Drex 914, Iowa 914 |
Drex |
Dec 22 2022, 04:30 PM
Member Group: Members Posts: 170 Joined: 1-December 22 From: Guthrie Center, Iowa Member No.: 27,003 Region Association: None |
Hello Everyone
My name is Dave and middle name Rex...thus D Rex A nickname my office girls gave to me as a play on 'T Rex' It was quite a process to get signed up on this forum But it appears I finally on I'm in the process of buying a 1971 914 It was hit in the R front fender and now Sat for > 40 years in a barn but was covered up (see pic) I own a '62 VW Beatle and had a '71 911 at one time So am familiar with air cooled engines Before the accident, it was apparently a running car I know its hard to tell without a thorough inspection But assuming it does not have much rust How much should I be offering for it? Thanks for all your expect advise Drex (IMG:http://www.914world.com/bbs2/uploads_offsite/www.surfacezero.com-27003-1671748247.1.jpg) |
vintagethunder |
Mar 10 2023, 03:19 PM
Newbie Group: Members Posts: 38 Joined: 7-January 22 From: Monmouth, IL Member No.: 26,225 Region Association: Upper MidWest |
There are two thoughts on dropping the engine. One is to disconnect all but the last four bolts, jack it up high, secure with jack stands, add a 4x4 or 6x6 to the top of your jack (or the Tangerine plate), remove last four bolts then very carefully wiggle and lower the engine/transaxle.
The other way is to disconnect everything but the last four bolts, take the rear wheels off, drop the car down low until the engine is on a furniture dolly (small size, $10 at Harbor freight), take out the last four bolts, then raise the car. Put blocks in appropriate places so the chassis will not be allowed to drop too far. Two floor jacks and a buddy are helpful. Both require you to check clearance of multiple parts multiple times. I seem to recall the injectors are one of them. I have only used the second method. Like many mechanical things, the first time is the hardest. Next time will probably take 1/4th the time. Note: if you are using a Quickjack hydraulic device, it will not lift a car from the extreme down (wheels off) position, even a relatively light 914 without engine and transaxle without some help from a jack. There is a great 914 engine removal checklist somewhere out there on the internets was was extremely helpful for this first timer. Take lots of pics and sketch out and label the vacuum and fuel lines, and electrical connections. There are diagrams out there for the first two. Good luck! Let us know how it goes! |
Lo-Fi Version | Time is now: 24th May 2024 - 06:26 AM |
