me we did a bit of reinforcing to kind of duplicate how the 914 mufflers have reinforcing plates from the flange back to the muffler body. we did "sturdy" plates but given the muffler pretty much hangs of those flanges even though the flanges are suspended from the hanger off the gearbox i figured i'd make sure it did not vibrate so much it would crack the flange welds down the track. it all works really well except the exhaust does sound very "tinny" until it warms up. i put that down to the SS heat exchangers in addition to this SS muffler. doesn't have that deeper tone that the mild steel exhaust systems have. |
vintagethunder |
Dec 20 2022, 07:18 PM
Newbie Group: Members Posts: 38 Joined: 7-January 22 From: Monmouth, IL Member No.: 26,225 Region Association: Upper MidWest |
If the Dansk muffler outlet isn't right for your rear valance, AA sells an outlet with a tighter bend on their site and ebay.
nathanxnathan |
Dec 20 2022, 07:52 PM
a bus muffler is different. I see what you're saying. I can definitely see how the first pic you posted that wouldn't work on a bus since the indents for the engine tin by the fan and the dipstick indent are below instead of above. But are you sure the bus muffler won't bolt up and work on a 914? I know the 1.7L muffler was the same muffler for both - almost sure anyway. The rusty one here came off my 72 914 which has a snowplow valence. Both of these are the same. The tailpipe lined up with the hole. Here is the nos muffler above on the engine of my 72 bus. (IMG:http://www.914world.com/bbs2/uploads_offsite/www.thesamba.com-21899-1671587553.1.jpg) I'm thinking maybe the tailpipe of the side exit 1.8 bus muffler can't be made to work with the 914 valence? I know it's triangular/3 bolt, and could go 3 ways(?) I've run the Ernst before but I don't have one currently to check.. |
nathanxnathan |
Dec 20 2022, 08:01 PM
Also, looking at the Dansk "914" muffler at AA, the flanges look the same as the "bus" muffler you posted above. The longer/2 bolt/bottom side of the flange is opposite of the indents.
http://www.autoatlanta.com/Porsche-914-Dan...ffler-srch.html |
wonkipop |
Dec 20 2022, 08:28 PM
@nathanxnathan .
yes the bus muffler will bolt straight up. take a close read of my post. but the result will be a right hand side exit. thats how it exits on the bus. and on the 412. after they went to the single piece muffler in either 73 or 74. definitely 74 but could have also been earlier in 73. that single piece muffler is a different ball game to the earlier style with the hot dog tailpipe you have posted. (note also your rusty 914 muffler does a real tight turn out before the left hand end of muffler to make the hole in the early valence). it will do your head in in a dyslexic way but you will see that i am correct about the later single part mufflers if you look very closely at my photos. i should know i have held both items in my hot little hands and worked it out. it is actually fine and if you did not care about originality - the smart move would be to make a modded valence with a right hand side dent and forever after be able to bolt a bus muffler straight up. your photo is also correct. the earlier 411 muffler that the early 914s had is pretty much identical. the difference is that hot dog section is shorter on the 914s and turns out sooner. 411s seemed to have two different tail pipes - one that shot out more or less straight towards outside of car on left hand side and one that turned out under the back over towards left. i think one sort went of variants because they had a tailgate. this might have been the extreme left side exit. and the other type went on the fastbacks and sedans. at that time 914s, 411s all had left hand exit tail pipes. then VW went to right hand side exit on their 412s and buses. but the 914 stayed left hand side. the key to understanding this is remembering that the flanges at the end of the heat exchangers on all the cars, 914s, 411/412s and buses is all in the same orientation. 