need an Electrical engineer to explain this, jump box |
r_towle |
Feb 8 2023, 06:31 PM
Custom Member Group: Members Posts: 24,574 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Hi,
I have a 997 (this feels like the start of a support group thing) This car has an electric front hood latch. So, the battery needs to be hooked up to open the front hood where the battery is... Its not logical, but Porsche put in a shortcut. So, go to the fuse box inside, pull out a red lead, and hook up a 12VDC battery to this lead, and chassis ground... Hood opens. Instead of using a full size heavy car battery, I went and bought a lithium battery "jump box" thing Schumacher SL1639 Lithium Portable Power Pack and 1000A 12V Jump Starter So, it will not work. We ended up getting a full size battery, with jumpers, just to open the hood, so we could reconnect the battery. My question is...WHY does it not work? When I put my meter on it, I see 16VDC ITs fully charged. Its on. The Tech support told me the unit can only be used for jump starting a car. The mechanic at the shop told me he also had this issue, and the unit needs to see a load?? I will return this if it will never work...but I really need to know why it won't work. I can get a motorcycle battery, or some other unit that will take care of my needs...but this thing should work...yet it does not. Anyone care to explain electricity to me? Rich |
fixer34 |
Feb 9 2023, 07:26 PM
Senior Member Group: Members Posts: 1,081 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest |
I've been around electricity and electronics enough, but not convinced that a 'jump pack' that weighs 4 pounds and fits in my pocket is going to start a car that normally needs a 400CCA battery.
Anyway, get one of these with F2 terminals (same as all the push on connectors in the 914). Sealed lead acid so you can store it pretty much anyway you want. https://www.homedepot.com/p/MIGHTY-MAX-BATT...22495/323133872 Holds a charge for 6 months or more, put it on a regular batter charger to refresh. |
Lo-Fi Version | Time is now: 6th May 2024 - 02:05 AM |
