need an Electrical engineer to explain this, jump box |
r_towle |
Feb 8 2023, 06:31 PM
Custom Member Group: Members Posts: 24,574 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Hi,
I have a 997 (this feels like the start of a support group thing) This car has an electric front hood latch. So, the battery needs to be hooked up to open the front hood where the battery is... Its not logical, but Porsche put in a shortcut. So, go to the fuse box inside, pull out a red lead, and hook up a 12VDC battery to this lead, and chassis ground... Hood opens. Instead of using a full size heavy car battery, I went and bought a lithium battery "jump box" thing Schumacher SL1639 Lithium Portable Power Pack and 1000A 12V Jump Starter So, it will not work. We ended up getting a full size battery, with jumpers, just to open the hood, so we could reconnect the battery. My question is...WHY does it not work? When I put my meter on it, I see 16VDC ITs fully charged. Its on. The Tech support told me the unit can only be used for jump starting a car. The mechanic at the shop told me he also had this issue, and the unit needs to see a load?? I will return this if it will never work...but I really need to know why it won't work. I can get a motorcycle battery, or some other unit that will take care of my needs...but this thing should work...yet it does not. Anyone care to explain electricity to me? Rich |
bkrantz |
Feb 8 2023, 09:00 PM
914 Guru Group: Members Posts: 7,751 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
Not sure about 997s, but my 991 has a hidden pull wire attached to the front latch, in addition to the fuse box jumper thing. The pull cable can be found hiding behind the front left fender liner. Some people relocate this or add an extension so they can pop the frunk lid without removing the fender liner.
Lo-Fi Version | Time is now: 6th May 2024 - 12:15 AM |