2 bolts down. i bolt up tapering upwards. thats why the late 914 muffler had to be made with the flanges 180 degrees to the others, so it could still do the lhs exit. i really like your suggestion of picking up an ernst muffler. its a high quality item. if it were me and i lived in the states its what i would do. then i would either mod my 914 valence for a right hand tailpipe or if i was super fussy mod the muffler like i did. ------ if i was the OP and i didn't have any metal/welding skills and i had a early 914 that still had the snowplow valence on it i would buy the dansk and bite the bullet. the price difference is tolerable in the USA. and buy a late valence and just go with the whole late set up. its all a straight bolt on job. put the original valence away in a cupboard. or as @vintagethunder suggests maybe there is a tight turn tailpipe that will get out through the earlier valence. it would want to be tight. i already have what i think is a relatively tight turn tailpipe to make it out on the 74 valence. but if that tailpipe is out there that could make the dansk work and you could keep the early valence. |
wonkipop |
Dec 20 2022, 08:37 PM
@nathanxnathan
here are the two dansk ads side by side. you can see it all clear as a bell. note where the tailpipe outlet is in both mufflers then look at the flange plates. the ernst will be the same as the dansk VW one. |
nathanxnathan |
Dec 20 2022, 09:00 PM
@wonkipop
Ah yeah, I see what you mean. The side exit mufflers come out the right side. You actually have to modify the 72 bus right side rear bumper bracket to clearance for the tail pipe. In 73 they switched the tow hook to the left side. Still, unless the Dansk muffler has the picture wrong, the outlet is coming out the right side, and it is essentially a bus muffler. (IMG:http://www.914world.com/bbs2/uploads_offsite/c767170.r70.cf2.rackcdn.com-21899-1671591641.1.jpg) Here's a pic of the original 914 1.7 L center exit tailpipe (rusty one) vs the longer (411?) tailpipe. The proper early type 4 bus tailpipe is actually like this, since I'm all showing off my early tailpipe collection. (IMG:style_emoticons/default/biggrin.gif) |
nathanxnathan |
Dec 20 2022, 09:05 PM
@nathanxnathan here are the two dansk ads side by side. you can see it all clear as a bell. note where the tailpipe outlet is in both mufflers then look at the flange plates. the ernst will be the same as the dansk VW one. Now I'm super confused lol. I'm getting dyslexia with all these upside down muffler pics. They all look to exit on the right to me?! |
nathanxnathan |
Dec 20 2022, 09:08 PM
@wonkipop Ok, I'm seeing it now. 2 bolts on the bottom, exit left for the 914 one. Ok, that took me a minute sorry. (IMG:style_emoticons/default/wacko.gif)
wonkipop |
Dec 20 2022, 09:24 PM
@wonkipop Ok, I'm seeing it now. 2 bolts on the bottom, exit left for the 914 one. Ok, that took me a minute sorry. (IMG:style_emoticons/default/wacko.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) it f%^ks with your head when you are looking at photos. but when you are looking at the real thing its easy to understand. VW and the parts bin mentality!!!! typically german. its how they got through world war 2. "lets just take this bit of a BF109 fighter and stick it in a tiger tank upside down and it should work. ja!" |
wonkipop |
Dec 20 2022, 09:48 PM
@nathanxnathan - you can kind of see what must have been going on between the giant bureaucracy of VW versus porsche in 1973/74.
if they had only been pumping out 1.7/1.8 914s they would have just flipped to a rhs exhaust like the rest of the VWs and done a mirror valence update panel. but no, porsche had gone off and designed the 2.0L with its "special" almost 914/6 muffler and a left hand side tailpipe. some accountant at VW probably said - no, not making two valence panels. and then went looking for someone to put in front of the firing squad. so some engineer or production manager at karmann probably worked out all they had to do was get ernst or whoever was making the mufflers to do a little tweak for the 914 inventory at no extra cost under threat of being pistol whipped. the bean counter would have calmed down. half a century later there is an opening for dansk to milk the market because the 914 muffler is so special. right? ......and you can't quite run over and grab that VW part from bus depot or whoever at half the cost like you can with the interior door handles and the cigarette lighter etc. |
potomacmidget |
Dec 21 2022, 02:41 PM
Dear All -
thanks for all the posts; this has been quite an education for me. Perhaps I will search for a later rear valence and that will give me more flexibility in the future. Thanks again, I truly appreciate everyone on this site. Best, Reg |
Lo-Fi Version | Time is now: 17th May 2024 - 09:40 AM |
