Replace or rebuild original fuel pump? |
Jay993 |
Aug 3 2023, 07:02 PM
Newbie Group: Members Posts: 25 Joined: 31-May 23 From: Los Angeles Member No.: 27,386 Region Association: Southern California |
Any help would be appreciated. My fuel pump isn’t pumping enough to bring the fuel up to the carbs. Does anybody rebuild these? I saw a nos one for sale for $$$. Any help would be appreciated! Thanks
914Sixer |
Aug 3 2023, 07:04 PM
You should be running a cheap $25-$50 pump. Nothing to rebuild. Chances are your tank sock is bad.
Jay993 |
Aug 3 2023, 09:47 PM
You should be running a cheap $25-$50 pump. Nothing to rebuild. Chances are your tank sock is bad. Good call! I assume you have to pull the tank to get to it, I’m sure it doesn’t screw in from the top. My fuel pump is original and pumps a little. So most likely the stained is plugged like you said. Any tricks/tips? Thanks! |
wonkipop |
Aug 4 2023, 04:48 AM
Advanced Member Group: Members Posts: 4,300 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
yeah i have rebuilt 2
go here to see what you are in for. http://www.914world.com/bbs2/index.php?showtopic=350416 (not interested in rebuilding, too far away mate, but you can do it. i encourage it. (IMG:style_emoticons/default/beerchug.gif) ) those three port pumps are red hot if you pick up a low enough mileage one. the seals go before anything else. and next the brushes or wear on the commutator. rest of it is built like a german brick shit house. anything that has done less than 100,000 mi is worth a shot. both i rebuilt were under 50k mi jobs. barely worn. the seals had shit themselves that was all. a crime almost to scrap them. mad max in the apocalyptic desert speaking here, keeping things going. (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/biggrin.gif) |
Jamie |
Aug 4 2023, 07:09 AM
Senior Member Group: Members Posts: 1,031 Joined: 13-October 04 From: Georgetown,KY Member No.: 2,939 Region Association: South East States |
You should be running a cheap $25-$50 pump. Nothing to rebuild. Chances are your tank sock is bad. Good call! I assume you have to pull the tank to get to it, I’m sure it doesn’t screw in from the top. My fuel pump is original and pumps a little. So most likely the stained is plugged like you said. Any tricks/tips? Thanks! Get rid of the tank sock, replace with an external fuel filter in line before pump. This allows service access without have to drain tank. (IMG:style_emoticons/default/confused24.gif) |
brant |
Aug 4 2023, 07:18 AM
914 Wizard Group: Members Posts: 11,624 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
If your car is a 4 cylinder
The original pump would have been for fuel injection And too much pressure for a carb You mention carbs so someone has put a lower pressure aftermarket pump on your car already or else it would have had a fire Replace if necessary with another carb rated pump and regulator |
dr914@autoatlanta.com |
Aug 4 2023, 07:28 AM
914 Guru Group: Members Posts: 7,864 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Jay993 |
Aug 4 2023, 08:16 AM
for carbs buy a new pump they are very very cheap Any help would be appreciated. My fuel pump isn’t pumping enough to bring the fuel up to the carbs. Does anybody rebuild these? I saw a nos one for sale for $$$. Any help would be appreciated! Thanks I forgot to mention it’s for a 914-6 with the webbers. Thanks guys! |
sbsix |
Aug 4 2023, 08:53 AM
only the lead dog enjoys a change in scenery... Group: Members Posts: 450 Joined: 10-January 12 From: Santa Barbara, CA Member No.: 13,990 Region Association: Southern California |
I don’t know of any other fuel pump that will work on a 914-6 other than the OE Bosch pump. If there is someone somewhere that rebuilds them that would be your best bet. Otherwise you’ll have to bite the bullet and find a new one. Do not discard your fuel sock. It’s there for a reason, to keep debris out of your fuel pump and Webers. They’re very inexpensive and available from 914Rubber and Tangerine Racing.
Your fuel filter needs to be between your fuel tank and fuel pump. I had to use fuel filter 131.262.275A recently since the filter I purchased from Stoddard advertised as a replacement for a 914-6 will not work. The filter I used had to be modified to fit the supply fuel line, however. Removing the gas tank is simple and draining the fuel is relatively easy. I just went through the fuel system on my 914-6 replacing all fuel lines, filters and installing stainless steel fuel lines from Tangerine Racing. My Bosch fuel pump has 820 miles on it and worked perfectly even after a ten year slumber. The only mishap I had was connecting the return fuel line to the supply port on the pump, and supply line to the return port. Took a few minutes of cranking the engine to figure out that problem. Your fuel pump is critical for a good running six engine. You shouldn’t compromise. You won’t be able to tune and adjust your Webers well otherwise. |
brant |
Aug 4 2023, 09:25 AM
all carb (low pressure) fuel pumps will work with a -6
and I realize that keeping it stock looking with a stock pump may be desireable. but all carb pumps will work with carbs. |
burton73 |
Aug 4 2023, 10:38 AM
burton73 Group: Members Posts: 3,524 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
PMB tried to rebuild the one that was in my 6 and I even sent a second one that was New Old Stock that I got off Ebay 14 years ago for $450. It did not work. Had to go with a new Bosch unit Porsche 911 914-6 Bosch Fuel Pump for Carbs. I paid over $700 for it they now are $800 or $900 depending on where you get it.
I had PMB change out to EFI so it used a different pump and sold the PMO 46s. Mine has a couple of hours on it. Bob B |
rhodyguy |
Aug 4 2023, 11:01 AM
Is it rotary or facet pump? If it’s LOUD chances are it’s a facet. The expensive filter lasts longer when any tank crap is trapped in the sock with the fuel filter down stream. With an empty tank you can look at the tank sock with a flashlight. You may see a bunch of debris in the fuel well in the bottom of the tank. New socks stand up when installed, not laying over flat. I figure the smarty pants engineers at Porsche put a sock AND filter in the fuel delivery system for a reason.
Root_Werks |
Aug 4 2023, 11:28 AM
Village Idiot Group: Members Posts: 8,321 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
It'd be nice to keep the stock fuel pump in a real 914-6, but you may have to settle for something from the aftermarket parts bin:
https://www.pelicanparts.com/More_Info/PELC...ASABEgIvg_D_BwE Keep the original, put oil in it, box it up etc. As others have stated already, check to ensure your tank strainer isn't all gummed up. Could be as simple as that. |
Jay993 |
Aug 10 2023, 07:53 PM
So I dropped the tank and changed the fuel sock. The one in the car was still standing, just discolored, and most likely original. This did not solve the problem. Next up I’ll be sending the fuel pump to “fuel injection corp” in northern ca. I think this will solve the problem. Anything else?
burton73 |
Aug 22 2023, 03:12 PM
So I dropped the tank and changed the fuel sock. The one in the car was still standing, just discolored, and most likely original. This did not solve the problem. Next up I’ll be sending the fuel pump to “fuel injection corp” in northern ca. I think this will solve the problem. Anything else? So Jay, You got the right pump from me now and it only has 3 hours on it, and you should be fine, but I put a tex message to you that if you are running the original fuel lines through the center, I suggest that you change out to stainless steel because if the lines leak you are screwed. You may want to change the pump location to the front to avoid vapor lock. Best Bob B (IMG:style_emoticons/default/welcome.png) |
Lo-Fi Version | Time is now: 17th May 2024 - 08:22 PM |
